Question about Canon EOS Rebel T2 with 28-90 lens 35mm Film Camera
Timer? how do u get the timer on?
    Problem Solver:
  • 15 Answers
There is a small round pushbutton on the top of the camera marked with a clock icon. Pressing this button engages self-timer mode. When the camera is in this mode pressing the shutter release starts a 10 second countdown. The camera will beep during the countdown if the beeper is enabled and the top-deck LCD displays the number of seconds left. Two seconds before the shot the camera will beep faster and the red-eye reduction lamp on the front of the camera will flash to warn you that the photo is about to be taken. You can cancel the timer at any point by switching the camera to another mode (or turning it off) before the picture is shot.
Posted on Apr 14, 2008
E10694 timer
Scroll down and identify timer:
E10694 is imaginary number applied to all sorts of intermatic timers sold by folks who want their timer to appear unique and rare on internet. It has been used for T101 120V timer, T104 240v timer, T170 series timer with day-skipper, and also with 'cycle' timers... except all timers with rotating dial could be called cycle timers, but 'cycle timers' are normally timers with less than 24 hour rotation period.
Gene h
Mar 24, 2014 | Intermatic Hardware & Accessories
The white wire has come off of the timer. There are two possible spots open on the timer. Which one do I use?
1) Copy following links to help identify timer:
2) Add a comment and at least give us a hint about your timer.
Is this a box timer, or in-wall timer, sprinkler timer, spa timer, pool timer, low voltage power pack, plug-in timer, delay timer, cycle timer, digital timer, analog timer... etc.
Describe timer in detail.
What voltage are you using? 120, 208, 230, 240, 277, 480, 600 etc.
What does timer control?
Is this for a nuclear power plant, or kitchen light bulb, or 3-phase motor, refrigerator defrost, freezer defrost, swimming pool heater, etc.
Feb 19, 2013 | Hardware & Accessories
How do I charge timex digital timer 12/874
Copy following link to identify timer and download possible manual:
2) Usually you plug timer into outlet for 1/2 hour to charge internal non-replaceable battery. Other timers have replaceable battery. Always reset timer before programming. If timer display does not show with charged, or new, battery, then try timer on different outlet, and/or replace timer.
3) If timer does not show on link above, add comment and include photo or clear description of timer.
Dec 05, 2012 | Timex EASY TO SET TIMER BY TIMEX
I need operating instructions for a wylex timer
There is no instruction manual for Wylex timers.
However the Wylex sell sheet appears to show generic din rail mounted timers.
Since these timers are made by other companies, and then sold by various companies, and then the models change rapidly, the best course of action is as follows:
1) Re-post question with clear and detailed description of timer buttons, and say what the timer controls.
2) Google image search for 1 and 2 channel timers to find same-similar timer.
3) Most timers have similar programming steps and once you find timer with same buttons, then that timer manual can be used to program unidentified timer.
4) Open following links to find din-rail timers that might match:
Jun 23, 2012 | Hardware & Accessories
Timer that has a 20 minutes interval up to 1 hour
More information is needed.
For example, a) what voltage timer is needed, b) what Load are you controlling and c) how does timer mount?
Easiest solution is 60 minute repeat cycle timer.
Timer knobs are adjusted, or the timer dial rotates once per hour and 20 minute timing cycle repeats each hour. The cycle repeats 24-7-365.
If you want the cycle to operate certain hours of the day, another 24 hour timer can be installed in-line.
1) Tork 8600 cycle timer, or Tork ACT percent cycle timer
2) Intermatic CT2000 percent cycle timer, C8800 cycle timer
3) For din-rail mount, Intermatic Talento 121 cycle timer
Add a comment
Oct 01, 2011 | Hardware & Accessories
How do I set in Automatic mode, seems to only work manually since loss of power?
1) Power outage is major cause of timer failure. Power surge occurs when power is restored, and electronics are susceptible to surge. This includes water softerer, treadmill, electronic water heater, timers, etc.
Timers should be unplugged when power goes off.
Of all timers on market today, only one instruction manual says to unplug timer with power loss. However many people write fixya saying their timer, and electronic water heater control etc stopped functioning after power loss. Probably other products have same problem, but I work with timers and water heaters and see only that slice of the world.
2) Question posted under Woods 59377.
Several timers look identical or similar.
59377 timer has non-replaceable rechargeable battery, some similar timers have AA battery.
If timer has battery, change battery.
Then reset timer to restore functionality. Press reset button for a few seconds with paper clip.
3) If timer function does not restore after reset, then timer is bad.
Buy similar timer at Lowes or Target, and return defective timer in new package.
4) If function is restored, then re-program timer
Open following link for timer instructions showing how to reset timer and re-program timer:
Sep 09, 2011 | Woods Industries 59377 Indoor Digital...
Timer runs constantly. Runs cycle then shuts off and shortly later restaRTS.
Posted under GE 15069 countdown timer.
Unknown if this is new timer that is wired wrong or if load has interference, or existing timer that stopped working.
If new timer, then check wiring: This timer is for single-pole application only and requires neutral wire.
Then check for line interference by moving timer to different Load, for example ordinary incandescent light bulb.
Make sure slide switch is set to Timer.
Slide switch works as ordinary on-off switch, so see if slide switch works correctly.
If timer stopped working:
Feel timer if it is warm to touch indicating overload or internal timer short.
Timer is rated for 1/2 HP at 120Volts. Check nameplate on motor for HP.
Check for short in line by temporarily replacing timer with on-off switch, and check wire nut connections.
Move timer to different Load, for example ordinary incandescent light bulb.
If timer has gone bad, then return it to Home Depot and swap for different timer.
If load interference is problem, then buy mechanical spring-type countdown timer like Intermatic FD60
Aug 03, 2011 | GE 60minute Automatic ShutOff Timer Switch...
How to set a Noma outdoor timer
You posted under Noma timer.
Noma timers are one of the names used for Woods timers.
You posted under 6-button outdoor timer.
Here is a link to 6 button outdoor Woods timer, to help identify your timer.
If this is not your timer, scroll through page to identify timer.
Manuals are posted with each timer, add a comment with specific timer number if you want me to write out steps from the manual once you identify the timer.
geno_3245_173.jpg 6 button outdoor 7-day timer
geno_3245_174.jpg 6 button outdoor Week timer
Dec 10, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do I set it and can I use it indoors?
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
To use timer outdoors.
Plug timer into wall.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
Dec 09, 2010 | Intermatic Outdoor Timer/Photo Control...
We need clear instructions for setting the timer
Woods makes several outdoor timers:
Image that shows with this post is Woods model #49647.
Below are instructions for #49647 timer.
If your timer is different, add a comment with model number and I'll post instructions for that timer.
Woods model #49647 is outdoor timer with photoelectric control that turns timer ON at dusk.
There are 4 possible settings that show on dial.
Rotate dial to make timer selection.
OFF = timer is OFF full-time until you change dial.
ON = timer is ON full-time until you change dial.
Dusk-Dawn = timer turns ON at dusk and OFF at dawn
2, 4, 6, 8 hours = timer turns ON at dusk, and turns OFF 2, 4, 6, or 8 hours later.
Nov 26, 2010 | Woods Outdoor Lighting Timer
Canon EOS Rebel T2 with 28-90 lens 35mm Film Camera Logo
105 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
