Question about Sharp Televison & Video
Sharp LC-46D82U trying to hook up a sound bar but regardless of configuration on sound set up in TV, I still get no sound from speakers. Sound will play from speaker when it is hooked up to PS3, but not from TV. Please help?
SOURCE: No sound from speakers
i would see if you can reach over and touch.. no, lash out at just simply the most biggest floppiest jugs that have ever grazed the plains near the Hakibuki Mountain Lake where Shelly "Monster ****" Johnson and Linda "Cock Specialist" Frudmann made love to three wood elks. that will definitly help your speakers play sound. purple monkey dishwasher.
Posted on Oct 22, 2007
SOURCE: hey help to find the best picture settings fo sharp lc-46d82u
hey help to find the best picture2.gif settings fo sharp lc-46d64u
Posted on Dec 28, 2007
djnick989
  • 1067 Answers
SOURCE: sound won't play thru stereo from t.v.
take the main tv digital opti outto sterio ok on ch or from dish box to sterio on a ch
Posted on Feb 02, 2008
SOURCE: hooking up surround sound
do you need a reciever to get ceiling mounted speakers to work surround sound
Posted on Jul 13, 2008
SOURCE: Sharp Aquos speaker buzzes
In my opinion i think that the your television is messed up. so you should either return it or keep it. I had this same problem but i tried everything to fix it but i couldnt so the best is just to return it
Posted on Aug 13, 2008
How do I replace fuse?
Sharp LC46D43U - Aquos - 720p LCD HDTV Service Manual
www.manualslib.com > ... > Service manual
Flat Panel TV Sharp AQUOS LC-46D82U Operation Manual. Sharp flat ... Flat Panel TV Sharp LC46SB54U - LC - 46" LCD TV Operation Manual. Operation ...
Sep 11, 2015 | Sharp Televison & Video
I'm trying to connect external speakers to a Sharp Aquos LC-C3234U TV but not having any success. Can anyone help?
Apperently this tv has a history of sound board related problems. So if you are trying to connect external speakers because you have no sound from the set then you still will be sound-less. On the other habd if you just want more sound then I would suggest using a surround sound system which will readily connect to your set.
Oct 31, 2012 | Sharp Televison & Video
I'm trying to hook up a sharp aquos tv to an rca surround sound receiver and it won't work? any suggestions? I have tried turning off the speakers on the tv....
First thing to do is get the owner manual for each and start checking both settings and actual hookup---usually a surround system will work on all types of sets---when in doubt read the owner manuals.
If need either manual Google that model number with "manual" to try to locate it.
As far as the set goes it may require either a variable audio output source or in some cases the out to be a fixed level.
May 23, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to connect sharp HT-SB350 to Sharp LC-42D69U
You may have to use the optical cable connections. Make sure there is an optical out on the tv and on the sound bar. Get an optical cable to connect them and go to the audio setup screen and direct the sound from internal speakers to optical out.
Nov 13, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a sharp aquos model number LC 60le81oun how do I set the settings to input 1 ?? I am trying to hook up external speakers and can't get sound if I hook it up straight to the tv but will get sound if...
Input 1 is an INPUT so you can't connect external speakers there and get sound from the television, which is what you are attempting.
Your two choices are the 3.5mm minijack hole that says AUDIO OUT terminal, which is under the Ethernet Terminal and the DIGITAL AUDIO OUTPUT terminal, which is under Input 7. If your external speaker system does not have a 3.5 mm minijack input to accept the 3.5 mm minijack cable then this isn't going to work. There are cables where one end is a 3.5 mm minijack and the other end is an RCA so you can try that and it MIGHT work. Other than that the Sharp televisions are known for not carrying sound over the fiber optic cables consistently so even if you bought a fiber optic cable and connected it between the digital audio output and a speaker system or sound bar there is no 100% guarantee it'll work. It is worth a try anyways.
Feb 09, 2011 | Sharp Televison & Video
No sound from TV - Sharp TV LC-32GPIU
Check to make sure you have the speakers tuned on in the setup menu, and you are not in sap.
Sep 02, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have a Sharp LC 32D4U TV and the sound is not working.
Try unplugging the power for 2 minutes and then replug/ turn it back on. This resets the TV's motherboard.
Jan 12, 2009 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
178 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
