Question about Dometic RM2652 Refrigerator
Bottom box stayes at 21f. on gas or elertic. had board and thermister replaced last year.
  • doswell23231 Jun 01, 2010
    cleaned drain with hot water allo defroseted like you said has ben working good between 40f and 35f thank a lot charles
    good deal fixed it thanks charles will youse you again charles
    Brigadier General:
  • 3,917 Answers
Thanks for writing to Fixya.com.
Try to vacant the fridge first. Next unplug and totally defrost the unit. Pour hot water down the drains. You might have to take off the bottom and back panels in the freezer box to get to the drain tubes. If you can bring it outside easily, you could clean everything with a garden hose, including the condenser cooling coil, drain pan, interior. Dry it well before plugging it back.
Thanks for contacting Fixya and please accept the solution if it has helped you.
Posted on May 28, 2010
My lg wm1832cw washer was in spinmode when it made a bam noise and lost power. I had to change the board ans when I did the upside down f and e came on. I changed the thermistor but am still getting the...
check the wire harness from main board to thermister. tE error code is either an open or shorted thermister. If you replaced the main board and thermister, the only other option you have is a bad harness. Reseat connectors on the main board and all along the harness to the thermister
Feb 10, 2013 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
GE side by Side ESS22XGMD won't go into defrost
its the defrost heater under the evaporator coil g.e. make a very poor and cheap heater and only last about 6 years average,replace it with a new g.e. part number WR51X10101,its a dual filament heater and looks different than the one now in there but will fit o.k.
Aug 29, 2012 | GE GSH25JFR Side by Side Refrigerator
I have a Kenmore Elite HE3 gas dryer that is not heating. When starting a cycle, it will run for a couple of minutes, then stop with "E2" on the display. Lint has been cleaned out from entire...
Ok
E2 means the control board has sensed problem or shorted thermister. Located on blower housing.
Replacing thermister should solve the problem. This picture should help.DISCONNECT POWER BEFORE ATTEMPTING
Elite Dryer schematic
Was thi helpful?
Aug 22, 2011 | Dryers
Food is warm on top frozen on bottom in bottom in both refrigerator and freezer
My guess is the thermisters are out of spec and the control board is not getting correct temp reading from them. Use the PSS service manual to locate the thermisters and check them according to manufacturers specs listed in the manual.
This ADC link explains how the icebox functions
Aug 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have had a GE Profile Artica Refer for 6 years and have nothing but problems. After 3 years, we had to have I think the mother board replaced because the refer would not cool....would run at 50 degrees...
The old style ice boxes used a mercury bulb switch that shut power on and off according to the desired temp. Not now brother. We decided that was not good enough so what brainiacs came up with were electronic monitoring. Sound familiar? A group of thermisters are placed around the icebox to monitor ambient temps. 177300d.jpgThese thermisters( thermostat resisters) change in resistance when temperatures change. The fancy control board relies on these suckers to give it good intel when to shut down cooling systems. You should consult your tech sheet to see if the ohms readings on each thermister is within 10% of specs.
Mar 20, 2010 | Refrigerators
98`350 yamaha warrior elertic start
may want to chec fuse-sometimes a normal lookin one is bad-test inspect wiring in ignition system for corrosion-cuts plug wire could be bad or connect
Aug 20, 2009 | 2003 Yamaha YZ 250 F
Our GE Profile Model PS123NG/PS123NS came brand
probably a loose thermister. The thermister being not attached to the evap coils tight might not be relaying back the proper resistances info for the control board to make a propper defrost determination.
May 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dometic rm2611 not restart after cooling box normally, then warmi
I would replace the thermister and also check the gas soleniod. Don't those get weak once they get hot or warm. Hope this helps.
May 10, 2009 | Refrigerators
Pilot light won't stay lit after release of gas valve.tried few t
Most likely it's time to replace the thermocouple, the safety device that makes sure the pilot is lit. New thermocouples are cheap and you can find them at most hardware stores and the big-box places (Home Depot, etc.)
Here is a site with basic information to get you going.
Apr 08, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Dometic RM2652 Refrigerator Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
