Oki Microline 186 pauses for approxamatly 3 seconds during printing. Happens multiple times.
    Genius:
  • 3,422 Answers
HI,
The fault is with your printer.Please get it serviced by a technician.
And if it is still under warranty i suggest you to get it replaced.
Goodluck..
Posted on Apr 07, 2008
    Master:
  • 555 Answers
Does it eventually continue and complete your print job?
  • Matt Jurach
    Matt Jurach Apr 07, 2008
    I see that this particular printer has a relatively small internal memory--only 128KB.
    I'm guessing this pausing happens with larger print jobs, but maybe not with small, single page jobs?
    The pause is probably when the printer rebuffers the next part of the print job from the computer, since it can't hold the whole job all at once.
    Assuming the job eventually finishes, this is an unavoidable inconvenience. A printer with larger internal memory would be needed.
Okidata 186 does not feed
Are you using pin feed or friction feed? Make sure the lever on the right is in the correct position.
Apr 08, 2013 | OKIDATA - DOT MATRIX New - Oki Microline...
Oki 320ml dot matrix printer pauses while printing and the menu light start to flicker.It resumes printing after a while. Why?
The printhead has some thermisters in and it is either actually overheating or a faulty thermister thinks it is overheating. Either way, a new printhead is required.
Jan 14, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
I have a OKI Microline 320 printer.
Your printer has a damaged mainboard. Very sorry, for yours is a very good unit. the replacement model is the Oki ML-420, which comes with a 3-year warranty.
Be blessed.
Oct 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI DATA MICROLINE 320 TURBO PRINTER PROBLEM
Hi Charles,
Use the IBM proprinter driver for this printer and select IBM in the menu of the printer.
Hope this helps.
Dezzi
Sep 10, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki microline 280
Check printer setup where you define carrige return and line feed options. Alot of times you need to set printer to do an auto CR on reciept of LF or auto LF on reciept of CR. I run into this all the time.
Aug 02, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Cannot Print at all
what kind of network is this printer setup on? it must be an external print server, that runs a cable to the serial port? i actually have not seen this done on this Oki model. it may not be possible...any more info you can add, and i can see what i can figure out.
thanks.
chris
Apr 02, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 591
You need to set and store paper size, width etc in printers internal menu and on print driver on pc.
See Oki manual for printer settings its written on the front of the machine i think menu and set power on, then print to see settings then read manual...
Jan 04, 2008 | OKI MICROLINE 591 Matrix Printer
Oki microline 590 elite
What driver are you using for this printer? Try loading a Epson LQ1050 driver and try again.
Dezzi
Dec 12, 2007 | OKI MICROLINE 520 Matrix Printer
44 people viewed this question
jasbo
jasbo
