Question about Samsung Televison & Video
Problem with Samsung LN46A550P3FXZA.
My television is a Samsung LN46A550P3FXZA. My problem is that I get no picture and no sound. However, the (white) lamp at the bottom of the television is lit and the small red LED (I think that what you call it) constantly flashes. Also every 20+ seconds I hear clicking ''cli-Click.'' This is what it looks like: http://goo.gl/EuQg I was advised that the problem may have been the power supply board. I was able to purchase one and replace the one that was inside my tv. It worked, but after a few days while I was watching tv, the picture & sound went out and some red dots flashed on my screen and the problem of no picture, no sound, flashing red light, and the click came back.
Thinking that it was just another bad power supply, I ordered another one...but THAT didn't work.
Can someone tell me that the problem is something other then the power supply? Here is what my television looks like in the back. ( http://goo.gl/yfVU ) Could something be ruining the power supply?
Please keep in mind that I know nothing about televisions, so feel free to ''teach'' me about this if necessary.
  • Vtorch May 28, 2010
    I would just like to read a second opinion.
  • Vtorch May 29, 2010
    Would like another opinion
  • Samsung Master
  • 5,807 Answers
Hi
Vtorch,
Here are some tools that you may need :
How to test for Continuity
How to use a multimeter
of course with a service manual like one of these:
http://www.service-docs.com/store/catalogue.php?cat=279&exp=&resultpage=205&shop=1
snapshot on the page:
or these one :
SAMSUNG LN40A530P1FXZA, LN46A530P1FXZA, LN52A530P1FXZA Chassis GPR40MUS, GPR46MUS, GPR52MUS Direct Download! (Pdf, 27 MB)
Source:
http://www.service-docs.com/store/catalogue.php?cat=279&exp=&resultpage=33&shop=1
there could be other web sites for your service manual
With the tools above , there might be a chance to have it working
only with the aid of the service manual.
Since you have also replaced the power board , have a visual
check on the 1000 uF capacitor on the former board.
Check for Va and Vs
All voltages must conforms to the Service Manual Specifications
Procedures are stated on the service manual.
Although , these symptoms can be also caused by these board
But most often on the Power Board.
Hope these helps
Regards,
palaboy
Posted on May 29, 2010
  • 2 more comments
  • Rommel Cana
    Rommel Cana May 29, 2010
    Please note that if your TV denies to work ,
    it can be a result
    of working power supply!
    Power supply (SMPS in technical
    term) has 2 main functions :
    1- Producing the needed voltages and
    supplying them to different stages.
    2- Protection and monitoring
    for unwanted situations like short circuit ,
    over/under voltage
    , over current , thermal problems and ...
    In all of the
    above situations , SMPS cuts all or some of its outputs
    for
    preventing further damages.
    You can recognize this using
    some symptoms like click sounds ,
    flashing standby LED , number
    of clicks and flashes
    and some simple tests.
    Replacing the Power Board is a good idea, but it does not necessarily mean that it will work,
    due to mismatch voltages , values that are critical in operation of the Unit as a whole.
    On some sets , required voltages are printed on a sticker on the chassis.
    All are based on voltages reading and the proper oscillation of each circuit.
  • Rommel Cana
    Rommel Cana May 31, 2010
    additional troubleshooting guide :
    these troubleshooting guide is from other Samsung LCD Model , Hope these applies to
    your unit.( same principle involve ).
  • Rommel Cana
    here are some of the waveforms that you can see on the scope
  • Rommel Cana
    * FRCM: Micronas FRC chip
    Guru:
  • 374 Answers
Have you checked all the parts on the mainboard? could be somethingnot feeding right and killing the power supply??also, how is the electricity in your area? you can use a meter to check it. I have a lot of problems with power spikes where I live and its killed a dvd player a few years back.
Let me know and I will respond with any info I can.
Posted on May 28, 2010
    I do not know how to check all the part of the main board. What do I look for?
    Can you tell me, why it could be the main board and how it could damage the power supply?
