Hitachi DV-RV8500E(UK) DVD Recorder won't play DVD Region 0
Hello Folks!
I have been given a set of pre-recorded discs - the description says Region 0 - Plays Worldwide. Also says that they are format free DVD-R - plays in both PAL and NTSC DVD players. I was told they would play in anything.
So why won't they play in my Hitachi DV-RV8500E (UK) player .....? Do I have to manually set up/change anything?
Can anybody help please?
4 Suggested Answers
SOURCE:
SOURCE: Playing PAL system dvds
Turn unit power on
with dvd draw closed and with no disc
press 9735
hidden menu appears
select REGION 0
exit setup
for multi zone compatibility and enjoy...
Posted on Dec 05, 2007
  • 4 Answers
SOURCE: Curtis DVD8723UK Wrong Region Problem
This may be of no help to anyone but I have the same problem and I have spoken to Curtis Support today, they say there is no fix, its a fault in the machine and must be returned to the vendor as they have no service network in the UK. I bought mine with a 90 day guarantee off Ebay and it went faulty after 100 days but probably only used for 3 days so I'm stuffed!!!
Posted on Jun 09, 2008
SOURCE: dvd recorder will not play
after power on display shown pleace wait & no any play the function so plz give me any solution for this foult
Model NO: DV -RV8500E
THANKS
DYAL ELECTRONICS
INDIA ( PUNJAB)
Posted on Nov 23, 2010
Region 0 DVD's will not play
I understand that what you call 'region free' is Zero! Therefore this discs you are trying are not zero. Try inputing different numbers to get them to play.
Region Free is a myth!
Dec 08, 2009 | Electronics - Others
Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Aug 01, 2007 | NAD C541 CD Player
Dvd recorder won't play disc
your recorder will normally give you 5 changes at different regions, and on the last region change that is the one that it stays on, although if you you have never changed the region go to> my computer>right click on your dvd drive>properties and on the hardware tab, your hard drive and dvd drive will show, highlight your dvd drive and click properties and click the dvd regions tab and look at the region to see wot its set at, if you still have 5 changes, it should be set at your region one, if there are no changes left you need to search and download a region free dvd programme to allow any region dvd to be played programme
Jun 10, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
All region code for Medion DVD recorder MD84100
Found on another board, tried and it worked on my Medion
P70002 / MD84100 DVD recorder:
Turn on DVD recorder
Press HOME on remote
Go to SETUP in Easy Menu
Move down to padlock icon
Press 0 seven times
Message appears:
Congratulations!
Region Change Free!
YES (press ENTER)
It now plays US and UK as well as Australian (in my case).
Dec 31, 2008 | Electronics - Others
Dvd recorder will not play any discs model dv-rv8500e(uk)
THANKS
DYAL ELECTRONICS
INDIA ( PUNJAB)
Oct 06, 2008 | Hitachi Televison & Video
Live in region 2 want to play region 1
To unlock all regions:
1.Press Setup on remote
2.Scroll down to Lock icon
3.Press 0000000
4.Regionfree!!!
Jay
Aug 26, 2008 | LG RH1999H DVD Recorder/HDD Recorder
Need to play region 1 DVD in region 2
I just got a RH387H in Hong Kong, region 3, but the above method doesn't work, this model has slightly different icon, no "lock" icon, I tried in other similar location but no effect, hopefully someone will provide a method.
ipw
Jun 28, 2008 | LG RH1999H DVD Recorder/HDD Recorder
LG RH1999H DVD HDD Recorder
1. Turn machine on
2. Use remote to open disc tray
3. Use remote to go to setup area of menu (Home - Left) and scroll down to 'Lock' symbol
4. Press 0 seven times
Oct 29, 2007 | LG RH1999H DVD Recorder/HDD Recorder
Instruction Manual for RV8500E
I have a manual. I can scan it and send it to you via email.
Aug 18, 2007 | Hitachi DV-RX5000U DVD Recorder
I have recorded (on to dvd-rw) my old VHS tapes. They won't play on computer
The PC requires a compatible DVD player software! What are you trying to play the DVD with?
Sep 28, 2017 | Hitachi DV-RX5000U DVD Recorder
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Ekse
