Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
When I attempt to open up and use a FTP program the error response said: "Too many connections from this IP (2) Help! thanks. I am using WNDR3300 router hard wired to four different components. 1. my computer 2. Xbox 360 3. Nintendo Wii 4. DVD player with an Ethernet onlet for Netflix "I am not using the wireless feature of this unit. I think there is a setting I must do in the setup on www.routerlogin.net. In the port forwarding.. but I am not certain. When it saids "too many connections " is it suggesting that I disengage some of the four units I have plugged in or is there some setting I can set up so this set up might allow me to use FTP programs to exchange large files? Thanks for any help...
    Brigadier General:
  • 10,406 Answers
It is the FTP-server at the "other" end that is complaining about too many simultaneous connections -- you open one or two connections everytime that you try to connect.
After a few minutes, the FTP-server will close all the "dormant" sessions, and you should be able to connect.
Posted on May 28, 2010
How to connect pc to casio se-c6000 cash register
Question is how to connect PC with Casio SE-C6000 Cash Register. Answer is very easy and simple. This ECR is POS system and has capability of FTP . Download any FTP software from net. Go to ECR program 3 . Press 798 and sub Total Key. enter local network area unique IP address for this ECR starting with 192.168.1.10 as( 192168001010) an example and must be not conflicting and within the range of local area IP Adresses. then press CA/Amt. Key. then 255255255000 for sub mask and press CA/Amt Key again..Then 192168001254 as gate way then press CA/amt Key again and sub Total Key to finalize. Connect PC with network cable in RJ45 slot on ECR. Turn the mode key on Reg Mode for normal operation. Now on FTP software which is already installed on your PC open and put host ID IP address of your ECR. User Name is "SCTHRD" and Password is : "OTTFFSSENT" then Enter . You will see all program of ECR in folders. I hope it will help your need . Ibrahim Azhar
Apr 01, 2012 | Casio Parts Cash Register PC Desktop
Tip
Bullet Proof FTP Server Tutorial
This is for the BulletProof FTP Server 2.10. However, It should work fine on most following versions as well.
I'm assuming you have it installed and cracked.
Basics 1. Start the program. 2. Click on Setup > Main > General from the pull-down menu. 3. Enter your server name into the 'Server Name' box. Under Connection set the “Max number of users" to any number. This is the limit as to how many users can be on your sever at any time. 4. Click on the 'options' tab of that same panel (on the side) 5. Look at the bottom, under IP Options. Put a check in the box “Refuse Multiple Connections from the same IP”. This will prevent one person from blocking your FTP to others. 6. Also put a check in the 'Blocked Banned IP (instead of notifying client). VERY IMPORTANT! If somebody decides to 'Hammer' (attempt to login numerous times VERY quickly) your server/computer may CRASH if you don't enable this. 7. Click on the 'advanced' tab 8. At the bottom again look at the 'hammering area' 9. Enable 'anti-hammer' and 'do not reply to people hammering' Set it for the following: Block IP 120 min if 5 connections in 60 sec. You can set this at whatever you want to but that is pretty much a standard Click 'OK'
Adding Users 11. Setup > User accounts form pull-down. 12. Right click in the empty 'User Accounts' area on the right: choose 'Add' 13. Enter account name. (ie: logon name) 14. In the 'Access rights' box right click: choose ‘Add’. 15. Browse until you find the directory (folder) you want to share. In the right column you will see a bunch of checkboxes. Put a check in the following ones: Read, Write, Append, Make, List, and +Subdirs. Press 'select'. 16. Enter a password for your new FTP account. 17. Click on 'Miscellaneous' in the left column. Make sure 'Enable Account' is selected. Enable 'Max Number of Users' set it at a number other than zero. 1 for a personal account and more that one for a group account. Enable 'Max. no. of connects per IP' set it at 1
18. Under 'Files' enable 'show relative path' this is a security issue. A FTP client will now not be able to see the ENTIRE path of the FTP. It will only see the path from the main directory. Hide hidden flies as well. Put a tick in both of these.
Advanced: You don't need to do any of this stuff, but It will help tweak your server and help you maintain order on it. All of the following will be broken down into small little areas that will tell you how to do one thing at a time.
