Question about Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer
Dryer will not start
On button works but start button does not
  • Whirlpool Master
  • 8,220 Answers
Inside the machine is a tech sheet to help trouble shoot the problem.
Remove the bottom panel and look for it behind the motor control unit.dryer will not start - fe8e810.jpg
Use this LINK to obtain a service manual. Strongly suspect lidswitch.
Posted on May 28, 2010
The dryer is plugged in, interior light turns on, panel lights on, thing keeps madly beeping but NOT ONE BUTTON works ... not the off button, not the start button, not the temperature button... the entire...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 14, 2011 | Amana NDG6800AWW Gas Dryer
The on button does not work...dryer will not turn on but you the other buttons work...like more dry, normal and damp dry...you can choose your options but the start button does not work
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 16, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Start button doesn't work properly
Hi, You have a motor going bad. The start winding is out on it.
The motor will need replaced.
Vic
Jun 25, 2009 | Kenmore 659 Electric Dryer
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Forgot to check the thermal fuse. Now working after changing fuse.
Mar 21, 2009 | Kenmore Dryers
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
Whirlpool Duet 7.0 Cu. Ft. Capacity Plus Electric Dryer Logo
106 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
