Question about Amana D545M Dehumidifier
Amanda dehumidifier, only the fan runs, the compressor doesn't
I have an Amanda dehumidifier Model number D545M. Only the fan runs, the compressor doesn't. My neighbors quit after 1 year mine quit after 2 years. Thanks, Larry
bozcro
  • 867 Answers
SOURCE: Kenmore Dehumidifier fan runs, compressor buzzes and quits
sounds like the compressor is seized.
Posted on Aug 01, 2009
  • 3368 Answers
SOURCE: I have a Goldstar dehumidifier model # DH440EYR.
Check the voltage to the fan motor. More then likely the fan motor It is either frozen or burnt out.
Good Luck,
Gilshultz
Posted on Dec 02, 2009
heatman101
  • 43501 Answers
SOURCE: I have a two year old D545M dehumidifier that has
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
  • 794 Answers
SOURCE: Model BHD-301 dehumidifier compressor will
Hi bash123er,
If you're facing these problem that your dehumidifier is not producing water and compressor is shutting off then there are few things that needed to be checked on:
1. The very common problem with most dehumidifiers is the circuit board relay. If this has gone bad then it will require replacement.
2. The compressor has already gone bad. This is the problem if you notice a buzzing sound every now and then from the system.
3. You may also have a refrigerant leak. This happens when the compressor is running but coils are not getting cold at all.
4. There will be cause of low water production if the fan is not running and the compressor does. If fan is not running then you have to replace it. This also will result frozen coil.
5. Check to see also if your coil is blocked. This will also result into no water production.Air needs to be continually moved over the cold coil to get the water out of the air.
If you're not comfortable doing the checking and repair yourself then I would recommend that you contact a repairman.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 03, 2011
joeguest2
  • 2080 Answers
SOURCE: I have an Amana D545M
If the machine's compressor runs when you switch it on, then turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you would need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options can potentially cost about the same.
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. If your dehumidifier is freezing up then that probably means the unit itself is actually working well and you probably just have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit. Remember to also clean the air intake filter while you are at it.
The ambient temperature in the room may also be a bit too low, so you can try adding some heat to the room if necessary. A dehumidifier will not work properly if the ambient air temperature is too low. Basically, the warmer and more humid the room is, the better they work. Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where the air is warmer.
Sometimes the drain tube leading to the bucket is clogged. You can often clean this out by inserting the pointy end of a long heavy duty plastic zip tie and jiggling it around a bit. Do not insert anything metal or sharp into the tube or you may damage it.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
And here is a link to a tip from another Expert (Heatman101) which includes his very detailed troubleshooting guide for dehumidifiers:
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
If you choose to rate Heatman 101's tip using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on Jun 20, 2011
Is there a recall on this product? My compressor and fan run but no water is collected. I know other Amana dehumidifiers were recalled for fire risk due to compressor overheating so I took cover off and...
Your description indicates a loss of refrigerant in the dehumidifier. The metal heat exchanger above the water collector should become cold when the compressor is running - if it does not, your dehumidifier likely has lost it's refrigerant charge. You will have to take it to a certified (refrigerant handling) technician to repair. It may make more sense to replace with a new dehumidifier.
Check the CPSC website for dehumidifier recalls. they will have details of the brands/models/serial numbers of recalled units.
Oct 23, 2013 | Amana D545M Dehumidifier
Has there been a recall on this product? My compressor seems to run but no water is collected. I took the back cover off and the compressor is extremely hot and I know that other Amana dehumidifiers were...
Compressor runs and gets hot but fan will not kick on. Replaced the capacitor and that did not help. One side of coils gets hot, the other side gets cold, which seems normal. Just can't get the fan...
Don't run the compressor for any length of time without the fan operating. Is it possible that the fan must be replaced? Can you power the fan safely to test it?
Gary
Jul 26, 2011 | Maytag M7DH45B2A Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Hope this helped you. Please let me know. Thanks.
Jun 06, 2011 | Danby Dehumidifier
Compressor seems to be overheating although top is cool. Continues to run but doesn't collect water. Fan is working. Can't locate model number.
If the compressor motor is overheating, it's usually a result of low refrigerant gas in the cooling coils. Recharging is an option, if you can find a shop that will do it.
May 22, 2011 | Kenmore 54501 Dehumidifier
We can hear the fan running and then the compressor, but little to not water produced; sometimes we can hear it click on and then off; the fan seems to be running a lot...
You may have the humidity level set to high. Usually anything above 50%, will show little results, unless your house is flooded.. Turn the humidity setting to the lowest level that your humidifier has
and give that a try.
The fan runs a lot, because it's designed to almost constantly move the air around. That way, if the humidity level rises above the setting on the dehumidifier, it can sense it and the compressor will turn ON.
May 17, 2011 | Amana D545M Dehumidifier
How do you know if it is on?
Assuming that the unit is plugged in to an outlet that has power, press the ON button and a green light should come ON. That will indicate the unit is getting power and is ready to function. If however, you have the humidity level set to high and it's equal to or higher than the humidity level in your home, the unit's compressor and fan will not turn ON and run. Keep in mind, the humidity level, whether it's and LCD readout screen or just a minimum and high setting, that's not the amount of humidity that the unit will remove. It's what it will maintain. So, setting it as low as possible, should cause the unit to start functioning.
If it doesn't start, check the water collection bucket, to be sure that it's installed properly and is making contact with the safety trigger switch. If it's not making contact, the unit will not turn ON.
Hope this info helped you. Please let me know. Thanks.
May 13, 2011 | Amana D545M Dehumidifier
Humidifer is not taking out water. Is there a start capacator for the compressor?
This could be one of several things, we are assuming the air is humid. If the fan is not running and the compressor is, replace or repair fan motor. If the compressor is running, the output line from the compressor should be warm, if not you probably have low refrigerant gas, plugged cap tube or a bad compressor. If it is slightly warm check the evaporator portion at the outlet of the cap tube, it should be cold, probably in the 40F range depending on ambient temperature, if not see above.
Goof Luck,
Gilsh
Nov 26, 2009 | Amana D545M Dehumidifier
I have a two year old D545M dehumidifier that has stopped dehumidifying. The fan operates, but it is not removing any moisture. What could the problem(s) be?
heatman101
Sep 01, 2009 | Amana D545M Dehumidifier
AmanaD545M Runs but no water comes out
if the compressor is running and the coils dont cool, then you have a refrigerant leak or a plugged capillary tube. it would cost more to fix than to but a new one. sorry but its time for a new one.
May 11, 2009 | Amana D545M Dehumidifier
Amana D545M Dehumidifier Logo
88 people viewed this question
Top Amana Dehumidifiers Experts
Gil Shultz
Tom Chichester
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
