Question about Microsoft Visual Basic Enterprise Edition 6.0 (361-00667) for PC
How to form an array in visual basics(Express)
  • 249 Answers
Samples of arrays in vb.net
1)
dim array(3) as integer
array(0)=1
array(1)=2
array(2)=3
array(3)=4
2) dim array() as integer
array=new integer(){1,2,3,4}
3) for two dimensional arrays add comma separation to the size
Posted on May 29, 2010
How can i get the free downloader and installation of visual basic 6.0..? programming, form........:((
there isn't one. you can download a free visualbasic.net edition from microsoft. it is part of visual studio express see http://www.microsoft.com/express
otherwise you have to try buy one from ebay or suchlike, and expect to pay quite a bit for it.
Aug 24, 2011 | Microsoft Visual Basic 6.0 for PC
How to run vb
How to Run a Visual Basic Program on a PC By an eHow Contributor
Like C++, C Sharp and Java, Visual Basic (VB) is an object oriented programming language. Recently it was integrated to the Microsoft .NET Framework. The .NET Framework is a software infrastructure that speeds up program development. It is supported by the Microsoft Visual Studio Integrated Development Environment (IDE), Microsoft's chief programming environment, and that of SharpDevelop.
Difficulty: Easy Instructions Things You'll Need:
  • Visual Microsoft Studio and .NET Framework
  1. Launch your Microsoft Visual Studio. It is a "heavy" application so depending on how much RAM you have it may take a few minutes to load.
  2. Click the Project tab on the first screen. Notice two buttons at the bottom of the screen named "New Project" and "Open Project." Since the tutorial assumes that this is your first VB program, click the "New Project" button. If you worked on a project before, its name will appear in an area labeled "Open an Existing Project" with a hyperlink that opens the project.
  3. Select "Windows Application" in the "Visual Basic Projects" folder if you intend to run your end program on a computer running a Microsoft Windows operating system. Focus in the "Name" text box near the bottom. Change the name from the default to something more descriptive such as "MyFirstVBProgram." Leave the Location to the default value to save your project to the "My Documents" folder. Press OK.
  4. Concentrate on the grey square area with the arrays of dots. This is the "form." The pinboard shows where components like buttons and text boxes will be installed to make a complete graphic user interface (GUI). The purpose of the grid is to align the components.
  5. Run your program. Click "Debug" from the menu bar. Click "Start" from the drop down menu. Alternatively, you can press F5 on your keyboard.
  6. Enjoy your first Visual Basic program in its simplest form. It is identical to the form in Step 4 except that the dots are gone. What you are looking at is a stand alone program that exists as an ".exe" file having the same name as your project. You can find it under the MyFirstVBProgram folder by default.
  7. Understand the difference between the two distinct environments of the IDE, the Design Environment and the Debug Environment. You saw the Design Environment in Step 4 of this tutorial. That was the environment where you could design a GUI on the form using your mouse. The Debug Environment takes over during the compilation interval in Step 5. That is where you can insert break points in your source code so that you test the correctness of the program.
Read more: How to Run a Visual Basic Program on a PC ' eHow.com http://www.ehow.com/how_2072757_run-visual-basic-program-pc.html#ixzz17b5EMirN
Dec 09, 2010 | Computers & Internet
Visual Basic 6.0 for PC: how can I download visual c++? ...
Microsoft provides basic C++, C# and VBASIC on express editions. For software development for publication, you will need to purchase Visual Studio.
May 14, 2010 | Microsoft Visual Basic 6.0 for PC
How to store in an array the records in a listview
create form1 with one list box and form2 with text boxes and command button.
Go to project >project properties>start object will be form2..
Here i takenexamble of two textboxes..code is below
Private Sub Command1_Click()
Form1.List1.AddItem Text1.Text, 0
Form1.List1.AddItem Text2.Text, 1
Form1.Show
End Sub
hope this will help you...Thank you,....
Nov 11, 2009 | Microsoft Visual Basic Professional...
