Question about Canon Powershot A1000IS Digital Camera
Lens error, restart your camera please help me I need to solve the problem with my camera as soon as possible.. what should I do?? The model is Canon powershot A1000is
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 09, 2011
I have canon SX 100 IS PowerShot and facing the error Lens Error Restart Camera. Please solve the problem.
The lens error indicates that the movement is inhibited possibly by sand or grit. It also may be misaligned or an internal component has failed. Here are a few links to some other things to try. With newer cameras I am usually hesitant to suggest these options since they include some more extreme procedures that may cause further damage if not done correctly, but since yours is probably no longer under warranty, they may save you an expensive repair bill. An older Canon camera is used to demonstrate these procedures but, the lens structure of these compact cameras is the same so the examples do apply to this unit. These procedures are effective about 60% of the time. Click on or copy and paste the links into your browser.
Lens Covers
* Lens FIX 1
* Lens FIX 2
Additional details also can read in this previous post: support/t10373115-nikkon_s3000
Hope this helps.
Sep 14, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens error, restart camera? Nothing happens when camera is restarted.
The camera may have gotten some dirt or something in the lens. If you need help with it, try this site: www.camerasandparts.com They just deal with service for the Canon Powershot models and nothing else. They do outstanding work on these cameras, that's where a lot of people go for help with the Canons. If you look on their site under their service and repair, you'll see your G9 model. It's $89 for the parts and labor and the servicing for the camera with the return shipping included. They're pretty much unbeatable if you need help with a Canon. They do excellent work. Best of luck with the problem on yours.
Feb 14, 2011 | Canon PowerShot G9 Digital Camera
ERROR 99....WHAT THE MEANING....HELP ME/ model canon 1000 D
Error 99 means "other error", so there are may possible causes. However, in most cases it refers to a communication problem between camera body and lens.
Try the following:
  • Remove the lens.
  • Check the contacts at the lens mount and contact pads at the lens for damage and dirt. If necessary, carefully clean them.
  • Power on the camera, without a lens attached. Does the error recur?
  • If the error did not occur without a lens, re-attach the lens and try again.
  • If this did not solve the problem, try a different lens
If this didn't solve your problem, please report what happened when you performed these steps.
Mar 10, 2010 | Canon Cameras
Lens error,restart camera
This error occured when lens is prevented from properly extending or retracting.when pressure is applied to the lens or the area surrounding the lens while handling the camera.
Avoid applying pressure to the lens and surrounding area:
  • Do not touch Lens while shooting.
  • Make sure the camera is off before the camera is placed back in the case.
If you cannot clear the error code by turning the camera off and then on again then your device need to be repaired.
Rating the solution is highly appriciated...Good Luck.
Feb 28, 2010 | Canon 8.2-Megapixel Digital Camera Lens
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Jan 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
the beeping sounds means that your camera lens is stuck. contact the manufacturer (canon), for a possible solution...or they can even send u a new one. My friend dropped her SD630 and had the same problem...she contacted canon, and sent in her camera to be fixed, but it wasn't fixable, so canon sent her a brand new camera. hope this helps.
Jun 14, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens Error, Restart
Hi
What you are seeing is a generic stuck lens error message, turning off the camera and turning it on again will not fix the lens unfortunately.
Your lens needs to be cleaned or repaired, and if it cant be repaired it needs to be replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
Fixya rules prevent me from giving you a link to anything off Fixya that would help you fix your camera.
Good luck from....
Darntoothysam com
May 01, 2008 | Canon PowerShot SD1000 Digital Camera
Well I dropped my Canon PowerShot® SD850 IS on the bathroom floor!
You need to take it to a camera shop for servicing, this is not something you're going to be able to solve at home
Mar 20, 2008 | Canon PowerShot SD850 IS Digital Camera
Canon Powershot A1000IS Digital Camera Logo
357 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
