I have the denon avr3600, the protection is on, how can i turn it off, thanks
  • jimmysh131 Mar 22, 2009
    I have a 3600 was working fine till I started to mess with it and not sure what I did I cant get any sound from the tunner but tv works and cd works does anyone have any ideas thanks
  • 4,234 Answers
Unfortunately you can not just turn it off. Protection means that a problem was detected in the final output stage and that stage was shut down to prevent further damage to either the amp or the speakers. The typical problem is either the output transistors on one channel or the output amp chip for one of the surround channels. Expect a parts cost of about $25-$40 plus hte local labor rate for repair.
Dan
Posted on Apr 07, 2008
AVR X1000 going in protect mode?
If you used it for only 3-4 hours before the problem occurred then you should have a replacement warranty on the product.
I think you have already done the factory reset procedure shown on page 175 of the user manual.
Is it possible to take it to the place you purchased it from. Alternatively check the Denon website and find out who the closest agent is in your locality. Send it back with proof of purchase using a courier service that you can track for receipt. Hope it turns out well.
http://assets.denon.com/DocumentMaster/us/Owners%20Manual%20-%20English_AVR-X1000.pdf
Denon
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
How to take protect off a denon receaver
Hello. DC Protection is not something you can turn off. It is a protection system engaged by one of the microprocessors (computers) within your receiver. If any of the amplifiers are bad, and producing DC voltage at the output, the micro will immediately turn the unit off, to lesson further damage to the amplifier or speaker system. There can be other causes of why the unit's DC Protection relay is not engaging, but 90% of the issues, are related to amplifier damage.
Dave
Jun 15, 2012 | Denon DRA-685 Receiver
DENON UD-M30 CD Player is displaying the word PROTECT and will not function. Any ideas how to fix this problem? Many thanks.
HI:
Usually when a receiver goes into protect mode, there are several reasons, One is there is a bad speaker connected to the unit, this will cause the unit to to into protect mode, try disconnecting all speaker from the unit and turning it on if it does not go into protect then one of the speakers are bad. Another reason is the power output Amplifier IC is shorted inside the unit. Another reasons could be that speaker wires are touching each other and causing a short. Disconnect all unit connecting to the unit and try turning on, if it stays on and no protect then connect them including the speakers one at time until you determine which is causing the error. If it goes into protect with nothing but the unit on then the Output IC is bad and the unit needs servicing.
Mar 10, 2011 | Denon CDR-M30 CD Recorder
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
Denon AV Receiver Model AVR3600 locked at'' Protection '' mode
The power supply is damaged and needs to be serviced. You have done exactly what you should have to test for an outside issue, it's the receiver.
Nov 02, 2009 | Audio Players & Recorders
My aplifier Denon UDRA F-10 says "protect"
Blingking Light or Protect usually means that there is DC appearing in output stage and is protecting Connected Speakers.
It can be faulty Output Stage (Bad ICs/Transistors/Resistors/Capacitors) or Faulty Power Supply.
Working on These types of Problem is not user friendly at all.
Advising to take local Authorized Shop.
Jan 30, 2009 | Denon PMA-100M Amplifier
Stuck on standby
Unit is in protect mode there are a few problems that can trigger protect mode the most common is blown channel (shorted outputs). Sometimes one of the 15v regulators may go bad causing imbalance of supplys triggering protect mode. Also sometimes a bad solder connection could cause unit to go into protect also. I work for Denon authorzied repair center in Michigan if your nearby and Shipping to Michigan is economical let me know kstahl65@att.net
Feb 13, 2008 | Denon AVR-1804 Receiver
Denon surround saying protect on display
Make sure none of your speaker wires are touching, this will cause it to shut down instantly.
Oct 15, 2007 | Denon DHT500SD System
294 people viewed this question
 Grubhead
Grubhead
