It won't spin or drain. :-(
Um, it's my grandma's washer, so, I don't really know anything about it, but, it will was clothes, but, it just kind of quits after that. Like it won't spin or drain.
  • 166 Answers
Check the lid switch first - depending on the brand - some machines won't spin or drain if it thinks the lid is open. open the lid and take a small screw driver driver, press up and down on the switch. you should be able to hear it click. if it is not clicking then the lid switch is probaly bad.
some machines will drain with the lid open but not spin. if this is the case with your machine you could have other problems such as timer or motor.
Posted on May 28, 2010
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
I have a GE Adoration WHDRE526E1WW top load washer. It drains and hits spin but will not spin. Lid switch seems to work. When tested the motor kicks on but will not turn the tub. Few times I manually spun...
It really sounds like the belt. You say it's in good shape but if it's loose or shiny from not having proper tension it wont have enough friction between the belt and pulley to actually work. If you've ever tried to move the drum when its full of clothes and water you know how much force id needed to function. Double check that belt tension and working surface.
Aug 13, 2017 | General Electric Washing Machines
F21keeps flashing.clothes won't spin.f21 still flashing on all cycles.
Hello again Chris,
Thank you for replying with the model number. It sounds like the pump may have become clogged in the washer pump filter.
I would first suggest you have a look at the pump yourself unless you don`t feel comfortable doing so, then calling a service tech might be the best avenue.
Here`s how to inspect it...yours may differ slightly, but if it is indeed a bosch clasixx6 1200...these instructions will apply.
1) **Turn off the power or unplug the cord from the dryer or wall...whichever applies to your set-up...safety first**
2) Water removal...remove toe panel. There you will find a small hose with a plug in the end for draining the pump.
3) Now bleed pump drain...A shallow pan is handy for this step.
3) remove pump filter, but be careful if you don't have a shop-vac or a shallow pan and towels you may get wet...
*Once you`ve reached this point you may have trouble removing the filter if it is really plugged up with debris. You might have to wiggle it back and forth as you twist and pull.
4) When you get the filter out, visually inspect inside the pump thoroughly with a flashlight and clean it out really well. It won`t take much to prevent these from draining. i.e. a penny, hair pin, buttons etc.
Let me know if you found anything in the pump and how you make out after that.
If you removed any obstruction, simply reassemble the unit making sure the filter is screwed in tight, unplug the unit for approx. 20 mins (you may have accomplished this in the time allowed to clean the pump so it may sound redundant, omit if so) run a quick rinse cycle to test for leaks before putting the toe panel back on and you should be good to go...save for any leaks.
There are other possible factors like a pump motor, that can prevent the unit from draining or spinning out items properly, but we`ll cross that bridge when and if we get there.
Thank you for choosing FixYa, keep me posted on your situation.
Regards,
Macmarkus :)
Oct 25, 2011 | Bosch Classixx WFL 2066 Front Load Washer
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
Machine won't go in to spin and cloth stay wet
Hi alvism,
The drain pump may have something clogging it up, or obstructing the pump impeller, easy fix, see my Tip below:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards d')
* If you found this solution helpful, please rate it.
Jul 21, 2011 | Malber P21 Front Load Washer
My washer will not spin, it sounds like it's trying to spin but it won't spin and if i turn the barrell by hand it spins so it's not frozen or anything. Any suggestions?
Hi mwilczewsk,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
Jul 18, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a Whirlpool WFC7500V Front Load Washer and after the load is done the clothes are still soaking wet, is there a step i am missing why are the clothes still really wet. Do i need to drain or is the...
What spin cycle are you using? Try a faster spin option. (The wrinkle release setting uses more water and a lower spin speed.)
Try putting fewer items in a load in the futute and make sure it isn't unbalanced. (One really heavy item could imbalance the load and shift the spin efficiency.) Redistribute the clothes and run a Drain/Spin cycle.
Make sure to use HE detergent (don't use more than the recommended amount of detergent).
The other issue to check is if the machine is draining properly. Check that the drain hose isn't clogged. Also check the voltage at the washer - low voltage will result in a slower spin cycle. To correct this, you probably will want to call an electrician.
I hope this helps.
May 05, 2011 | Whirlpool Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Washer problem with a Kenmore Elite HE 3 T model
are you useing the right kind of soap....HE detergent only make sure the bottle says He on it. If you are not useing he detergent this will cause drain problems and make the washer spin longer. check it out and let me know if this helps. If not I have a different solution for you
Jun 03, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
