Question about GE Kitchen Ranges
I have a GE XL44 gas range. My Broiler goes on then off, on then off what could it be?
  • retnmt May 28, 2010
    Everything works except the broiler
  • 166 Answers
If this is a self cleaning model with the broiler at the top of the oven then i would guess that you may have an ignitor going out. is the bake working ok?
if this is not a self cleaning model and the broiler pan is underneath the oven then it uses the same burner as the bake. if this is the case you should also be having trouble with the bake function.
Posted on May 28, 2010
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
GE XL44 Oven and stovetop work - broiler does not work
The broiler is the top element in the oven. Look at it. Bad ones sometimes have burnt into or have a melted spot. If it looks ok take it out by removing the screws at the back and pull the wires out a little and unplug the element. With an ohm meter it should show continuity. Replace it if any of these things apply.
Feb 04, 2010 | GE Kitchen Ranges
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Lower oven burner will not light.
    Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
    May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE spectra xl44 not work
    I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
    Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Ge xl44
    GE XL44... Oven does not work. It was working just fine one day & then would not work. Everything else works fine. Stove has electric ignitiion. Could it be it is not working on the oven? Any ideas?
    Jan 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Kitchen Ranges Logo
    224 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Mike Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
