Question about Klein Tools Klein Wiggy Solenoid Voltage Tester
Old (1950's vintage) came apart would like
Old (1950's vintage) Wigginton Voltage Tester, Wiggy, came apart would like diagram to reassemble
Where is the fuse panel on a 1950 Ford Custom ?
Ho, what does it have, like 4 fuses? They sure didn't have use for many back in 1950. I think they might be up under the dash, maybe to the side, probably on the driver's side. Or also check on the firewall under the hood. You could find some vintage car sites with an active group of enthusiasts real easy, any of those people who own old cars could sure give you the facts and then some. How long have you owned this car? I remember that car style, a high-school friend owned a 1949 ford 2-door. That was in 1961 and '62.
Dec 09, 2015 | Ford Cars & Trucks
Cooling system capacity
First, check with either a volt meter or a circuit tester light rated for the voltage of your cooler if you have voltage to the compressor. Your problem may be a faulty temperature control thermostat or a compressor.
I hope this helps you, good luck!
Mar 26, 2014 | Vintage Keeper Furniture
The switch to our 1959 came apart and we have the parts but need to know what order to put them back together
I am not aware of an exploded view of that switch. Most people buy a new one for $25 instead of trying to repair it.
It was used from 1950 to 1960 on most Ford Lincoln and Mercury models.
Jul 13, 2012 | Ford Cars & Trucks
I need an instruction manual for a Klein 69100 voltage tester
Try
mauritron2.com
They have a good range of
Technical Repair Service Manuals
and
Owners User Instructions Operating Guides
I've used them in the past with good results.
They even managed to get a guide for me which was not shown on their site
Jul 25, 2011 | Klein Electronics Klein 69115 Wiggy...
Do you know where we can purchase a Wiggy Square D 6610 voltage tester?
Go to this page and click on "find a retailer":
http://www.service.kleintools.com/Tools/PRD/Category/Continuity%20Tester%20TESTERS-CONTINTEST-CONTTEST/Product/69115
I should tell you, as an electrician, the Wiggy is considered obsolete. The Klein ET200 will do the same thing as a Wiggy and also tests continuity. When the leads are placed in the tester's built-in grooves you can easily test tamper-resistant (TR) receptacles:
http://www.homedepot.com/Electrical-Electrical-Tools-Accessories-Electrical-Test-Meters/h_d1/N-5yc1vZ1xg4Zboff/R-202266608/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Dec 10, 2010 | Your One Source Square D Wiggly Voltage...
Can I test a 12v battery
My friend ... here is the answer:
Description:
  • WIGGLY VOLTAGE TESTER
  • Solenoid type tester polarity
  • indicator
  • 120/240/600 VAC; 50/60 HZ
  • Lifetime warranty
Your 12 volt battery is DC voltage as well as far below the voltage testing threshold of 120 volts.
Thank you for your interest n FixYa.com
Jan 13, 2010 | Your One Source Square D Wiggly Voltage...
Reassembling a vhs tape---lots of little internal parts and springs. where do they all go? Is there an exploded diagram for the reassembly?
You do mean a TAPE?
If so I suggest you take apart an old tape that's no good or a cheap new one, that will show you better than a diagram.
Jan 09, 2010 | Televison & Video
How do you get the contact tips together so that they work. It is a 6610 wiggy tester.
To check your meter for continuity, put settings on dial to the Ohm setting. Touch the 2 tips together & if it is operating properly, the needle will spike. Then you can check a circuit on a wire using both tips to touch (black) wire & (white) wire.
Sep 28, 2009 | RTO Wiggy 6610VT1 Voltage Tester
Vintage General Electric Range
Lazidaisies,
you asked where can I find a service manual for a vintage stove? General Electric, 24"wide, push-button, electric; 1950s.
Placard on inside of oven door is "erased", except for embossed numbers: On the Left = 1 1245W2M2 10 7 On the Right = NM28552
You should go to GE and call them on the phone. They will have th resources to give you this Manuel!
bless you,
huuum
Please rate me before you sign off
Sep 12, 2008 | Kitchen Ranges
Klein Tools Klein Wiggy Solenoid Voltage Tester Logo
240 people viewed this question
Top Klein Tools Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Klein Tools Measuring Tool and Sensor Expert? Answer questions, earn points and help others
