Question about Danze 5 1/2'' Wall Mount Tub Spout with Diverter - D606225
How to replace a cartridge in a tub faucet?
Tub 5100-13BN faucet
cartridge clogged. How do you remove the old to replace? Is a special tool needed? Do I need a plumber or can I order the part and install myself?
    Scholar:
  • 122 Answers
These spouts are screwed on... sometimes they are tight.
to remove, turn counter clockwise. reinstall a new one, a little teflon tape and screw back on clockwise. do not over tighten! you want the spout to be snug by hand tightening, do not use a wrench!
Posted on Aug 06, 2010
Hot water tap leaking what can i do
That is a simple fix - you need to replace the cartridge that is in the faucet handle. however, each manufacturer is different. NOTE sometimes you need a specially designed removal and puller tool. I found this out the hard way. I had a Moen faucet and needed a collar removing tool and a cartridge puller in order to remove the cartridge.
Google
May 01, 2017 | Water Water Heaters
Moen Eva two handle lavatory faucet - hot water leak from faucet. Old cartridge removed (had to get a special tool to remove it), new cartridge installed, and leak fixed. Four days later, leak is back...
Hot water side of most faucets give most problems try heating with hairdryer pryor to trying to remove,contact moen tell them of your situation they will more than likely send you a new cartridge free of charge if you raise enough stink about just replacing cartridge.
Jun 08, 2011 | Moen T943/MO4999 Eva Deck Mount Whirlpool...
I have a moen single handle tub and shower faucet took out the clip and pulled but the stem will not come out what esle is holding it
You need to purchase a replacement cartridge before trying to remove a defective Moen cartridge. Always buy genuine Moen. If your valve turns on and off with a pull/push action you need part number 1225B, otherwise you need part number 1222. The 1200 cartridge will work in lieu of the 1225B but is more expensive and no longer used in Moen valves. There is a tool that comes with these cartridges which looks a bit like a white plastic cap.with notches on one end and a square head on the other.
Once the clip has been removed the only thing keeping the cartridge in the vslve is old sticky lubricant. Place the tool over the cartridge end and rotate as necessary until the notches are fully engaged and it no longer rotates. Using pliers or a wrench over the squared end, twist the tool back and forth several times. Remove the tool, and using pliers, pull the old cartridge out. Put the tool on the replacement part and insert it back into the valve. Lightly tap on the squared end to make sure the new part is completely seated, then use the squared end again to turn the cartridge as necessary to align for the clip to be reinstalled.
Nov 06, 2010 | Moen & One Handle Tub & Shower Faucet
Moen bathroom faucet leaks from the cartridge. Unable to remove the cartridge. Do I need a special tool?
Usually not a special tool needed. Moen will provide FREE replacements for you, call them up and they will ship to your door, free.
Sep 28, 2010 | Moen & Replacement Cartridge
How remove the broken bathtub cartridge(Moen 1222)
The exact procedure to remove the old cartridge is with a plastic removal tool.With replacement cartridge you have to buy this plastic removal tool.Also there is same metal removal tool available.With the help of this tool you can easily remove the old cartridge.
Moen Cartridge Replacement Instructions
Moen shower faucet cartridge replacement is a project that will take some time to get done right. When is it time to replace a Moen cartridge? If you are like most people, you won't want to replace your old Moen cartridge until your old cartridge is starting to show its age.
Replacement is necessary, usually, once the old faucet starts to drip. Thankfully Moen faucet cartridge replacement is not difficult. However, if you are uncomfortable with doing the repair yourself, do not hesitate to call a professional plumber to do the job for you. This will guarantee that the job is done right.
If you follow these Moen faucet cartridge replacement instructions you will be able to replace your old cartridge by yourself. First of all, as with any plumbing repair, make sure that the water supply is turned off. Open the faucet to remove water pressure from the lines and let the remaining water drain from the pipes. You will then need to remove the faucet's handle by removing the decorative cover and removing the retaining screw. This will allow you to remove the handle.
Once the handle has been removed, work on releasing the splash plate from the wall. Generally there will be one or two screws to remove and the plate should release from the wall easily. From here the process begins to get a little trickier. Insert a shower stem socket onto the faucet valve's retaining nut and release the nut. Your Moen cartridge removal will be complete once you grab the cartridge with a pair of pliers and pull straight out to remove the old cartridge.
Clean any surfaces that you have access to and replace with the new cartridge. Follow all of the previous instructions in reverse order to re-assemble your shower faucet. Check to make sure that all the connections are tight before turning the water back on and testing the system out.
Now in your case the broken/cracked while removing the old cartridge so try this procedure carefully to get the stuck -up old cartridge out.
