Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
We are trying to remove the wheels and tines from the craftsman roto tiller in order to replace a broken drive chain. We are having a very difficult time getting the wheels and tines off. Any suggestions?
    Problem Solver:
  • 6 Answers
There should be a cotter pin or pin holding a large washer once you have removed these then you have to get the wheel to slide off the axle it has a keyway on it.i have taken a hammer and hit one side of the tire on the backside then turn the tire half way round and hit the tire from the backside and walk the wheel off the axle.if the axle is rusty shoot wd-40 around the axle and wheel .the wheel should slide back on as you line up the keyway when putting them back on.if your going after the chain the tines will have to come off too and the chain box split
Posted on May 28, 2010
  • 3 Answers
Worst case scenario, if wheel hub is seized on axle you can try heating up hub sleeve with small butane torch, enough to cause hub sleeve to expand and drive off with hammer on back side of hub while still hot, or grab tire and try to turn on axle to un seize it, it will get tight as it cools so you have to work at it.
Posted on Apr 21, 2012
Gilson roto tiller model 51082
Something in the wheels drive is jammed preventing them from turning. That is why the turning belt starts to smoke when it is turning but cannot unstick the wheels. Need to unstick them for unit to work.
Apr 01, 2016 | WI Gilson Bycast Club Chair
How to fix broken chain on a 65 ortt rear tine husqvarna tiller
If you are in a hurray a cutting torch , hammer and chisel method might work. other wise flip the thing over remove the tines split the housing and remove the chain
Aug 26, 2014 | Garden
My craftsman rear tine tiller m# 917293202 will not move tines will move but wheels will not
hello, upon inspection of the parts brake down looks like you have broken the drive chain inside of the trans to drive the wheels,there is no mencion if the belt and pulley turns and the wheels don't,did you check the belt and pulley?hope this helps,oh bring it over abd i will repair it,
Feb 12, 2012 | Craftsman Garden
I have a craftsman 17" 5.5 rear tine tiller chain
Go to sears.com. at top of page about center of page find parts. put in model #. It will give you a breakdown of the whole tiller.
R.G.S.
Mar 22, 2011 | Craftsman Garden
I have a Craftsman 17" rear tine tiller with
check to see if there is a snap ring on the shaft or a roll pin.
Feb 23, 2011 | Craftsman Garden
I have a craftsman 19 in dual rotating tines, rear tine tiller. # 917-293493. In mid till, the tines quit turning. Won't shift into any gear. Wheels are locked. Any ideas?????
It is going to be a transmission issue. You can try with the engine off, turning the trans pully by hand in the opposite direction that the motor was turning it.
Some gears in the trans got crossed up and locked.
Aug 12, 2009 | Craftsman Rear Mount Tiller
Tiller will go into every gear except forward/till..whats going on?
check the shift lever where it goes into the transmission. a lot of times, the lever will get sloppy where the roll pin goes through and it won't shift into till. sometimes you can drive the roll pin out, pull off the lever and peen the holes over. sometimes you have to drill the lever and shaft and put in a snug fitting bolt and nut. OR, the chain driving the tines is broken, and that means a new transmission. hope it's simple
Jul 19, 2009 | Craftsman 8.50 Torque Rating Dual...
I have power to the tines but the wheels are locked
Tines only spin in the T position.with cutch engaged.If thats not it split the case and check to see the shift fork operating properly. Or that chains are not broke. NOTE This is a serious job!!!
May 11, 2009 | Craftsman 8.50 Torque Rating Dual...
Tiller does not till
broken tiller belt or drive chain.
Oct 28, 2008 | Craftsman 8.50 Torque Rating Dual...
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
313 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
