Send print command, paper comes out but without any print. cartridges were just replaced.
  • dbramsden May 28, 2010
    ms word and even from the internet. the printer sounds as if it is printing but the pages are blank. it is a vista machine if that helps.
  • 4,737 Answers
Please let me know the program with which you are printing, this should be a with the print settings, not with the printer. I hope you would do it so that i can help you better.
Posted on May 28, 2010
  • Lebanon Raingam
    Lebanon Raingam May 28, 2010
    Well, after the print command, follow this steps,
    On the print dialog box, select "Document" from the lists available at the "Print What" menu.
    If possible, go to printer "Properties" and select "Black ink only" and check if it helps or not. If the problem is not with the cartridge, then this will fix the problem. Do let me know after this. Good luck.
Both paper jam and ink replacement lights are flashing.
Sounds like print cartridge collided with paper. Open both covers. Try to remove paper carefully without damaging print cartridge. you may need to remove print cartridges to get paper out. Then close every thing without print cartridge in. Reopen covers reinstall print cartridge/s, hopefully, everything returns to normal. It will probably say something about going through the process of realignment.
Mar 13, 2015 | Office Equipment & Supplies
Will not print text from computer (paper feeds
PGBK cartridge was totally blocked. Deep cleaning did not resolve block. Replaced ink cartridge (large black).
Feb 07, 2010 | Canon PIXMA MP160 All-In-One Printer
Printer Prints nothing as it moves.
print a test print from the printer first without sending the command form the pc, if this works, that rule out the printer problem. then check the printer's history and see if you don't have uncompleted work on the status. if you have delete and resend. if you don't, uninstall and reinstall the printer. good luck
Aug 24, 2009 | Office Equipment & Supplies
I can send faxes but I cant recieve any.
Follow the steps given below:
1. Snap the cartridges in and out three times.
2. On the operator panel, press Options to indicate which cartridges were changed.
3. Press Start / Yes.
4. Press Options to indicate the type of cartridge you installed.
5. Press Start / Yes.
If the problem persists, do the following:
1. With the printer powered on, remove both cartridges.
2. Unplug the power cable from the back of the printer
3. With the printer disconnected, insert the cartridges and reconnect the power cable.
Apr 09, 2009 | Lexmark X125 All-In-One InkJet Printer
Having problems printing after changing ink cartridges.......scanner and copier work fine.....when send the command to print from the computer...it pulls the paper and sounds like it's printing but just...
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
PREM
Apr 06, 2009 | HP PSC 1210 All-In-One InkJet Printer
I 450 printer sends command to print but, no print on paper, paper goes through the printer as tho' it is printing but no print
Check your ink cartridges. Even with ink inside, the heads could dry up and not allow new ink to penetrate. Take a dry cloth (rag, not something you wouldn't want stained) and gently wipe it over where the ink shoots out of the cartridge. If you barely get a streak on the cloth, try dampening up the cloth and gently wiping the ink cartridge to see if it loosens up the ink flow.
If there is already plenty of fresh ink coming out of the cartridge, you might have a problem that isn't worth fixing. Repair costs compared to buying new are very similar these days.
Apr 01, 2009 | Canon i450 - Printer - color - ink-jet -...
Printing problem of my hp 2015 laser printer
It may be poor contacts on printer cartridge holder. Try to clean all electrical contacts inside depending to cartridge.
Mar 07, 2009 | Canon LBP 800 Laser Printer
Hp 2600n laserjet will not print
Check the printer if no light coming during power on. If it is coming, and no sound for rolling printer after giving any command.. or blinking light when print command is send, then check the top cover for any paper jam and firmly closed.
Clean the toner/cartridge and also internal part of printer with a blower/Vaccum cleaner.. then with a cotton or cloth.
Let me know the status after this, so I can help you out.
Oct 21, 2008 | HP Color LaserJet 2600n Printer
HP 1010
ppls. remove the cartridge and close the cartridge door hear the sound if it is not comming then change the cartridge and then check
if ur problem solve pls. remarks ur word
Jan 14, 2008 | HP LaserJet 1010 Printer
26 people viewed this question
k24674
jasbo
jasbo
