Question about Brother MFC 3100C All-In-One InkJet Printer
I have a clogged Printer Head. Only blue works. Having the printer clean itself doesn't solve the Problem.All ink cartridges are new and full. Is it possible to clean the Ink head or do I have to buy a new one?
  • 241 Answers
If your printheads are dried out you will need to replace the printhead. If the printhead is built into the printer it is time to replace the printer or contact Brother directly to see if you can get a replacement printhead for this model.
Posted on May 28, 2010
Blue stripes on photo
Hello, if you have blue stripes moust likely some of the Magenta or Yellow nozzels are clogged. I recomand to execute head cleaning and deap head cleaning BUT with OEM cartridges. If that dosent help take the print head out of the printer and let it soak in distiled wather at 30-35 degrees Celsius. If that still dosent work you will need a new print head.
Jan 26, 2013 | Canon Mp 630 Compatible Printer Ink...
Hp officejet r60
You can use Sainsbury Bathroom cleaner which is very good.
Process to clean your printer which is the main reason for wastage of ink :
  • Turn on printer - head moves across
  • Pull power cord so the head is left 'unparked'
  • Spray cleaner onto the parking pads
  • Carefully soak up spray with kitchen roll
  • Repeat if there was a lot of dried up ink on the pads
  • Spray again - leave the pad soaked with the cleaner
  • Turn printer on, let head return.
  • Switch printer off with it's own power button
  • Wait overnight :-)
You can get cartridges full of cleaning solution but I prefer to get an old empty cartridge and add a few cc of isopropanol to it through the vent tube (this is a fiddly operation and needs a syringe). This cartridge now has very dilute ink/solvent in it. Run some test prints and see if the clogs go away. The very dilute ink and solvent is much easier to see on paper than pure cleaning fluid.
Oct 24, 2008 | HP OfficeJet r60 All-In-One InkJet Printer
Not recognizing ink cartridge?
1.Check the ink. Printers are picky machines. They are programmed so that they would recognise a particular kind of ink. Thus, when you buy compatible ink cartridges, make sure that these ink are truly ones specifically made for your printer. Otherwise, the ink will not work with your printer.
2.Follow the instructions to the letter. Just like the manufacturers of original printer cartridges, the manufacturers of compatible ink cartridges have instructions on how you should place and install the cartridges in the printer. You should follow these instructions to the letter so you can be sure that they would work.
3.Clean the printer head. It is also possible that the reason why the printer would not recognise the compatible ink cartridges you bought is that the printer head itself is clogged. Such problems can occur, especially when you have not used the printer in a long time. You can clean the clogged printer heads with a cleaning solution made especially for printer heads.
If the cartridge itself is the one that is blocked, you can try soaking the cartridge in warm water first. Afterwards, dry it with a lint-free rag and then install it in your printer.
4.Check the circuitry in your printer. Another possible reason why the printer would not read your compatible ink cartridges is that the printer itself has a problem with the circuitry. You can try topping the cartridge with ink first before reinstalling it into the printer.
If that fails, you should bring your printer to the repair shop. Be warned though: If your printer is under warranty, the warranty will no longer be valid if it is found out that you have used compatible ink cartridges.
Feb 26, 2011 | HP PSC 1510 All-In-One InkJet Printer
Not printing all colours, heads clogged? Printing red and blue but not yellow.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or viceversa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. Make sure that the yellow ink is not empty. If it's not empty, head may be clogged.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
If that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 11, 2010 | HP Photosmart D5160 InkJet Printer
Canon pixma ip90 printer is not printing blue colours. i've tried cleaning but it doesn't work.
If the blue ink cartridge is not empty, then it means that either the pront head or the ink cartridge is clogged. Here are some information about ink cartridge cleaning, and here you can find some information about print head cleaning.
Nov 24, 2010 | Canon PIXMA iP90 Mobile Printer
Hp photosmart 8050 won`t print black even though it says it full
Hi there! If you haven`t used the printer in 2-3 months the black ink cartridge has gona dry.Wich means the printer is seeing full ink but the ink isn`t actually coming out from the ink head.Take a peace of clean cloth or cotton and clear the bottom part of the ink head(be verry carfully while cleaning it cuz you may dmg the head.If that doesn`t help just go and buy a new ink cartridge and it will solve your problem.
Nov 10, 2010 | HP Photosmart 8050 InkJet Printer
Hp photosmart 7350-cannor print from emails or any
Your printhead is either clogged or not working. There should be a self cleaning program built in to the printer. Run this 4 or 5 times. If the unit still doesn't print you can either clean it yourself with Q-tips and isopropyl alcohol, or take it to your local HP printer repair center. If you printer is still under warranty I would advised having them check it.
Jul 15, 2009 | HP PhotoSmart 7350 InkJet Printer
Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Jan 13, 2009 | Canon I960 InkJet Photo Printer
Not printing even the test page,full ink ??
I have the same problem, I re-loaded the software, checked all the settings, went through set up procedures and nothing??????? I goes through all the motions, spits out the paper..........blank
Apr 10, 2008 | Epson Stylus CX6400 All-In-One InkJet...
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Brother MFC 3100C All-In-One InkJet Printer Logo
239 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
