Question about Honda Garden
Honda Harmony mower starts but will not stay running
Honda Harmony Self Propelled mower starts but will not stay running. It starts right up but immediately stalls out.
  • 61 Answers
Rebuild the carberator. easier said then done huh. anyways, thats your only soluation. hope this helped you
Posted on May 29, 2010
HOW DO I REPLACE THE SELF PROPELLED ON MY HONDA MOWER. MODEL HRX217HXA
http://www.lawnsite.com/showthread.php?t=281234
Good pictures on this link to follow. I found it eaiser if you put your mower on a work bench or 2 sawhorse with plywood on them. Read everything on the link for your plan before you start. When you finish you will feel you can fix anything on the mower. Hope this will do the trick for you. Good luck!
Sep 21, 2014 | Honda HRX217VKA Lawnmower
I have a 6.5 self propelled Lawnman by MTD . It will start but will not stay running.
is the handle hard to pull?or pull back at times?any way pull the flywheel off and check the key that aligns the crank and flywheel in time they shear when you hit rocks
May 08, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
May 17, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Self propelled mower will start but want stay running long? it runs about 3 or 4 min. then stop and when i restart it, it will start back up.
The fuel bowl has a float and needle, if the float isn't floating to open the needle for gas to flow into the carb, it will cut off. A kit can be purchased for about $5 or take yours out and soak and clean then replace. Usually when these go bad its best to replace them.
May 10, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Honda Harmony self propelled not propelling. Belt is fine. Cant find adjustments
Do you know for sure that the belt is not stretched. Make sure also that it is on the pulley correctly and the pulley is spinning with the shaft you also might have spun a key.
Oct 08, 2009 | Garden
Honda harmony self propelled cable snapped at end
Get a replacement cable, part number should be in your user manual...when you get the cable it should have directions on how to replace.
Sep 08, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Apr 29, 2009 | Garden
Honda Harmony mower, self propelled hydrostatic, wheels lock up when pulled backward. Going forward no problem.
If i remember correctly, under each drive wheel, there is a small gear, and under each gear there is a small metal rod that is what the transmission uses to propel the mower...it sounds like the rods either have dirt on them or they are just stuck and can not move to allow you to pull it backwards
Apr 25, 2009 | Garden
Garden Logo
1,651 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
