Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
Tractor started up and ran for about 5 seconds and shut off. Now I have no power. When you turn the ignition switch on no dash icons come on, nothing electrical in the cab works other than the clock in the dash.
  • 66 Answers
I would start with the ignition switch itself first if you know the battery is good. Second start checking fuses to see if any are blown. www.nnyparts.com
Posted on May 30, 2010
Tractor hasn't been ran for 2-3 months. It started up for a few seconds then shut off and won't start back up. It is 10 degrees out.
Check for spark and or fuel, bad ignition or safety switch etc.
below are links to videos and write ups on small engine, no start problems, press the helpful button
donyboy73
LAWN TRACTOR REPAIR how to diagnose and correct engine valve issues
Jan 21, 2016 | Cars & Trucks
Ford tractor
How old is the fuel in the tractor? is it petrol or diesel powered?
Apr 14, 2014 | Cars & Trucks
My 42 in Craftsman Tractor will not start. It normally runs great. I went to start it the other day and it ran for about 5 seconds before shutting down. It felt like it was getting no fuel. Any...
try and run it with the gas cap loose the vent could be plugged also see if it cuts out while keeping you foot on the brake and its just a bad safety switch shutting it off
May 29, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have an older Kubota tractor, model B7100 HST. Was running the tractor and had electrical smoke/short? Took the dash off and noticed that the regulator was fried and melted no other apparent damage. I...
I can see where you believe that the problem is in the dash. But I can also see where the mechanic said to trace the wires out. This is a very difficult one to figure out. But before you go buy an ignition switch. I would take the old ignition switch off and check all of the wires to ground. Make sure that you don't have any continuity on any of the wires to ground. Then you can check all of the pins on the ignition switch to ground also. This will determine if it is one of the wires going to ground, or the actual ignition switch going to ground.
Nov 30, 2010 | Diesel Garden
1999 Sunfire 2.2L wont start
Try starting it with the shifter in neutral. You might have a bad
Neutral safety switch.
May 14, 2010 | 1999 Pontiac Sunfire
When I turn the key to shut the engine down it
I don't think the starter solenoid is involved here. T
There should be a fuel shut off solenoid on the bottom of the carburetor which shuts off fuel when the ignition is turned off -- this is a safety feature as well as protection from damaging backfiring.
This fuel shut off solenoid could be stuck open.
There is a switch under the seat which opens and closes the solenoid depending on whether the seat is occupied. This switch as well as the ignition switch control the solenoid.
May 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No power to ignition - ? please help! 91 amigo 2.3l
If everything is turning on, and there's power... check for 12V at the alternator. it may be out now.... or a connector came loose, or wire broke.
Jan 09, 2009 | 1991 Isuzu Amigo
Engine starts, but stalls when clutch is released.
The is a safety switch located underneath the mower, in the dashboard area. This switch will not pass voltage to the ignition system unless the pedal is depressed, or the deck is not all the way up. However, your culprit is most likely the pto (power take off) switch on the dash that engages the blades. It will not allow the mower to start, if pulled, and if faulty will shut off ignition power when you release the pedal. First. You'll need a volunteer to sit on the mower and operate the controls.  Now put the deck down and with the pedal depressed start the engine. Nothing should happen, if it does replace the deck switch Sears part number #176138 mentioned above. Now raise the deck and release the pedal. Again, nothing should happen. Same solution if it does. If nothing happens on both tests the switch is ok. NOW. Behind the dash, find the pto switch, and squeeze the sides, depressing two clips that hold it in the dash. You should now be able to slide it though the dash, wiring attached. Unplug the switch. With pedal depressed, deck up, someone sitting on the seat, start the mower. Now release the pedal (making sure to block the wheels and have the transmission handle is in the neutral position. If the engine continues to run, you found the problem. Replace the PTO switch. Sears part number # 174651. Also, check the plug to the pto, ignition and deck switches for corrosion as this is a common problem, though not likely to cause yours, it could. Good luck, and please let us know the outcome, good or bad. Thanks so much.
Nov 12, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
226 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
