Question about Sony PlayStation Portable (PSP) Console
My "R" always on
My "R" Button always On. if I play a car racer, the "R" it's for handbrake, so if I play car racer, the car always brake
  • Sony Master
  • 441 Answers
The membrane under the R button has gone bad and needs to be replaced. The following website sells the part and also repairs them for $30 for R buttons replacement. Check the following page out for the part for the 1001 model PSP. They also sell it for 2001 and 3001 models:
http://store.richspsxparts.com/psprbuca.html
My
Posted on May 28, 2010
Testimonial: "Thank you for the solution, but I don't want to buy it from internet, because my credit card can be stole by a thief."
  • Richard T Jun 22, 2010
    You can also call the company at 757 965 3317 to order to mail them a money order.
    Your credit card is safer online than it is at restaurants or anywhere else you hand a human your card.
Help my friends handbrake on her automatic vauxhall Mokka is stuck on how can it be released?
Parking brake Always apply parking brake firmly without operating the release button, and apply as firmly as possible on a downhill or uphill slope. To release the parking brake, pull the lever up slightly, press the release button and fully lower the lever. To reduce the operating forces of the parking brake, depress the foot brake at the same time. Control indicator R 3 85.
Feb 16, 2015 | Vauxhall Cars & Trucks
The handbrake button light keeps flashing & the handbrake wont go off
Misplace/Broken switch located next to the back of hand brake. Hand brake is on. Low brake fluid. Check brake pads by removing tire. Change brake fluid if it's time.
Nov 22, 2010 | 2007 Volkswagen Passat Sedan
Park brake adjustment
no do not touch the cable thats cowboy stuff ,remove the drum and then grind the lip out on the edge of the drum ,then adjust the auto adjusters up manually so drum just slips on and you can hear the brakes rubbing ,perfect. then do the other side ,when you finish the handbrake shouldnt move more than 3 clicks and the footbrake will be nice and firm .Then its off after dark to the local industrial estate and take on the boy racers with handbrake turns ,drifting is out as its front wheel drive
Jan 15, 2010 | 1996 Mitsubishi Eclipse
How do I by pass the parking brake on a Jensen vm8032hd radio so the dvd will play while the vehicle is in motion?
The Hand brake wire simply needs to be connected to Gnd for the screen to always work. It may be a brown wire, but you may be able to clarify this on the lid of the radio or just find where the wire is connected to the handbrake and then ground it.
Sep 09, 2009 | Jensen Car Audio & Video
1996 Subaru Legacy L Wagon: Handbrake button is stuck in shaft.
this is generally a failure in the hand brake assembly itself.Pulling the center console will reveal the mechanism that locks the brake cable in the unit.You probably will notice its inability to hold in this area which will necessitate replacement .
Jul 23, 2009 | 1996 Subaru Legacy
My 1999 saab 9-3 seems to have a stuck handbrake. Can I drive it? I can't move lever up or down, button does not affect the lever. I am on Eastern Shore of Md. on a Sat. of course when I find this out.
If the handbrake is stuck on, with the brakes engaged, NO you should not drive it, as the brakes will overheat, or not move at all if fully engaged. If you aren't sure if they are engaged, it's easy to test. Just put the car in gear and try to drive ahead, on a flat surface. If the car goes forward without stepping on the gas, the brake is not engaged, and you can drive it. If you give it some gas, and it feels like it's holding back, or not moving, the brake is on and it shouldn't be driven. Is the brake handle in the down position ? If so, the button to move it is probably broken, and needs to be replaced, if it is stuck in the up, or on position, try pulling up and pushing the button in at the same time, it should release. Let me know how you make out. Good luck! Curt
Jul 11, 2009 | 1999 Saab 9-5
Rear brake lights always on
sounds like brake pad sensor damaged or did you forget to put in new pads or removed? if its got one.
low fluid in brake reservoir can cause light to stay on also
or hand brake light switch shorted to earth have seen coins jammed in there b4
May 28, 2009 | 1992 Daihatsu Charade
How to by pass to watch dvds
You need to have your parking brake engaged to watch dvds.
Mar 19, 2009 | Clarion VRX585USB Car DVD Player
I have a Ripspeed DVD-730B head unit for my car. its all installed but when trying to play a dvd it displays a message sayin: do not watch while driving and then only plays sound, no picture. how do i...
if the unit was installed with a handbrake lead properly it will only get picture with handbrake on,try taking that wire off and connect it to a permenant positive like the permanent live to the head unit,so the unit thinks the handbrake is on, or if it wasnt installed properly and that wire is somewhere else like a permenant negative then the unit thinks the handbrake is always off hence no picture while driving,hope this helps :-)
Mar 13, 2008 | Televison & Video
Sony PlayStation Portable (PSP) Console Logo
87 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