Changing the Port The default port is always 21, but you can change this. Many ISPs will routinely do a scan of its own users to find a ftp server, also when people scan for pubs they may scan your IP, thus finding your ftp server. If you do decide to change it many suggest that you make the port over 10,000. 1. Setup > Main > General 2. In the 'Connection' Area is a setting labeled 'Listen on Port Number:' 3. Make it any number you want. That will be your port number. 4. Click 'OK'
Making an 'Upload Only' or 'Download Only' ftp server. This is for the entire SERVER, not just a user. 1. Setup > Main > Advanced 2. In the advanced window you will have the following options: uploads and downloads, downloads only, and uploads only. By default upload and download will be checked. Change it to whatever you want. 3. Click 'OK’
While you are running your server, usually you will end up spending more time at your computer than you normally do. Don't be afraid to ban IP's. Remember, on your FTP you do as you want.
When you are online you must also select the open server button next to the on-line button which is the on-line Button
You also have to use the actual Numbered ip Address ie: 66.250.216.67
Or even Better yet, get a no-ip.com address
on Feb 08, 2010 | Computers & Internet
I have a Buffalo WBMR-G54 ADSL Router. The local IP address of the router is 192.168.1.1. My Medion desktop computer connects connects to my Buffalo router using an Ethernet cable. I use the wireless...
> Zone Alarm free firewall and Avast antivirus have been installed on both computers
Your router is already acting as a "firewall" to block "unsolicited" traffic from reaching the computers on your LAN. So, unless you use Zone Alarm to block "outgoing" connections
(such as a computer-virus would try to make when "calling-home", there's little benefit
to using the Zone Alarm software.
> If I use Internet explorer to connect to http://myname.dyndns.org, Internet Explorer does connect successfully to the network. However, it invites me to enter the username and password for my Buffalo WBMR-G54 router - not for the storage drive.
While you are "forwarding" TCP port 21, you are not "forwarding" TCP port 80 (as used by the 'http://' protocol). So, when you connect from the Internet to your "public" IP-address, it is the router that responds, rather than one of your computers inside your LAN.
IMHO, it is "bad" that your router's web-interface is "exposed" to attacks from the Internet.
Either "forward" TCP port 80, or configure the router to use a _different_ port number for "remote management".
> If I enter the Router user name and password, that allows me to access the Router menus via the Internet, which confirms that my account at DynDns has translated the IP address successfully.
Correct. Hopefully, you're the only one who knows the correct username/password, and there is nobody that is doing "brute-force" attacks on your router, trying to login to "hijack" your router.
> if I use Internet Explorer or FileZilla to access ftp://myname.dyndns.org, I cannot connect to the router
Correct. The 'ftp://' protocol uses TCP port 21, which the router is "forwarding" to one of the computers on your LAN.
> or the storage drive - so I cannot access any of my files remotely.
> FileZilla reports -Status: Resolving address of bob1944.dyndns.org
> Status: Connecting to 78.144.xxx.xxx:21...
> Status: Connection established, waiting for welcome message
So far, so good.
Is FileZilla expecting a "specific" content in that "welcome" message, or will "any" response be "close-enough" ?
On a computer on the Internet, open a command-line prompt:
Click Start
Click Run
Type CMD
Press Enter
Enter FTP bob1944.dyndns.org
Press Enter
Do you get a "connecting" message?
Do you get a "connected" message?
Do you see the "welcome" message?
Note that the FTP protocol usually uses _two_ ports for File Transfer:
* port 21 for "control" (sending/receiving commands/responses)
* a "random" port for "data" transfers (including directory-listings)
It's this "random" port that your router is not forwarding.
However, some FTP-clients (probably including FileZilla) and some FTP-servers
support "passive" mode, where both the "control" and the "data" connections "share" port 21.
So, configure FileZilla to use "passive" mode, and _hope_ that your FTP-server supports "passive" mode.
Jan 06, 2011 | Buffalo Technology WHR-G54S Wireless...
Scan won't send the files to the network folder
1 - If connecting via the IP adress, please check that the IP address for the destination's folder hasn't changed (if it is an automatic ip address, i'll recomment placing a fixed one,
2 - Check the folder's permissions, you can try to allow anyone for that folder, write and execute for all users.
