Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Water draining in bottom of refrigerator - Frigidaire FRT21H8 Top Freezer Refrigerator
  • Frigidaire Master
  • 1,606 Answers
Unplug the refrig . Inside the refrig section , remove the 4 screws ( 2 on each side ) and
lower the panel . Disconnect the large plug and remove the panel by pulling froward to
clear the defrost drain hole .Find a food safe caulking or odorless silicon and caulk at the
upper portion where the styrofoam meets the plastic AND on the top center of the styrofoam (
all the way around the large rectangle hole ) so that the styrofoam will seal to the top of
the refrig . When the refrig goes into defrost , the water is seeping between the refrig top
and the styrofoam , causing it to run into the refrig section . When reassembling , be sure
to plug the large plug back into the refrig .
Posted on May 28, 2010
  • Mike Smith
    Mike Smith May 28, 2010
    While the panel is down , insert a hose in the drain hole opening on the rear wall and blow thru it to remove any unseen blockage in the line .
3 Suggested Answers
  • 11 Answers
SOURCE: water draining to bottom of refrigerator during
you need to check behind the panel on the freezer side (inside) the drain hole is more than likely plugged. run a coat hanger through it.
Posted on Aug 26, 2009
imufo2
  • 3773 Answers
SOURCE: water in bottom of the
Sounds like cooling coils inside ref. that cools the water before the dispenser in the door.
These coils are in the back bottom of ref, behind crispers. They may be leaking.
Here is some more help.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
Posted on Sep 26, 2011
Why does my samsung fridge leak water under the fridge when I use my water dispensor?
hi Todd.
Problem: It's leaking water. ... Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leakingout of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself - CNET
https://www.cnet.com/.../three-common-refrigerator-problems-you-can-easily-fix-yourse...
Why is my refrigerator leaking water from the bottom?If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013SOLVED: Water leak in refrigerator? - Refrigerator - iFixithttps://www.ifixit.com/Answers/View/128713/Water+leak+in+refrigeratorSearch for: Why is my refrigerator leaking water from the bottom?
Why does samsung fridge leak water under the fridge Google Search
Nov 27, 2017 | Samsung Refrigerators
I have water on floor under refrigerator.There is no water supply line to this frig.
SOLVED: Water leak in refrigerator? - Refrigerator - iFixit..or go to this link might help you as well....
water on floor under refrigerator Google Search
Oct 23, 2017 | Refrigerators
We have a leak inside of the refrigerator. Water
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website). If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Mar 20, 2010 | Refrigerators
I have water under the crisper drawers in my fridge. The water at the bottom on the ?condenser does not seem to be draining what can I do? Thanks Mary
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clear the bottom of the refrigerator so you can get at the drain. Then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the freezer side as well.
Good Luck,
Gilshultz
Dec 01, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
It is leaking water and the bottom of the refrigerator has water
Is water leaking OUTSIDE your refrigerator or INSIDE at the bottom of your refrigerator ? If it is inside your refrigerator the most common reason is a clogged defrost drain tube - The water collects from a defrost cycle and drains through a hole on the ceiling of your refrigerator into a cup that drains it through the tube down to the defrost pan at the bottom of your refrigerator on the back and evaporated by the compressor heat. Sometimes this tube gets clogged and water does not drain from the cup and overflows inside your refrigerator against the backwall.
Aug 16, 2009 | Kenmore Refrigerators
I have a whirlpool refrigerator and it seem to be leaking from
The bottom front of the refrigerator or freezer door Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
The back of the refrigerator Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Underneath the front of the refrigerator If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn’t out of place, broken or cracked.
Mar 24, 2009 | Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
My whirlpool refrigerator is leaking water inside the refrigerator. i have no water or icemaker on mine. its just a regular old fridge about 9 years old. i keep it clean and vaccum out the bottom every...
Water can leak from these areas:
Here's what to do:
Jan 06, 2009 | Refrigerators
Leak
It leaks Water can leak from these areas:
Here's what to do:
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Water pooling on the bottom shelf of the freezerless refrigerator
take back panel off inside freezer.
you will see a drain tray at the bottom with a drain hole in the middle. this hole is blocked with ice
melt off with a hairdryer and follow up with hot water till water flows away freely.
check drain tray heater is ok as well
Oct 11, 2008 | Kenmore 16.7 cu. ft. Freezerless...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
403 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
