Question about Neovo F-419 19" LCD Monitor
How do I configure using front screen controls? What do OSO, phase shift, etc mean and who do I adjust them?
  • 11,361 Answers
Does digital mean the tramsmitions are printed out on the screen?
no
It means the radio transmissions are converted from analogue sound waves into a digital format. Then the radio uses a phase shift technique to encode digital information on what is in reality an analogue radio signal.
The receiver then converts the digital signal back to analogue for the sound waves out the speaker.
The advantage is that amplitude variations do not affect the quality of the radio and error correction techniques may also be employed to fix errors in the digital information.
https://en.wikipedia.org/wiki/Phase-shift_keying
Feb 17, 2016 | Radio Communications
I need info about what the cpu phase leds on aN msi 990fxagd65 mean
They indicate the number of different power phases that the CPU is currently using. In order to save power the motherboard is able to reduce the voltage to (and performance of) the CPU. In 2 phase mode (2 LEDs) it basically switches between high performance, and low performance. 4 LEDs means that there are two additional intervals in between the high and low power settings. 6 LEDs indicate six total phases, etc.
I believe that there is a greater possibility of system instability as you increase the number of phases that the motherboard switches through.
Oct 22, 2012 | MSI 990fxa-gd65 Motherboard Am3 Amd990fx...
98 f150 won't engage in 4wd
For the 1998 MY the front axle uses a vacuum shift motor
Is the system ESOF ( Electronic Shift On the Fly ) or MSOF ( Mechanical Shift On the Fly ) ?
Lift and support the front of the truck so the front wheels are off the ground ( take safety precautions, chock wheels, jack stands, etc )
Key on, engage 4x4 and try to turn the front drive shaft.
If it turns it is a problem with the transfer case.
If it doesn't it is a front axle engagement problem.
If the problem is with the front axle engagement, check that the shift motor is operational
This is on the front axle. If it does not move, it could be a problem with the vacuum lines or the vacuum diaphragms.
The vacuum should be applied to the pink line if you are in 2WD, and the blue line when in 4WD.
Obviously check the fuses if you have the ESOF versions, to make sure the transfer case shift motor is operational.
Aug 18, 2010 | 2004 Ford F150
My phone shows a dark screen when turned on. it's nokia 6124c
Hi, when a phone displays a dark screen,it means that the screen of the phone has shifted or has stop working.
Unscrew the phone to check if the screen shifted. adjust if shifted.
But if not shifted, that means screen will be replaced.
Take care.
Jun 02, 2010 | Nokia 6124 classic Battery
Window screen is smaller then the monitor. it is on the
For presice adjustments of VGA input run the Auto Ajustment Software on the CD
Additional image quality improvement use the clock and clock pahase controls of the monitor to fine tune the image
Clock increase or decrease the value to minimize any vertical bars or stripes visible on the screen backgroung
Clock phase increase or decrease the value to minimize video distrotion or video jitter
  • allow the monitor to heat up before adjustments
  • use the adjustment pattern application provided ont he CD
  • select OSD menu to select image control and change clock or clock phase
  • Incase of any error restore factory settings select the OSD menu and select factory reset and select yes
Feb 25, 2010 | HP 2159M Monitor
At the spin cycle it shuts dwn and has Lr on the screen when I shut it off to just use spin cycle it does a count down but not the spin then Lr comes up again
Hi
Thanks for using FixYa. Lr means locked rotor. This issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
My printronix printer making shadow while printing
Hammer Phasing Adjustment:
Important: The printer must be printing the Phase pattern of “H’s” when the
Phasing Value is changed, or the New Phasing Value will not be written
into NVRAM. If the value is changed when not printing, the printer will
return to its default phasing value when powered off then back on.
1. Raise the printer cover.
2. Install the ribbon.
3. Load full width (136 column) paper and set the top of form.
4. Power on the printer.
5. If the printer is on-line, press the ON LINE key to place the printer off-line.
“OFFLINE / CONFIG. CONTROL.” displays.
6. On the control panel, press the = + > keys to unlock the ENTER key.
“ENTER SWITCH UNLOCKED” briefly displays. (If “LOCKED” displays,
simply press = and > again. This is the default key combination. The lock/
unlock key combination can be programmed by the user. If = + > does
not unlock ENTER, get the combination from the user.)
7. Press the ; key. “OFFLINE / DIAGNOSTICS” displays.
8. Press >. “DIAGNOSTICS / Printer Tests” displays.
9. Press >. “Printer Tests / Shift Recycle” displays.
10. Press ; until “Printer Tests / Phase Printer” displays.
11. Press ENTER. The display shows “Printer Tests / Phase Printer” and the
test begins. The current phasing value is printed on the left of the printed
pattern of all H’s. As the pattern prints, compare the H’s to the figure
below. If the phasing needs adjustment, go to step 12. If the phasing is
OK, go to step 15.
12. Press >: The current phase index displays. Press > again: An asterisk (*)
appears next to the phase value.
13. Press < to increase or ; to decrease the phasing index value, then press
ENTER to activate the value as it prints. Continue to increase or decrease
the phasing index until the pattern of H’s is acceptable.
14. Press = twice: “Printer Tests / Phase Printer” displays.
15. Press ENTER to stop the test.
16. Press CLEAR. “OFFLINE / CONFIG. CONTROL” displays.
17. Press = + > (or the key combination set by the user). “ENTER SWITCH
18. Close the printer cover.
19. Press the ON LINE key to place the printer on-line.
NOTE: If you changed the phasing value, power down the printer, remove
the shuttle cover, and write the new phase value on the aluminum
shuttle casting.
Jun 04, 2009 | Printronix Line Matrix P5005B Printer
On the jensen vm9022 how do you reverse the subwoofer polarity
CLICK HERE for a copy of your manual in PDF format.
Phase control is featured on page 17 (21 of pdf)
In the Audio Sub-Menu:
Subwoofer Phase Adjustment: Touch the sub.w icon to
access the subwoofer polarity controls and reverse the
subwoofer signal polarity from to 180°. Reversing
polarity can improve bass response related to speaker
configuration.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 06, 2009 | Jensen Car Audio & Video
Print is clear and fuzzy
I'm sure you have fixed this by now... But solution is...
Check the hammer phasing. Adjust hammer phasing if
necessary.
OK, go to step 15.
LineMatrix
Sinca Printers, Parts, & Repair
www.sinca.biz
Jun 11, 2008 | Printronix Line Matrix P5215 Printer
Dell m782 Brightness control???
Brightness is adjusted by using the 2 buttons on the left side of the front.
See instructions here:
http://support.dell.com/support/edocs/monitors/m782/En/controls.htm
Jan 04, 2008 | Dell M782 Monitor
Neovo F-419 19" LCD Monitor Logo
181 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