3 - If you transfer files via the FTP protocol, then you should enable file sharing with the ftp service active (port 21):
Thias is what i have found for windows xp:
"XP includes a built-in FTP service component that lets FTP clients connect to the machine and read or write files; however, this service doesn't install by default. To install the FTP service, perform the following steps:
- Start the Control Panel Add/Remove Programs applet (go to Start, Control Panel, then click Add/Remove Programs).
- Select Add/Remove Windows Components.
- Select Internet Information Services (IIS), then click Details.
- Select the File Transfer Protocol (FTP) Service check box, then click OK.
- Click OK to close all dialog boxes."
hope these things help
Dec 19, 2010 | Toshiba e-STUDIO 4511 Printer
Cannot access FTP server from outside.
your server need to connect on Internet with pubilc IP or fixed NAT with public IP
Apr 08, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't connect to my webpage using Cute FTP, since I got my D-Link Wireless modem, How can I open up port 21? I get this error: During an FTP session, the following error...
You need to open port 21.
Using the DLINK manual, find out what the IP No. of your modem is.
(i.e., 10.1.1.1)
1. Type the IP No. into your Browser window. Press <enter>.
2. Look through the Modems Firewall Settings to open Port 21.
ELSE
Navigate to : http://www.dlink.com.au/tech/Default.asp
Follow the instructions on the page to select the product etc... and get support. Here you should be able to find the IP No. of your modem.
OTHERE
There is information on CuteFTP's website and also an extensive knowledge base and support section.
1. Navigate to the CuteFTP support area of their site: http://www.cuteftp.com/support/
2. Select which area you wish to look into : User Forum, Knowledge Base, Support etc...
3. In the Quick Search section, type the error into the search field, i.e, socket error = #2000. Press <enter>.
4. Read through the information.
Hope this helps. Regards
Feb 09, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Ftp - port forwarding
Hello.. If you already have the port numbers needed and static IP on your computer, you can do the following steps to open them on your router:
1. connect a computer to the router wired.
2. Launch an internet browser and type in http://192.168.2.1. Use the user name and password that you have set for your router.
3. Click on the Firewall tab, then Port Forwarding
4. For the Protocol, specify if the port you will open is TCP or UDP.
5. Set the port numbers on both WAN and LAN port range then set the Static IP address on the textbox then click add. After doing that, check if you have an apply,save or ok button and click on that.
Here is the site for the user guide of your router.
If you do not know how to set a static IP on the computer, you can do the steps from this link. This depends on the operating system of the computer you are using. Make sure to set an IP address in the range of 192.168.2.x (x being a number from 2- 200).
Jul 30, 2008 | U.S. Robotics USRobotics USR5461 Wireless...
Sagem d box
Before you try anything - make sure you understand how to do the following:
1. Use a network cable (RJ45)
2. Use an FTP program (FlashXp or Filezilla etc)
do you know if you're using a 1 chip or 2 chip Sagem (1chip is most likely but you 'must' know before attempting anything.
The answer is to either re-flash the unit with an image (a software program) which has the auto updating ROM7/10/11 keys included.
You can use the FTP program (assuming you know the IP address of your system and that of the DBOX) - and manually copy the freely available ROM7/10/11 files from your PC into var/var_init/keys etc
If most of the above is double dutch - then get a mate to do it - you can easily be left with a box which doesn't start up and has the infamous 'KEIN System' on the display.
Jul 15, 2008 | StarTech.com StarView SV211K 2-port KVM...
FTP problems.
There are 2 ports used for FTP. They are 20 and 21. When you initiate a connection that occurs on port 21, but data traffic is on port 20. Your firewall sees your outside FTP server trying to 'initiate' a connection on port 20 and breaks the connection to that IP address.
What you need to do is either use 'passive' ftp or open both ports 20 and 21 for ftp traffic in the firewall.
Apr 02, 2008 | D-Link DFL-800 Firewall
Proxy server?? problems
I supose this old problem has been solved?
Jun 08, 2007 | RCA REB1200
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
78 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
