Question about Acer 22" X223w LCD Monitor
Acer X223W power supply
Have taken the monitor apart have taken the PSU to one side, but no aparent damage. Have identified all the capacitors - I think as, -
Type Voltage micro farads Tolerance
KMG 400v 68 20%
KY 35v 220 20%
KY 6.3v 1000 20%
50v 22 20%
KNB1560 275vac 0.33 10% C>=0.1 uf 1
and will replace all. Have I missed any? Which components are the voltage inverters, and what are there model numbers - just in case the capacitor fix doesn't work. Additional help will be appreciated.
I'll post disassembly instructions for the monitor shortly.
Bob
    President:
  • 1,138 Answers
The voltage inverters are the small transformers attached to a small pcb, that is connected to the backlight inverter (cold cathode).
Just in case replacing the capacitors did not work, the second thing to do is to check the backlight inverter. If there is busted light, replace this one too..the last thing to check is the high voltage ballast transformer... if one of these is burnt, it is enough to affect the stability of your supply current. It can also result to a dark portion on your screen or worst , could result to a total black screen..
If you can replace this transformer with the same value, please do so.
If this is a help to you.. please rate this solution...thanks.
Posted on May 28, 2010
Testimonial: "No separate PCB's on power supply, but your advice did make me check out the PCB further, so thank you for your advice. I will be undertaking identification of the inverters. On this model the inverters are built into the PCB, above the power supply input. "
How can I fix Acer X223W Monitor blinking?
You need to replace 5 Electrolytic capacitors on the Power Board.
Cheers
May 20, 2014 | Acer X223W Monitor
Suddenly my acer X223W lcd monitor goes blank and the light stays blue. I can barely see the images like in a 10% transparency filter. When I turn the lcd on everything is ok until the logon screen appears...
There is an "inverter" component inside the LCD monitor,
that creates all the "brightness" of the image.
That part is failing, and is becoming intermittent.
It's about a $20 part to replace, plus $50 for a qualified TV/computer technician to open the monitor, replace the part, and reassemble the monitor.
Jul 17, 2010 | Acer 22" X223w LCD Monitor
Acer monitor won`t turn on
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 24, 2010 | Acer 22" X223w LCD Monitor
My acer x223w lcd monitor is flickering. When I change the resolution to 800 x 600 it stops. I have updated the driver and tried uninstalling and reinstalling.
hi, have you checked running the monitor on all the outputs? dvi? vga? flickering is caused most times by bad connections either in the video cable, or on the video board, or power board inside the monitor. i know those monitors pretty well, i'm willing to bet if you opened up the monitor and looked at the power supply board, you would probably find worn/blown capacitors. this could very well account for the flickering. electrolytic capacitors store power for parts of the circuit that require lots of power to run. when they go bad(overheat) they pop up at the top, sometimes leak a little fluid. they are replaceable, need to be soldered in, and you can find them at most electronic stores abundantly, but you should check everything else first, the video cables(dvi,vga) before opening the monitor.
Apr 28, 2010 | Acer 22" X223w LCD Monitor
I have a x223w no sound
Spec of X223W: http://reviews.cnet.com/lcd-monitors/acer-x223wbd-lcd-display/4507-3174_7-32908354.html?tag=mncolBtm;rnav
As you can see, the monitor does not have built-in speakers. Please verify the make and model.
Apr 08, 2010 | Acer AL1917W LCD Monitor
How do i disable auto adjust on an acer x223w
restart your computer and enter setup... find the one that youve longing for and disable that
Oct 24, 2009 | Acer 22" X223w LCD Monitor
I can't open the user guide off the disc for my X223W LCD acer Monitor
Ah.
Is there any error message?
Should be an PDF file. Is Adobe Acrobat Reader installed or any alternative PDF Reader?
Download User Manual Acer X223W (zip file)
Jun 11, 2009 | Acer 22" X223w LCD Monitor
Acer x223w monitor
Hi..there,
If you wanted to be crystal clear... Try using a DVI cable if your monitor got these function. Happy Holidays!
Dec 18, 2008 | Acer 22" X223w LCD Monitor
New install Acer x223w monitor
You would only need that cable if the other end requires a VGA end. Happy Holidays
Dec 17, 2008 | Acer 22" X223w LCD Monitor
Acer 22" X223w LCD Monitor Logo
1,343 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
