Question about ASUS P4S333-M Motherboard
Does ASUS P4S333-M support USB 2.0? Currently, I have USB 1.0 but if I buy a USB 2.0 PCI, would it work?
  • vinceandrewp May 28, 2010
    Really? Can you site sources if ever there are any? And will it run as fast as 2.0 or speeds of 1.0 only?
  • 4,737 Answers
Yes definite it'll work for your motherboard. Good luck. Thank you for visiting FixYa.
Posted on May 28, 2010
  • Lebanon Raingam
    Lebanon Raingam May 28, 2010
    Well if you don't believe, I don't want to interfere with your problem. I assist you with my experience not with what i assume. Usb 2.0 has it's own speed as Usb 1.0 also has it's speed, you cannot changed it or modify.
Asus P4S333-M Audio driver where can i find download and how to install?
HI!!, In Asus homepage ( asus.com) you can find all drivers to the motherboard, here are they, http://support.asus.com/Download.aspx?SLanguage=en&m=P4S333-M&p=1&s=15 just download the audio driver, and run it, and follow instructions.
Apr 06, 2011 | ASUS P4S333 Motherboard
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Want to konw that will new graphic cards work on my pc??
I suggest that you need to buy the SAPPHIRE Radeon HD 5770 1GB graphics card. It is compatible to your ASUS motherboard. It will display and work faster.
Dec 23, 2009 | Computers & Internet
ASUS P4S333 Bios is maybe corrupted
Asus motherboards are junk, if you buy another in the future, stay clear of Asus products.
With that said, you should check your system for malware and viruses first, before doing anything else
Sep 06, 2009 | ASUS P4S333 Motherboard
ASUS P4S333 no power
Asus motherboards are garbage, they die within a short period after being sold (perhaps they're even designed to die so that asus can sell more) Buy from a reputable manufacturer like foxconn, abit, gigabyte
Aug 09, 2009 | ASUS P4S333-M Motherboard
Reseting bios
Read & follow the instructions found on page 2-18 in your
P4S333-M manual. If you do not have your manual you can download it by clicking on the PDF link below;
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4s333-m/p4s333m-100.pdf
You will need Adobe reader to view the PDF file. Download Adobe for free at; http://www.adobe.com/products/reader/
Cheers!
Mike
Apr 25, 2009 | ASUS P4S333-M Motherboard
ASUS P4SDX USB Ports not recognized as USB2 HS Ports
The message comes up when a USB 2 device is connected to a slower USB 1 or 1.1 port. It is only to advise you that the devise will operate faster on a USB 2 port. If your computer has only USB 1 or 1.1 ports, you will always see the message. You can buy and install a card with USB 2 ports and install it. It will come with the USB 2 drivers. Install the card and the drivers and then connect your USB 2 device to the new hardware and you should not see the message anymore.
Good luck, And let me know ho it works out for you.
~ Spoem
Mar 30, 2009 | ASUS P4SDX Motherboard
Dear Sir, I have a problem with audio device, My system is saying that found new hardware, I think it may be realtec audio drive or avance audio drive ********* to Asus..they can't provide sound driver...
reyhard_23,
Click on the Asus link below. When the site opends there is a search windows in the right hand corner; http://support.asus.com/download/download.aspx?SLanguage=en-us
Type in P4S333-M & click the white arrow. In the next window that opends click on, "P4S333-M related files for download". Another windows will open & here you'll need to choose your operating system from the drop-down menu. Click the plus sign to the left of "Audio". Create a folder on your desktop & name it Audio. Download the audio driver into that folder.
This Asus board does not use the SiS 7012 chipset. From the link above you will ba able to download the manual. On page 1-6 you'll find the P4S333-M MB uses the SiS 961 controller for audio.
If you want the CD that came with the Asus MB you can pick up a copy at Asus E-store. http://estore.asus.com/shop/.
Manual link; http://www.unitycorp.co.jp/support/download/manual/478/p4s333_m_e.pdf
Good luck reyhard_23!
Mike
Jan 30, 2009 | ASUS SiS Chipset P4S333-M...
ASUS P4S333-M Motherboard Logo
290 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