TAPPING the Threads into the Cartridge:
Carefully  hold one tab on the cartridge tight against the brass lip on the faucet body with needle nose and try  to drive the 1/2" tap into the smaller bore of the cartridge. It will take  about 15 minutes to slowly work the tap in all the way (maybe 3 turns?). Then  back out the tap... remove needle nose. [remember to turn the tap 1/4 turn back, for each 1/2 turn forward ... this clears the metal particles from the tap and makes the next 1/2 turn forward go smoother].
Next, assemble a 1/2" x 4" threaded rod, so it had threads all the way to the two jam nuts on one end)... If you use a bolt, get one with threads all the way up to the head. you may find it hard to find - so try a carriage bolt and spin a nut all the way up to the head .... continue:
next on the bolt goes a 1/2 nut (this is the "jacking nut") and a flat washer so the jacking nut can spin easily against the next piece, a 1/2 drive socket (7/8" ) with the square hole toward the washer and jam nuts ( bolt head ).
The open end of the socket faces the brass body of faucet and rests on the round brass lip... having the same inside diameter. This allows a space for the cartridge to be pulled into ( a cavity). Thread the bolt into the tapped cartridge and snug it up so the 7/8" socket is aligned with and resting against the brass body. If the cartridge spins smooth, the threaded rod is GREAT. You can just work with the 1/2" rod and use needle nose (or similar) to stop the  cartridge from spinning, to get the rod threaded into the tapped threads in the cartridge... then, slip on the socket, washer and nuts.
Now snug it up tighter. Check socket alignment. Then begin turning the jacking nut ( the "extra" nut) until it contacts the flat washer and 7/8" socket. Now, as you continue to tighten the jacking nut, it will pull the 1/2 bolt (threaded rod) away from the faucet... and the cartridge will come along too. [You have to prevent the 1/2 rod from spinning while tightening the jacking nut. put a wrench on the bolt head.]
This procedure is bit lengthy and requires some appropriate tools,but this will release the stuck cartridge out.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 05, 2010 | Moen & One Handle Tub & Shower Faucet
Replace old cartridge
They actualy make a tool to help remove the cartridge as they can be stubborn. If you have allready removed the clip, then you may want to use a crescent wrench and adjust it so it lines up with the ears on the cartridge, then begin rotating the cartridge to loosen it up. Then you can try to pull it out again. Sometimes if you can turn it while pulling will help. I hope this helps. If so please vote.
May 23, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower faucet can't get cylinder out
New moen cartridges for tub/showers come with a handy white plastic tool to aid in old cartridge removal. One end is squared off for a wrench, the other is slotted to place over the old cartridge in the wall after the clip has been removed. Place onto cartridge and use a wrench to turn several times back and forth. Remove , grab the stem with pliers and give a tug. You want either service part #1225B (pull/push to turn on) or #1222 (just turn knob counterclockwise to turn on. Get the replacement before you proceed.
May 06, 2010 | Moen & Bayhill& Single Handle Tub & Shower...
Removal of moen #1248 cartridge
That was exactly the solution I needed for my Jacuzi bath tub with the two handle faucet. The use of the screw in the top of the cartridge was needed to be able to get a strong enough hold on the cartridge stem. Mine is all recessed about 2 1/2 inches so I grabbed the screw head and stem with long nose pliers, and then clamped down on the pliers with a set of adjustable pliers, and then used a 1/2 block of wood as a lever to get pressure on. That got the cartridge to pop out! Thanks!
Mar 27, 2010 | Moen & Replacement Cartridge
The hot water is not working at our tub. we had the water turned off for a couple months and I believe sediment is in the line. The hot water works everywhere except at this one tub. i need instructions on...
Your problem is most likely a bad cartridge.#1 turn off water in house #2 remove handle #3 you will see a horseshoe shaped clip that holds in cartridge remove clip and try to pull cartridge straight out you may need to purchase a moen cartridge removal tool for easier removal and install new cartridge and replace horseclip
Nov 14, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Vestige 7065 how do i remove cartridgi.handle is off
Note: You can get a cartridge for FREE from the hardware store if you have the old cartridge to trade them. The problem is that Moen cartridges are water-sealed into place and you need a special tool to break that water seal. The special tool (just a tiny piece of specifically shaped plastic, really) comes, you guessed it - with the new cartridge.
Two possible solutions: a) bite the bullet and just buy the cartridge (~$25) or buy a Moen cartridge puller, usually available from the hardware store as well for about the same price. Ask, they might even lend you one.
The point of whichever tool you end up with is to rotate the cartridge itself inside the faucet body to break the water seal so that you can pull it out with a set of pliers. There will be a retaining clip to pull out as well. Once the water seal is broken and the retaining clip is slid out, the cartridge will pull straight out.
www.plumbingpartsdepot.com/moen7300.gif
http://img2.timeinc.net/toh/i/a/plumbing/faucets-toilets-07.jpg
Good Luck.
Sep 04, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Danze 5 1/2'' Wall Mount Tub Spout with Diverter - D606225 Logo
135 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
