Question about Panasonic NN-T990SA Microwave Oven
Panasonic microwave shuts off
My microwave turns on and works for 3-4 seconds and then shut off. WHat is up?
  • Aji Divakar
    Aji Divakar Jul 07, 2008
    i have a new panasonic microwave NN-GD576W used only three times, forth time i used to make a cake... turn table start to turn only 20seconds after it shuts off,its not getting heat, the window showing two dots,i tried two thee times its happening shuts off in 20sec,anybody can help me?
  • codixon Dec 25, 2008
    My Panasonic Inverter Microwave consistantly shuts off after 4 seconds.
5 Suggested Answers
MicrowaveSvc
  • 8973 Answers
SOURCE: Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Posted on Dec 28, 2006
MicrowaveSvc
  • 8973 Answers
SOURCE: Panasonic microwave 1200
This model uses an inverter to produce high voltage. That symptom is an usually indication of a problem with the inverter or a bad magnetron. I do not recommend that a person without training and experience ever work on these models. You should be able to locate a Panasonic-authorized servicer here: http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 I would mention the exact symptom when you call so the technician can bring a new inverter with him when he comes out to repair it. Might save you having it pulled into the shop. Good luck!
Posted on Sep 22, 2007
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Posted on Oct 21, 2008
MicrowaveSvc
  • 8973 Answers
SOURCE: Panasonic microwave shuts off
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Dec 25, 2008
MicrowaveSvc
  • 8973 Answers
SOURCE: Microwave turns off by itself after being on for 3 seconds
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Mar 06, 2009
Panasonic microwave began arcing and now shuts off after a few seconds
Your wave guide cover and magnitron need to be replaced.
Apr 10, 2012 | Panasonic Microwave Ovens
My NN-T994SFR Panasonic Microwave shuts off after 1 second.
My unit shuts off after about 2 seconds. It seems like it tries to go, but it sounds like it stops working and then 1 or 2 more seconds run off and it shuts down. Then you hit start again and it lights up inside and then shuts down. It's only about 2 or 3 years old.Any solutions?
Mar 05, 2010 | Panasonic Microwave Ovens
Microwave shuts down after 3 seconds
you need a new magnetron and inverter board, this is an expensive repair, unit can be replaced with panasonic parts or replaced with same size panasonic unit
Jul 17, 2009 | Thermador MBBS Microwave Oven
Dec 25, 2008 | Microwave Ovens
Turn off after 4 seconds
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Sep 09, 2008 | Panasonic NN-H664 Microwave Oven
Microwave shuts off
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Sep 02, 2008 | Panasonic Microwave Ovens
On for 2-3 seconds and shuts down with slight wire burning odor.
http://froogle.google.com is showing this model selling for as little as $100. But as a technician, I have never cared for the inverter models. As complexity increases...
Mar 21, 2007 | Panasonic NN-T774SF Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
99 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
