Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
NOT DISPENSING THE RED THING ON TOP IS NOT GOING ROUND AND ROUND. NOT DISPENSING WATER AND SOLUTION.
    President:
  • 1,673 Answers
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines.
Posted on Apr 28, 2008
  • 25 Answers
I had exactly the same problem with my five-year old my Bissell 7920, and it's probably a broken pump belt.  See page 19 of your instruction manual for how to replace.  The Bissel ProHeat belt accessory pack costs $3.99 and you get a pump belt and a brush belt.  Since you have to first remove the brush belt to get to the pump belt, you might as well replace both. The first time I did this it took me 15 minutes, but now that I know the drill, doing a belt replacement would take about 3 minutes.
Posted on Apr 14, 2008
SOURCE:
DC18 won't stan up
here is dc18 foot repair video
Nov 22, 2012 | Dyson DC14 All Floors Upright Vacuum...
Water not dispensing
Check the release valve on bottom of clean water reservoir unscrew if needed, once again if your not sure run hot water in the solution tank through the system to help remove old soap residue and always run hot water through to prevent future problems after cleaning carpet and storing.steve
Jun 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Machine will not dispense water even though reservoir is full. Soap is not dispensing either.
check the spray nozzles on top of the brushroll. these often clog. If those are clear could most likely be the pump as they fail frequently.
Jan 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Proheat wont spray soap with uniformity
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhkl
Sep 10, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
NOT DISPENSING
Apr 28, 2008 | Bissell 1699 ProHeat Clear View Upright...
Flow Indicator Not Moving, Not Dispensing Anything
Does water squiret out of the hose, if it does, then check the heater inside the handle to see if it is clogged where the 2 water lines hook to it. The other reason, you may ghave a bad pump. But check the back edge to make sure the top isn't coming loose from the base. Check the bottom of the tank to be sure round seal is on the tank on the cap and valve. Sometimes they come off and wind up in the hole.
Mar 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Have a hoover steam cleaner F5837-900 model
First off, check the dirty water tank, check the round filter on the bottom of the lid to make sure there is a gap and pushed all of the way up, then make sure that the lid is locked onto the tank. Check the bottom of the tank, push in the plunge to make sure water comes out freely. There is a round seal where the water tank sits, make sure it is ok. There is a diapham that the tank sits on could be bad, or the tube running down the inside of the handle is crimped. Could have a bad pump. but they don't go bad very often.
Nov 04, 2007 | Hoover F5906-900 Upright Steam Vacuum
Not dispensing water and no suction
I'm assuming the belts are OK.... Your heater is clogged. Unplug the machine and let it sit for 30 minutes. Take the handle apart, there will be a 4 inch by 8 inch metal box inside. This is the heater. Remember I said to let the machine sit for 30 minutes? If you didn't, the heater may be EXTREMELY hot!! Disconnect the two hoses going into it, and clean the metal pieces out (that the hoses connected to) with a needle or very small drill bit. You may want to remove the 6 or 8 screws holeding the heater together and remove the cover to clean it out. Reassemble and fill both tanks with VERY hot water ONLY and run the machine to rinse the entire system.
To prevent future reoccurences... use only Bissell extraction shampoos. Never put anything in the detergent tank except shampoo. (And only water in the water tank) Mixing chemicals with anything else turns the water/detergent mix to sludge. Also, when finished shampooing, put ONLY water in both tanks, and run the machine until one of the tanks run out of solution. Doing this rinses the hose lines out and prevents hardening of the solution in the heater ports.
I've fixed these machine for years. No dispensing is almost always the heater clogged.
Sep 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
129 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
