Question about Champion International Champion 532 2 Splash Lubricated Two Stage Air Compressor Pump
Having problems with my champion air compressor
Started blowing oil out by crankshaft pulley side
    Problem Solver:
  • 18 Answers
Crankcase vent may be stopped up. Could have too much oil in the compressor.
Posted on Jul 10, 2010
Ford Expedition 2001 crankshaft sensor location and installation
  • Located front of engine, close to crank pulley
  • press the helpful button and follow me on Fixya for more tips
  • Insert the square tip of a 1/2-inch socket wrench into the square hole in the center of the serpentine belt's adjustment pulley. The adjustment pulley is the smallest pulley the belt wraps around.
  • Pull the adjustment pulley toward the engine with the socket wrench to release the tension on the serpentine belt, then pull the belt off the air conditioning compressor's pulley.
  • Remove the bolts which secure the air conditioning compressor to its mounting brackets with an open-end wrench, then position the compressor to the side of the engine compartment. Do not disturb the hoses that attach to the compressor.
  • Pull the electrical connection off the crankshaft sensor.
  • Remove the two bolts that secure the crankshaft sensor against the engine with an open-end wrench, then slide the sensor out of the engine.
  • Slide the new crankshaft sensor into the engine, then install and tighten the sensor's two securing bolts with an open-end wrench.
  • Press the electrical connection onto the crankshaft sensor.
  • Position the air conditioning compressor against its mounting brackets, then install and tighten the compressor's bolts with an open-end wrench.
  • Pull the serpentine belt's adjustment pulley toward the engine with the socket wrench, then position the belt onto the air compressor's pulley. write up found @ehow
How to Replace the Crankshaft Sensor in Ford 150 eHow
Jan 28, 2016 | Ford Expedition Cars & Trucks
Ac quit
engine running do you see compressor turning let me no pierre
Aug 02, 2008 | 2004 Dodge Intrepid
Champion CSF30 compressor high screw temp fault
Check the oil level, if oil level is ok, check the cooler for cleanliness, if cooler is clean, check the thermal valve by measuring the temperatures going in and coming out of valve. The final thing would be the air-end (pump). has lost it clearances.
Apr 04, 2014 | Champion Air Tools & Compressors
VP10 Pump,air Compressor,single Stage,3 Hp 5FTU5
3 inch pulley with a 3600 rpm motor. 6 inch pulley with 1800 rpm motor.
Nov 04, 2013 | Champion VP10 Pump,air Compressor,single...
Position of cam shaft censor in the ford f150
nstructions
    • 1
    • 2
      Pull the adjustment pulley toward the engine with the socket wrench to release the tension on the serpentine belt, then pull the belt off the air conditioningicon1.png compressor's pulley.
    • 3
    • 4
    • 5
    • 6
    • 7
    • 8
    • 9
Read more: How to Replace the Crankshaft Sensor in a Ford F-150 ' eHow.com http://www.ehow.com/how_6769823_replace-crankshaft-sensor-ford-f_150.html#ixzz2Ebai9Ftj
Dec 09, 2012 | 1998 Ford F150 Regular Cab
Crankshaft pulley r/r
Place the crankshaft pulley bolt removal tool over the end of the crankshaft bolt. Tool will hold the pulley in place while you apply torque to the bolt with an impact wrench. Start the air compressor by plugging it in and turn it on. Set the pressure of the compressor on the highest setting. Attach air hose on the air compressor to the air inlet and the locking mechanism using the quick-connect lock on the end of the air compressor hose. Set the impact wrench to turn counterclockwise. Spray the crankshaft bolt with penetrating oil. Make sure you soak the bolt head in oil so that it is easier for the wrench to remove. Secure the socket end of the wrench to the pulley bolt and pull the trigger on the impact wrench. You might need to reapply penetrating oil several times during this process to loosen the bolt up. Eventually, the bolt will come off 215 lbs torque, and simply stated righty tighty, lefty loosy. Hope this will assist you.
Dec 19, 2011 | 1991 Honda Accord
Having a problem with the belts on 1986 Saab.
There are four drive belts
  1. crankshaft to power steering pump
  2. crankshaft to a/c compressor belt idler pulley, to a/c compressor
  3. crankshaft to coolant pump, and
  4. crankshaft to alternator.
3 and 4 are side by side belts on the crankshaft, and each drive both the coolant pump and the alternator.
See this page for pictures of the belts, but I haven't a layout for them. The pulley grooves align for each of the different belts, so it shouldn't be too too difficult to figure out which is which.
Dec 21, 2009 | 1987 Saab 9000
Hi - While being moved, Speedaire compressor (model 32180) fell on its side. Side opposite pulley and dammaged unit directly opposite of pulley. I have no idea what the unit is called or its function. Was...
Lee,
I'll email you the breakdown. The pump is probably actually a 3Z180, made for Speedaire by Champion. If you are looking for the assembly sticking out of the back of the pump, it is probably the centrifugal unloader, which vents the pressure after the compressor shuts down. You can get the parts from Grainger parts (888-361-8649), or your local Champion compressor distributor.
Nov 06, 2009 | Air Tools & Compressors
Compressor not cycling and building pressure after servicing
Hi
I suspect you may have either overfilled the sump or used the wrong viscosity oil, may have splashed up onto valves and patially jammed one open.
Aug 11, 2009 | Champion International Champion 532 2...
