Question about Microsoft Works 8.0 for PC
How do I sort text in a document, I just want to alpha small sets of info in docs that I write Thanks
  • 903 Answers
There should be an icon in the toolbar that has an "A" and a "Z" and arrow going up or down. Highlight the text you want to sort and click that icon. If the icon is not there you might have to search Help to find where you can choose the sort option.
Posted on May 28, 2010
Why do my database files open up in notepad whenever I click it, is this normal? help please...
You have notepad set as your default text reader. If you have Word installed use that as your default. So go in set up your default programs you can do this by going to setup default programs in the start menu when you get there look for your default programs for .doc files etc and set it to open up using Word or whatever Word program you have other than notepad. It will not harm your computer if you open .doc or .txt files using notepad.
If you want a free Word Document for Office files or for writing purposes go to Open Office it is a free word processor Click Here, that does not cost anything and will even open most Microsoft Office documents as well. Thanks for using FixYa! John
Apr 13, 2011 | Microsoft Windows Vista Ultimate Edition
All printout of correspondence is in small print. How do I increase the printout size?
Font type and size are usually set in the document processing application.
If it's a word .doc,you set the size in Word.
Anything you can paste to Wordpad,highlight the text and set the font size in the toolbar.
Aug 06, 2010 | HP Office Equipment & Supplies
Problems with .docx files
For infomration on Office 2007 .DOCX file format, refer to http://office.microsoft.com/en-us/word/HA100444731033.aspx
I use Office 2003, and have installed and currently employ the "Microsoft Office Compatibility Pack for 2007 Office Word, Excel and PowerPoint File Formats" mentioned in article. This is, for the most part, seamless when reading in Office 2007 .DOCX or .PPTX files, for examples, in Office 2003.
Otherwise, in Office 2007, you can change and set your Word Options so that you can save files in a specific format, including a previous Office version to ensure compatibility.
See http://www.mydigitallife.info/2008/11/25/how-to-change-default-file-saving-format-from-docx-to-doc-in-word-2007/
Hope this makes sense... Good Luck!
cds
Jan 20, 2010 | Microsoft Office Professional 2007 Full...
A document I am working on somehow got changed to rich text format, I don't know how this happened or how to change it back.
If you have Microsoft word on you computer, you may do any one of these steps that you are most comfortable with. First, you may click the document twice to rename it eg "name.doc" insure that you put .doc at the end or you may right click the file and choose open with and select Microsoft word and then go to save as and save it as a word document. Or you can open the file in word-pad and copy the text and paste it in a word document and save it. Rich text format is a Microsoft word-pad document while .doc is a MS word document or now they have .docx.
hope this help you have a great day!
Oct 04, 2009 | Dell Dimension 2400 PC Desktop
No new txt doc.
There is never ant option for .txt docs. It is only for a word doc and what you save it as is your problem. So, dont worry about it. After .txt you will ask for normal txt or rtf. The list is very long. So, the short cut is to open a new doc and save it as whatever you want.
Aug 22, 2009 | Microsoft Windows XP Professional
Scan a Document and Need to edit in Word 2007
Most of the time a scanner by default, will scan a document in a tif or other image file format. That means that the scanned image is actually very similar to a photograph. In order to edit the text, you first have to convert the image using something that's called OCR software. OCR is a process that the software uses to look at a scanned document image and determine what characters are on the page. It's not always very accurate but that depends on the quality of the scan and on the OCR software being used. You must have received some sort of scanning software with the scanner. Hopefully it containes some sort of OCR software. Some scanners will save you this extra image manipulation by having a setting that allows you to scan directly to a word document. Usually in that configuration, the OCR software automatically knows to convert the scanned document image in order to automate the process. But either way, you first have to install the manufacturer's software. Hope this helps. Please remember to rate my answer. Thanks.
Feb 26, 2009 | Visioneer OneTouch 5800 Flatbed Scanner
Editing a document that has no security on it
This is an interesting problem. Since you've already tried copy/paste to a new document, I'll assume you don't care about the file so much as the text in it.
First, make a copy of the file and let's experiment with that.
You said you cannot copy the text, but I'm not sure if that is because you cannot "select" the entire text of the document or because the copy function is simply not working on that file. If you're able to open the document at all, try using keyboard commands to perform the copy/paste. Open the doc and leave the cursor at the beginning of the text. Then attempt to select all the text by pressing Ctrl-A. If that works, then press Ctrl-C. Leave the document open and press Ctrl-N to open a new doc page. Then press Ctrl-V and see if the text pastes in. One important thing to know would be if the text pastes but exhibits the same 'symptom'. If so, attempt an EDIT, PASTE SPECIAL and try pasting "unformatted text". Unfortunately, that method will also remove your formatting.
Here's another approach that may allow you to retain most MS Word formatting items. Click START, RUN and type "wordpad" .. Then hit ENTER. This launches MS Wordpad which should be able to open most .doc files. Use the FILE, OPEN menu items to locate and attempt to open the document in question. If from here you are able to select all the text (Ctrl-A) and copy it (Ctrl-C) and paste it (Ctrl-V) into a new doc file, then we will move on to another possible option.
Another approach would be to download one of the many different .doc repair utilities that exist. There are a number of free ones as well.. repairmyword.com advertises a number of free utilities you may have luck with.
Hopefully one of these will help fix the matter... if not, let us know!
Aug 26, 2008 | Microsoft Word 2000 for PC
Scanning Problems
I would first make sure that you have latest driver update. MS Word is very particular about how it reads things back in. I would try saving the scan as a text file or PDF instead and then open them in Word. Hope this helps!
If this solution was helpful to you, will you please rate the solution? Thanks!
Aug 13, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
To fix the page layout to
Oomar,
Using Word with VB6, I show how you set the page size to A5:
Sub AutomateWord()
' Declare the variable.
Dim objWD As Word.Application
' Set the variable (runs new instance of Word.)
Set objWD = CreateObject("Word.Application")
' Add a new document.
objWD.Documents.Add
' Add some text.
objWD.Selection.TypeText "This is some text."
'Set Page Size
objWD.ActiveDocument.PageSetup.PaperSize = wdPaperA5
' Save the document.
objWD.ActiveDocument.SaveAs FileName:="mydoc.doc"
' Quit Word.
objWD.Quit
' Clear the variable from memory.
Set objWD = Nothing
End Sub
Hope this helps!
Mar 18, 2008 | Computers & Internet
Printing a selection from a text
Hilight the text by using the mouse, and right click and select copy.
On your desktop, right click and select NEW, then select either Word (if you have it) or Wordpad.
A new document will appear on your desktop. Double click it to open, click in the body of the document, right click and select paste.
In the file menu select print. Once done you can either save the document or if it's just temporary exit without saving.
Leaving the new empty Word document on your desktop to use for next time isn't a bad idea. You could even rename it to "Temp Word Doc" or whatever you like.
Dec 09, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Microsoft Works 8.0 for PC Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