    The reason I ask, is that a Samsung technician pointed out to me that the problem was the main board and he wanted to charge me a total of $500 to replace it. So (what I did was) I went and bought a main board myself online and replaced the original one. The problem still existed. So I took out the "new main" board and put back the original one. Then (under advisement) I bought a new Power Supply to replace the original one. That worked, but for about 10 hours or so then the tv went out just as I described. Thinking that I just got a bad Power Supply Board, I bought another one and the problem still exists. I even connected, at the same time, the new power supply board with the new main board and the problem still exists.
    The weather in my area is pretty good as a matter of fact the problem with my television occurred just when I was watching a tv show during a bright sunny day.
    Could the problem be anything else on the tv besides the power supply board or the main board? In case you didn't see, here is what my tv looks like in the back: click here
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To start with check the lamp if that’s working fine, you can also take the lamp cover off from the back then take the lamp out and try to reset the lamp door switch and then put the lamp back in. After this if still the issue is not resolved then check the ballast which is the power source for the lamp and if you also hear a loud whine like sound then it means that the color wheel has gone bad and needs to be replaced. If the lamp seems to be working fine then it’s the DMD Board that needs to be replaced.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith May 28, 2010
    Second opinion will be to check and replace the digital board.
When I turn on tv comes on then off with no picture.... after a few times of this I get a grainy picture.with a weird noisy... after a few times of this it comes on and the picture and sound are good
You have to check and replace the electrolytic capacitor in the power supply board of you tv. some time bad electrolytic capacitors in the power supply can cause power on problems.
check the video too
Samsung LCD TV Power Supply Repair Capacitor Replace LN46A630
www.electro-medical.blogspot.com
Oct 20, 2015 | Samsung Televison & Video
Replacing Tcon board E2268E8A0JQJ with LJ9402870E from shopjimmy didn't fix vertical line problem. on start up. Samsung LN46A550P3FXZA tv. Capacitors replaced 2 yrs ago, still look good.
It could be flat panel problem which goes when screen gets warm. slight pressure on top or bottom middle of screen may prove it when faylt appears.
Oct 19, 2015 | Samsung Televison & Video
White screen
Hello
White screen with or without sound? If you have sound maybe motherboard or panel (or Tcon module)
Best take it to the nearest authorized Samsung service.
Regards
Apr 10, 2014 | Samsung LA32D403E2 HD LCD TV
Samsung LCD TV Model LN46A550P3FXZA sound is cutting in & out 1-2 second intervals
Your video and audio (sound) signals are generated on the main board. However, for those circuits to work properly, they have to have clean and accurate power from the power supply board. The power supply boards are notorious for bad capacitors. Has your power supply been recapped? Do you see any bulging tops of any of the capacitors? If you are not familiar with capacitors, just google bulging capacitors. There are plenty of pictures on the web to show you what they look like. It is possible that the main you have has a problem. I assume you order the same exact part #?
Nov 12, 2013 | Televison & Video
I HAVE A SAMSUNG LN46A550P3FXZA LCD TELEVISION. RECENTLY WHEN I TURN IT ON I GET THE BLUE LED POWER LIGHT AND POWER ON ELECTRONIC SOUND BUT NO TV AND NO SOUND. I PUSH MENU AND STILL NOTHING. THIS...
There are many tips already on how to replace the capacitors in these units. In your case it will probably be CM852 and CM853 on the Power supply board. They should say 1000uF at 10Volts on both.
Oct 12, 2010 | Samsung Televison & Video
TV turns on and off...
My repair experience on same symptom of the Samsung A550 series, it is the main board fails, the part # you can see a sticker on the board, the format is like BN99-99999C.
May 15, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Picture is black and white
Does it sound like thin grinding noise?
The color wheel is very common problem. Color wheel for this model is about $100 to $150 plus labor.
Nour BMI
Feb 18, 2010 | Samsung HC-P4752W 47" Rear Projection...
Problem turn on picture few sec. no picture only clear white and sound
I had this problem and replaced the bulb. I have not had the problem since.
Nov 22, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
900 people viewed this question
Henry  Thomas
Henry Thomas
