Question about Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television
Tv stays on for awile and then turns itself off
Diag code flashes 2 then 3
  • 116 Answers
23 is horizontal deflection failure. The problem may be the high voltage power supply or bad connection(s) in the yoke circuit.
Posted on May 28, 2010
ABS light comes on... but no noticble degradation in operation etc.
Most likely a wheel speed sensor, hopefully... The only thing that will change when the ABS light is on is that the ABS will not function as long as the indicator is on. I hope this info helps.
When the airbag system is in functioning condition, the airbag warning light will remain on for about 7 seconds and go out when the ignition switch is set to ON .
If there is any malfunction, the airbag warning light will either stay on or off continuously. In such cases, perform on-board diagnostic in accordance with the specified procedure to determine trouble codes.
  1. Turn ignition switch ON (with engine OFF ).
85091723
  1. Connect DIAG. terminal to No.2 terminal of diagnosis connector located inside lower cover.
  2. Check in accordance with the trouble code indicated by the AIRBAG warning light, and record the trouble codes.
  3. Turn the ignition switch "OFF " and remove the DIAG. terminal from No.2 terminal of diagnosis connector.
85091724
HOW TO READ TROUBLE CODES
The ABS lamp flashes a code corresponding to the faulty parts.
The long segment (1.2 secs on) indicates a "ten", and the short segment (0.3 secs on) indicates a "one".
NOTE: This is the only information provided by the manufacturer for clearing diagnostic trouble codes.
97511505
CLEAR MEMORY
After eliminating problem as per trouble code, clear memory as follows:
Make sure ignition switch is ON (and engine off). Connect one DIAG. terminal (1) on diagnosis connector (2) terminal No.1.
where warning light is flashing, connect the other DIAG. terminal (3) on terminal No. 2 for at least three seconds . After memory is cleared, normal warning light flashing rate resumes. (Warning light flashes every 0.6 seconds (ON-OFF operation.) Memory cannot be cleared if any problem exists.
After clear memory and then DIAG. terminals (1) and (3), extract from diagnosis connector (2)
Jul 27, 2011 | 1999 Subaru Legacy
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
Green light on front of tv flashes. Screen stays black
The flashing light indicates protection mode and is a generic error code.
Google for a service manual and read the error code may help.
Protection mode = the tv detects a problem and is preventing itself from turning on and damaging other components.
for more info and detail of likely causes post your tv model number.
for parts check
http://rns-systems.com/
Oct 16, 2009 | Apex Digital Televison & Video
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Turns off/ on by itself model 27v412t
well my tv was doing the same thing my prob was the buton bord.the ezyest way to check it was to take the back off and find the wires that come from the boton bord the plug the tv in and turn the tv on wile its on unplug the boton bord wires if the tv stays on that is probly your prob the bord dont cost much I found a site on here that has them for under $5.remember to be carefull when checking it out tv car be very dangerus.I found that if I beat on my buton bord alittel it would work for awile hope this helps
Oct 26, 2007 | RCA 27V520T 27" TV
Tv won't stay on
My tv is a Toshiba. It comes on for a second and then goes off by itself. I use the remote and the power button on tv and the same thing happens. Is there a solution to this?
Jan 24, 2006 | RCA F27450 27" TV
Mitsubishi WS-65311 65" Rear Projection HDTV-Ready Television Logo
136 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