Insertion sort
<!--StartFragment-->
Function InsertionSort(ByVal TempArray As Variant) As Variant
' Written By Louis Sutherland
' 1/25/99
' will be the sorted arrary when finishe
' d
Dim SortedList As Variant
Dim x, y As Integer
Dim NumSorted As Integer
'This Set up SortedList as an Array
SortedList = TempArray
'This zeroizes the new array
For x = 1 To UBound(SortedList)
SortedList(x) = 0
Next x
'sets the Total num counted to 1
NumSorted = 1
' Processes first element
SortedList(1) = TempArray(1)
For x = 2 To 5000
' insertion loop
For y = NumSorted To 1 Step -1
' if current value is <= then insert in
' next place
If TempArray(x) >= SortedList(y) Then
SortedList(y + 1) = TempArray(x)
'This Breaks the loop
y = 1
Exit For
Else
If y = 1 Then
SortedList(y + 1) = SortedList(y)
SortedList(y) = TempArray(x)
Exit For
Else
' save the value to the next spot
End If
End If
Next y
'advance total num sorted
NumSorted = NumSorted + 1
Next x
InsertionSort = SortedList
End Function
Mar 17, 2009 | Microsoft Visual Basic 6.0 for PC
How i can download vb on my pc for windos98
Here the download for visual basic environment on windows 98
Download details: Visual Basic 6.0
If you instead want to do programming, then you need to download Visual studio 2005, that runs on Windows 98.
You can download Cisula Studio 2005 from the link below:
Download details: Visual Studio® 2005 Express Editions SP1
Feb 28, 2009 | Microsoft Visual Basic Professional...
How can i download visual basic 6 soft ware freely
Dear friend take a look to these links, I hope they help you:
http://www.youtube.com/watch?v=y4F_rPu0ddU
(Through this video you'll learn how to download VB 6.0 free)
http://www.developers.net/tsearch?searchkeys=visual+basic+6+free+download
You can aslo download Express version of VB via this link:
http://en.kioskea.net/telecharger/telecharger-104-visual-basic-express-edition
Good luck
Feb 24, 2009 | Microsoft Visual Basic 6.0 for PC
I need to download visual basic
Here is the free version for you: Click Here
Feb 01, 2009 | Computers & Internet
Open Questions:
Hai everyone, I am doing a project on Attendance Monitoring. I have two tables one master table called student and another table called att to store students daily attendance. I have four comboboxes in my form, by selecting the city,area,centre and batch the respective students satisfying this condition has to be displayed in the grid apart from that i have to display another column to mark attendance. I am using datagrid and mark P for present and A for absent. When i finished marking the whole data has to be stored in att table with the current date. The next day again the same class may be selected with the next date and has to be stored again. The problem is i am not able to store each person attendance. Please help me in this regard. The att table contains fields like Code: Student_ID,Date,Attendance The student table contains fields like Code: Student_ID,City,Area,Centre,Batch,Name etc The code that i have written is like this Code: Public ac As New ADODB.Connection Public ar As New ADODB.RecordSet Private Sub Command1_Click() Set ar = ac.Execute("select student.Student_ID,att.Attendance from student,att where City = '" & Combo1.Text _ & "' AND Area = '" & Combo2.Text & "' AND Centre = '" & Combo3.Text & "' AND Batch = " & Combo4.Text & "") Dim count As Integer count = ar.RecordCount MsgBox count Set DataGrid1.DataSource = ar End Sub Private Sub Form_Load() ac.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=E:v-tablesStudent.mdb;Persist Security Info=False" ac.CursorLocation = adUseClient Combo1.AddItem ("CHENNAI") Combo1.AddItem ("BANGALORE") Combo2.AddItem ("GILL NAGAR") Combo2.AddItem ("CHOOLAIMEDU") Combo2.AddItem ("EGMORE") Combo2.AddItem ("SOWCARPET") Combo2.AddItem ("KOTTIVAKKAM") Combo2.AddItem ("KILPAUK") Combo2.AddItem ("MOGAPAIR") Combo3.AddItem ("RANGA NURSERY") Combo3.AddItem ("V-KIDS") Combo4.AddItem ("1") Combo4.AddItem ("2") End Sub
Jun 27, 2009 | Microsoft Visual Basic Enterprise Edition...
Microsoft Visual Basic Enterprise Edition 6.0 (361-00667) for PC Logo
110 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