Timing for tropper 6cly and 4 camshafts and 24 valves model 2000
Timing Belt
Removal
1. Disconnect battery ground cable.
2. Remove air cleaner assembly.
3. Remove radiator upper fan shroud from radiator.
4. Move drive belt tensioner to loose side using wrench
then remove drive belt.
850RW001
Legend
(1) Crankshaft Pulley
(2) Cooling Fan Pulley
(3) Tensioner
(4) Generator
(5) Air Conditioner Compressor
(6) Power Steering Oil Pump
(7) Drive Belt
5. Remove cooling fan assembly four nuts, then the
cooling fan assembly.
6. Remove cooling fan drive pulley assembly.
7. Remove idle pulley assembly.
8. Remove serpentine belt tensioner assembly.
9. Remove power steering pump assembly.
10.Remove crankshaft pulley assembly using
5–8840–0133–0 crankshaft holder, hold crankshaft
pulley remove center bolt, then the pulley.
11. Remove right side timing belt cover then left side
timing belt cover.
12. Remove lower timing belt cover
13. Remove pusher.
CAUTION: The pusher prevents air from entering
the oil chamber. Its rod must always be facing
upward.
014RW011
Legend
(1) Up Side
(2) Down Side
(3) Direction For Installation
(4) Locking Pin
14. Remove timing belt.
CAUTION:
1. Do not bend or twist the belt, otherwise its core
could be damaged. The belt should not be bent at
a radius less than 30 mm.
2. Do not allow oil or other chemical substances to
come in contact with the belt. They will shorten
the life.
3. Do not attempt to pry or stretch the belt with a
screw driver or any other tool during installation.
4. Store timing belt in a cool and dark place. Never
expose the belt direct sunlight or heat.
6A–30 ENGINE MECHANICAL
Installation
NOTE: For correct belt installation, the letter on the belt
must be able to be read as viewed from the front of the
vehicle.
014RY00042
Legend
(1) Crankshaft Timing Pulley
(2) RH Bank Camshaft Drive Gear Pulley
(3) Water Pump Pulley
(4) Idle Pulley
(5) LH Bank Camshaft Drive Gear Pulley
(6) Tension Pulley
014RY00043
Legend
(7) Alignment Mark on Oil Pump.
(8) Alignment Mark on Timing Belt
(9) Alignment Mark (notch) on Crankshaft Timing
Pulley.
(10) Alignment Mark (groove) on Crankshaft Timing
Pulley.
014RW006
Legend
(1) Timing Belt
(2) Engine Rotation Direction
(3) Cylinder Head Side
1. Install timing belt.
1. Align the mark (notch) of crankshaft timing pulley
(2) with mark on oil pump (1).
Align the mark (groove) on the crankshaft timing
pulley (3) with alignment mark (white dots line) on
the timing belt (4).
NOTE: When timing marks are aligned, No.2 piston will
be on Top Dead Center.
014RW003
Legend
(1) Alignment Mark on Oil Pump
(2) Groove on Crankshaft Timing Pulley
(3) Alignment Mark on Crankshaft Timing Pulley
(4) Alignment Mark on Timing Belt
ENGINE MECHANICAL 6A–31
2. Align the alignment mark on the RH bank
camshaft drive gear pulley (2) to the alignment
mark of the cylinder head cover RH (3).
3. Align the alignment mark (white line) on the timing
belt (1) with alignment mark on the RH bank
camshaft drive gear pulley (2) (on the left side as
viewed from the front of the vehicle) and put the
timing belt on the camshaft drive gear pulley.
Secure the belt with a double clip or equivalent
clip.
014RW00004
Legend
(1) Alignment Mark on Timing Belt (White line).
(2) Alignment Mark on Camshaft Drive Gear
Pulley.
(3) Alignemnt Mark on Cylinder Head Cover RH.
4. Align the alignment mark on the LH bank
mark of the cylinder head cover LH (3).
5. Align the alignment mark (white line) on the timing
belt (1) with the alignment mark on the LH bank
camshaft drive gear pulley (2).
When aligning the timing marks, use a wrench to
turn the camshaft drive gear pulley, then set the
timing mark between timing belt and camshaft
drive gear pulley and put the timing belt on the
clip.
NOTE: It is recommended for easy installation that the
belt be secured with a double clip or equivalent clip after
it is installed the timing belt to each pulley.
014RW00005
Legend
Pulley.
(3) Alignemnt Mark on Cylinder Head Cover LH.
6. Install crankshaft pulley temporarily and tighten
center bolt by hand (do not use a wrench).
Turn the crankshaft pulley clockwise to give some
belt slack between the crankshaft timing pulley
and the RH bank camshaft drive gear pulley.
2. Install pusher and tighten bolt to the specified torque.
Torque : 25 N·m (2.5 Kg·m/18 lb ft)
1. Install the pusher while pushing the tension pulley
to the belt.
2. Pull out pin from the pusher.
NOTE: When reusing the pusher, press the pusher with
approximately 100Kg to retract the rod, and insert a pin
(1.4 mm piano wire).
014RW011
Mar 18, 2009 | 2000 Isuzu Trooper
Champion International Champion 532 2 Splash Lubricated Two Stage Air Compressor Pump Logo
258 people viewed this question
Top Champion International Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Champion International Air Tool and Compressor Expert? Answer questions, earn points and help others
