Question about Frigidaire Kitchen Ranges
I have a Frigidaire stove that was installed in 2008 model FED 355ESB serial #NF64920919. All of the burners except one have stopped working. Have had electrician out that tells me that power is there but nothing is working. Can you please tell me if there is something that can be done to get this repaired.
  • mary_newman_ May 28, 2010
    Yes was helpful will try the suggested repairs
    President:
  • 949 Answers
Since one of your burners is working I would agree with the electrician that the power is fine.
The problem is with the connection points between the burners and the receptacles. The image below is not the best picture but if you look at the 'tips' of the elements and receptacles (numbers 27) they will most likely be black or burned and pitted on the burners that do not work on your range.
The burner will plug into the receptacle (27) and when the contact gets burned it will not longer work. You can try to sand off the ends until clean but the best repair is to replace the burners and the receptacles.
The part numbers for your model are:
Left rear and Front Right Burners: 5303012223
Right Rear and Left front burners: 08067762
Receptacles: 5303912666
Posted on May 28, 2010
    Are the parts readily available at local hardware stores or are these items only available through a dealer for Frigidaire. Also is this a common problem with this model?
  • Philip May 28, 2010
    They would not be available at a hardware store but will be available at an Appliance Parts Dealer. You should be able to find one in the yellow pages for your town, if you cannot find one, I can look up one if I know what city and state you are in. You can also order online at places like the following:
    http://www.searspartsdirect.com/
    repairclinic.com
    This is a fairly common problem for this type of range, so the parts will be easy to get and should not cost an arm and a leg.
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
Frididaire electric stove the oven has stopped working
Good Afternoon Friend, thank you for allowing me to assist you!
I understand you are experiencing an issue with the oven of your Frigidaire range. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? Do the burners/elements work? With this information I can assist you better in pinpointing the problem.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you! -Z
Sep 05, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
Frigidaire Glass Top Stove - Model #FEF668CJ5C The
Check your incoming power for 240 volts and your circuit breaker.
Check the cord where it attaches to the back of the range. If they are OK,look for a loose or broken wire.
There are no fuses in-line with the surface burners.
Jul 10, 2010 | GE JBP65 Electric Kitchen Range
Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Burners abruptly stooped working on top of the stove
check electrical panel of your house and make sure both breakers are in the on possition ..
Jan 04, 2010 | Frigidaire FEF352 Electric Kitchen Range
I have a frigidaire gas stove model #FGF337AWJ.
I went through that once and believe it or not it was the ignitor. Instead of a thermocouple these new ovens use the amount of current going through the ignitor to prove the flame. Seems like after it gets ot a certain temperature the amps drop off enough to cut out the flame and then it will try to recycle. If it is not that it would be the thermostat but they very seldom go bad. I would reolace the ignitor first I think it will solve your problem.
Nov 14, 2009 | Frigidaire FGF337BC Gas Kitchen Range
Frigidaire gas range makes loud whirring sound when oven is set above 250
You don't give a lot of info here (like if the range was converted from natural to LP, or if the burners are OK, or if it is a self clean model and how the broil works, etc) and I can't guess all that, especially because a lot of people post under whatever model pops up when they enter a key word while posting a problem, but,..........
Any range that was professionally installed should have been tested for proper burner and oven operation by the installer before they left. Call the installer back and let them know you are not satisfied.
Nov 02, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Burner no longer functions
two thiongs, you might have a bad switch( under control knob), or before you try that ck the old elemnt that you replaced, on the back of the limiter( the glass rod that goes through elemnt itlself), you'll see little letters 1a,2a,1b,2b.--- new replacemnets depending on age are wired differently, they too will have 1a2a1b2b but in different position. id check that first
Mar 02, 2008 | Jenn-Air JES9800AAS Electric Kitchen Range
Kitchen Ranges Logo
32 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
