Question about HP Pavilion N5150 Notebook
Remove password on my hp n5150
At boot my hp n5150 is asking for a password i never had one this is first time it ask foir one how can i remove password
    Novelist:
  • 83 Answers
This is the BIOS password. BIOS password is stored in the CMOS/ RTC battery of the notebook. So if you would remove it, reboot the notebook and then again reseat it. BIOS passowrd will get removed.
Check this link and download the manual to get the procedure for RTC battery removal.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=57784&lc=en&cc=us&dlc=en&lang=en&cc=us
If your laptop is in warranty you can call up HP and they fix it or give you the procedure to remove the password.
Dreamkam
Posted on May 28, 2010
Password reset asking foir insertion of floppy disc or usb flash drive#
You should have created a floppy-disk (or USB flash drive) after you initially defined the password, so that you can now use that device to "reset" the password.
Or, search for "Nordahl Offline Password" -- it's a bootable CD that can "blank" an existing password. Then, boot from the 'C:' drive, and leave the password field blank, and you will be able to login, and then set a more-memorable password, and you will be able to create that floppy-disk (or USB memory-stick).
Mar 07, 2014 | Lenovo Thinkpad 05K9283 - USB Portable...
It keeps asking for current password i dont know it
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Mar 22, 2013 | HP Mini 1000 Netbook
Intel Hp c.p.u. asking password .we do not use password to open our p.c.then why our p.c. ask for password ?
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Jun 03, 2011 | HP Compaq Motherboard
What is the default password bios of the HP
There is not default password as such but it comes up only when it is created.In order to get rid of the password we need to boot the computer to the BIOS .
Turn the notebook off and then when you turn it on or lets say as soon as you press the power button to turn it on start tapping the f10 key on the keyboard repeatedly till you get a screen that says BIOS SETUP UTILITY ,once you are on that screen press the f5 key on the keyboard it displays a mesage that says load default,press y for yes on the keyboard and then press f10 that displays a message which reads save and exit again pres y for yes and the computer restarts .Once it boots up should not for the bios password.
hope this helps you ...all the best
May 21, 2010 | HP Pavilion N5150 Notebook
Hp compaq nx8220 - Administrator password cannot be reset
If this issue started with a motherboard error that appeared to be a faulty CMOS battery and then it started incorrectly detecting your memory and now is asking for a password it could be a faulty motherboard. If you are 110% you or anyone else has set a password on that laptop then I would say your motherboard needs to be replaced. It is a difficult process to reset admin passwords on most laptops due to a security chip that will prevent the trick of removing the battery from working. In all honestly if no one has set a password and the motherboard THINKS someone has then even if you reset the password you will still have issues. There is a small chance your CPU or RAM could be defective. But, again going back to it saying you have a password set that was never set. It just yells faulty motherboard unless someone has set a password without you knowing.
Jul 28, 2009 | HP Computers & Internet
I got a used hP zv500 laptop it has a password that I cant get
As pc is booting hit F8
boot into safe mode login as administrator
goto start then run type cmd
type net user
type net user (account name) *
should ask for new password
there is a space before the *
Good Luck !!!!
Mar 08, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Removing power on password
When you restart your PC, before it boots to windows on the HP logo , tap the F10 key to enter set up, Go to security option and disable to power on option. next time when u restart it would not ask you for a power on password.
Feb 16, 2009 | HP Computers & Internet
HELP!!!! ---- HP Notebook (zx5060us) Asks for Bios Password Now...
If the system boots to a windows screen, then asks for a password, it's definitely NOT a bios password, but a windows operating system password. Either way, if we had it here at the shop, I could have it done in a few minutes; to bad you're not in Tulsa.
What makes you think it's a bios password?
Good luck
Nov 29, 2007 | Computers & Internet
HP Pavilion N5150 Notebook Logo
164 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
