Question about Samsung Televison & Video
Black an white line in the middle of my 42"inch samsung plasma
There is a black an white line going down in the middle of my 42" samsung plasma tv
lukster
  • 217 Answers
SOURCE: black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
Posted on Feb 17, 2007
SOURCE: I have no audio on my 42" Samsung plasma tv
This happened to me also. It had to be taken apart. The audio connector on the motherboard had come lose. Hope this helps.
Posted on Feb 07, 2008
charcois
  • 763 Answers
SOURCE: I have a lg flatron
see your manual about the settings you might find the configuration of it. hope that helps sir!
CHARCOIS
Posted on Aug 21, 2008
SOURCE: black line in a 42 inch panasonic plasma tv
I have a 2 black lines. One goes horizontal and one runs vertical. Is this something I can fix?
Posted on Sep 26, 2008
SOURCE: Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Posted on Oct 03, 2008
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
A one inch black line down middle of tv on my lg 42 plasma and some times two lines
The LG plasma TV with the black vertical bands, may be the bad connections, you can try to reconnect the cables on the X board. If the bad connections on the panel side, you need to replace the panel.
May 08, 2010 | LG Televison & Video
Got black line in the middle of my 42 inch plasma screen
Perform the following tasks:
Determine if the "line" is an external cause or internal.
By external, it means a result of the interface, cabling or other boxes that are connected to the set.By internal, it means a defect within the hardware or software of the set itself.
Do find out you must disconnect everything but, say one video source. The best would be to unplug, pull everything from the back or front of the tv .By a process of elimination you should be able to convince yourself the source of the vertical line is external to the tv or internal to it.
Then, once you have decided that, you can attack the place that is most likely to be the source. For example, some of the early sets had some non-standard processors and had to be upgraged to the new standard after they were purchased by the consumer. It had to do with the HD and HDMI interface connections, but could have effected other stuff. Also, some S video inputs have glitches in them.
Aug 30, 2009 | Samsung PS42P2S 42 in. Plasma Television
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Black line down screen
hello, your tv has either the lower or the upper buffer defective, worst case scenario is the screen but only a tech with the skills can determine wich one is bad.
good luck
caypianan@yahoo.com
May 20, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Black Vertical Lines in screen
All I can tell you is that you maybe have left your T.V. on a channel that didn't move for so long, or maybe someone else did and it burnt the screen. Plasma's run off of plasma gas to create the great picture and they collect on the screen and stick. What you need to do is go to your menu and look for "screen burn protection" and put it on white and let it sit for 20 minutes. All of one color such as white doesn't harm your T.V. The only way anything burns is like a bright white line in front of a black background.
Oct 26, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Blue pilexlation on 42 inch samsung plasma
there is no upgrade to fix this problem, you need to adjust the VS-voltages and the V-scan voltages
Jul 17, 2008 | Samsung HP-T4254 42 in. Plasma Television
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Pioneer PDP-425CMX 42" Plasma Tv
Try the scan PCBs that run down the side and the connectors that hook them up to the rest of the system. That would be my first place to start.
Unfortunately I don't have service manuals for non-european models. What is the date of manufacture?
Nov 16, 2007 | Pioneer PDP-425CMX 42 in. Plasma...
Televison & Video Logo
32 people viewed this question
Henry  Thomas
Henry Thomas
