Question about ASUS K8V-MX Motherboard
My computer froze up one day. The green light on the mobo stays lit all the time now. I've replaced the cpu, RAM and tried different video cards, but it still won't boot up. I even got a different ASUS mobo and the green light on *it* stays lit up!. When I got a new/different cpu, the system does at least try to start, but only runs for 2 or 3 seconds and then shuts down. The hard drive is fine (works in another system). Anyone got *any* other ideas what could be the trouble? Everything is seated properly and nothing is loose. The RAM is good (I tried it on another computer). I'm at a loss and been without a computer for almost a month now. Thanks.
    President:
  • 1,138 Answers
Hi!
Check the out put voltage of your power supply.. If possible try using a digital multi-tester. Check the standard reading on the power supply connetor, the red wire should read +5 volts while the yellow wire should read +12 volts..
If the readings is below the standard output voltage, then it means that the supply current for the motherboard and other hardware like harddrive and cd drive is not stable.. it cannot supply the required voltage to run your motherboard.
Check also if there is something that affects the current stability of the power supply...like for example check all the cooling fans, exhaust fan or blower fan that is already burnt and yet still connected to the power supply.
Hope you find the problem from this solution..
Much appreciated if you rate this solution.. thanks..
Posted on May 28, 2010
  • ASUS Master
  • 4,806 Answers
I think you have just about covered everything by testing the hardware out on a different system. The only vital thing that you haven't checked is the PSU (Power Supply Unit).
Get another power supply of the same type and try that in your system as faulty PSU's can cause these problems even though the motherboard is showing that power is being received, it could be showing a false positive.
Please let me know how you get on and if i can provide anymore assistance.
Regards.
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
Nov 14, 2016 | Computers & Internet
Ok, hey guys, this may end up as a bit of an essay, for the past month now i have been trying to work out why my pc has so much problem posting, 99% of the time nothing happens, not even a post check, here...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
don
Feb 10, 2011 | ASUS Crosshair III Formula AM3 AMD 790FX...
Shut down my PC, unplugged it, moved it to new location. Plugged it back in and it would not power up green light on the ASUS P4P800SE would not stay lite. Replaced power supply, green light on the mother...
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
Jan 11, 2011 | ASUS P4P800SE Motherboard
Fans work green light shows on motherboard but cpu wont power up
Any HDD light on / if not could be failed HDD OR faulty IDE / Sata cable.
Did you get posting beep if not remove / replace ram / reboot.
If you did then either mobo / CPU may be faulty.
May 10, 2010 | Intel D845GVSR Motherboard
Powered off while using. now will not power on. tech @ bestbuy sed was bad motherboard
Take out the battery and only hook up the ac adapter. Make sure if your ac adapter has a green light that its lit. If its not lit then that means bad ac adapter.
If your laptop doesn't turn on then next step is to take out the hard drive and the dvd drive.
Try turning on the laptop again and if it doesn't turn on then that means for sure its a bad motherboard.
Dec 03, 2009 | Acer Aspire 4520-5803 Laptop
Gateway 702GE desktop When i push the front botton to start it up,the fans start to turn and then stops with no operation. The small green led on the motherboard stays lit and green and the front start...
try removing all the cards from the expansion slots and remove the ram sticks. disconnect the drive cables from the board but dont touch the cpu or power connectors. Now hit the button. If nothing changes, probable board fault. If it now boots up and starts beeping ( which it will when no ram sticks installed) shut it down and reinstall each drive connector, ram stick and card one at a time booting between each item. when the faulty item is connected, the board will stop booting and you can replace that item. Many things can also cause this. Bad connections to ram sticks and video cards, damaged usb port connections, failed cpu's, failed psu's etc.. You may still have to take the machine to a professional repairer to have the problem diagnosed.
Nov 02, 2009 | Gateway 702GE PC Desktop
Computer does not post. Fans & lights on.
Good day sir, as you describe your problem, as I see it you forgot to replace your Power Supply box. Swap in a new one, see if it runs. Also make sure that your RAM is good.
Oct 13, 2009 | ASUS A8N32-SLI Deluxe Motherboard
No power to dell latitude d600
have you checked your ram? remove it and see if it powers on and qickly turn off. if it powers on replace ram after shutdown. if problem not fixed coud be cpu problem or mobo.
Jun 02, 2009 | Dell Latitude D600 Notebook
P5NT won't boot
I went throught this and it is really silly. The P5N-T motherboard has a problem with some of the new energy efficient CPUs. The fix was to insert an older CPU and upgrade the bios and then it would recognize the new CPU. If you happen not to have an older 775 CPU laying around (most people do not), it might be easiest to return it and get a different board - or maybe the store can upgrade the bios for you.
Oct 05, 2008 | Computers & Internet
New Graphics card wont work
is the bios set to dispaly using a built in graphics card on the mobo?
Jul 02, 2008 | Intel Motherboard
ASUS K8V-MX Motherboard Logo
135 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
