Bulova Watch Logo
Dave Keanie Posted on May 28, 2010
I have a crane & viceroy radio controlled watch with no instructions and can't set the time? what do i do there are 3 buttons but which one to press to adjust the time to uk?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
932
Points
Just try the botton and then you will know
I have a Crane Viceroy watch which is radio controlled. It says on the back glass back, stainless steel case. How do I remove the back. It has no screws or indent to prize it off. Thanks
Question edited for clarity.
It is probably a screw back. This is always my advice.
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted by ADMIN... on Dec 31, 2018
Alternatively, they all work to a theme
https://www.google.com/search?q=crane+viceroy+watch+remove+back+cover
2answers
Require instructions on how to reset my Crane & Viceroy radio controlled watch details as PH16251 & cvw0002
Hi, to reset, remove battery, short out the -ve battery spring terminal to the ATM movement, this is the part of the watch in the centre of the lower part of battery holder, it has a small access hole through some clear insulator material. You need to pull up the battery spring a bit to see this. use tweezers to short it out. This discharges the watch circuit and resets it.
hope that helps and thanks for using fixya!
Sep 05, 2011 • Watches
1helpful
Crane & Villeroy watch (radio controlled) After fitting a new battery it shows the time 1 hour behind the correct time.
It sounds like your watch is on daylight saving time (DST) or it is set to the wrong time zone.
If you press the "Mode" button you will enter the settings menu and you should be able to change this by pressing one of the other buttons. Some experimenting will be needed.
Sep 18, 2010 • Watches
Setting analogue time on a Crane & Viceroy Radio controlled watch
I haven't been able to locate your watch but since watches tend to be similar in operation, I suggest that you look at the instructions for my watch and try a similar settings.
Go to "http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2735.pdf" and instructions for a Casio watch will appear. Go to page 4 and read instructions under "to adjust analogue time".
Mar 30, 2010 • Watches
6helpful
3answers
It has a new battery now i can't reset the time it is a crane viceroy radio controlled fintan
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all LA CROSSE watch manuals. Rate me, please
1helpful
I have a Carne & Viceroy Radio Controlled Watch reset time
I went to How To Mend It Site and I fixed the watch in ten minutes and it was free I expected fast response from you because of the charge.
Dec 18, 2009 • Watches
Having fitted a new battery I need to re-set a Crane & Viceroy atomic watch but cannot find the re-set button.
The reset is typically not a button. If you look at the back lid with the watch open you might have instructions to reset or "AC" the watch. Usually this involves using tweezers or lever to contact the battery and circuit board to clear it. My suggestion for this procedure is to see a watch maker/technician since the circuit board is easily damaged.
Sep 15, 2009 • Watches
3helpful
3answers
Crane and Viceroy ladies RC watch
Hi, Klik and Crane & Viceroy are excellent and robust watches, but due to the radio control batteries need to be changed more often than ordinary watches. Instructions for resetting the time on a Klik or Crane & Viceroy watch. With the watch face upwards and the buttons on the right assume the buttons to be; top button - "A", middle button "B" For setting the watch to GMT all hands need to point to 12 oclock exactly. To achieve this press Button A until the hands start spinning. Stop the spinning when the time reaches a couple of minutes before 12 oclock by repressing A. Inch the time forward by repressing Button A until all hands are at 12 oclock.(EXACTLY). Press Button B within 10 seconds and the time will advance 1 hour and stop. The radio signal will be picked up automatically and time will set itself in a few minutes. Notes: If you have radio dead spots avoid these when resetting the watch and do it away from magnetic or large metal objects. i.e. trays etc. If you are refitting a new battery and have a battery that isn't quite dead, do the advancement of time with the old battery and fit the new one near to 12 oclock to get the best life out of the new battery. If for any reason you want the watch to be in radio mode but read a time other than GMT ( no adjustment is needed for BST ), then instead of stopping the watch at 12 oclock stop it at the time in relation to 12 oclock. i.e. if you wanted the watch to read 30 minutes fast then stop the watch at 12.30. if you want any other info my email is; [email protected]
Jul 15, 2008 • Watches
2helpful
2answers
Klik r c watch.
problem solved.
regards.
Matt.
Apr 17, 2008 • Watches
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
