Question about Whirlpool GU2200XTSS Built-in Dishwasher
One day the diswasher was working fine...the next time it turned it on it ran for about 3 min. then shut off and seemed to have no power. I checked the breaker...it was fine. A few days went by and all of a sudden the lights were blinking on the panel. So I pushed the cancel drain button. The water drained out and I then proceeded to load the dishwasher and turn it on again thinking it was just a fluke when it shut off earlier in the week. It did the same thing...ran for about 3 min and then shut off.
5 Suggested Answers
SOURCE: Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Posted on Nov 24, 2007
  • 220 Answers
SOURCE: the clean light is blinking diswasher won't start
Push these buttons in this order High temp wash > Heated dry>High temp wash >Heated dry all the lights will come on and this will reset the board and run it through a short test cycle but more than likely it will come up again,It's a failure in the heating cycle either the heater itself or the turbidity sensor which sits mounted up into the tub right behind the drain pump...hope this helps
Posted on Sep 13, 2009
Testimonial: "i tried the sequence of buttons that was suggested and my dishwasher reset itself and is now washing!!!"
jan mczeal
  • 632 Answers
SOURCE: 'clean' light flashes
Press the normal wash then heated dry buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Posted on Oct 18, 2009
  • 155 Answers
SOURCE: The dishwasher won't start, its stuck, pots/pan
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Posted on Apr 07, 2011
Jet ski loses power when it gets hot
are all cylinders working ? carbs might need cleaning ! what compressions have you ? 100psi min !!
Nov 15, 2013 | Tempest Kawasaki Jet Ski 1100cc JT1100 STX...
2004 900 efi mountain cat no start, seems like no spark
try unplugging the throttle switch to see if its ok. then of course replace...thats a quick sled
Sep 01, 2017 | Arctic Cars & Trucks
This problem started about two weeks ago. when i started the car and left the house it was running but the rpms would drop and the car would shut off but start back up immediately while going tdown the...
This is a good indication of a bad ignition control module. The module is located under the coil pack (where all of your spark plug wires come from) and may be testable. Auto Zone says they can't accurately test this part but it is $100 to replace it.
Mar 05, 2010 | 1991 Buick Park Avenue
75 Stingray stalled while driving
Sounds like the ICM is going bad.(Unless for some weird reason you have points)It is locate inside the distributor.
I had the same problem on my firebird after it was parked for 3 months,the heat grease just broke down and allowed it to over heat.
You should also check the fuel screen on the fuel inlet.
Please rate this a fixya
Jan 30, 2009 | 1986 Buick Regal
Engine kicks and almost starts but does not
you need to double check your timing ound like you might be a tooth off
Dec 05, 2008 | 1996 Ford F150 Regular Cab
I have had a panasonic DLP PT-60DL54 for about 3 1/2 years and up til now its worked fine. The first time I seen a problem the tv shut off after about 5 mins and a fast clicking sound was coming from the...
This is an old posting, but will reply anyways.
I am not sure if this is the same problem that I had , but sounds similar.
I found that there were power surges, or lack of power. I could see my power bar blinking at the time this happened.
So after trying everything under the sun, I plugged it into another outlet with the power bar, and have never had a problem since. It seemed that for some reason I had surges in that line, and have no idea why.
Not sure if this is what is happening to you, but maybe might be of some help to someone else.
Thanks.
Bob.
Nov 21, 2008 | Panasonic PT-60DL54 60" Rear Projection...
Running long time
hi thanks for the question. yes if that's the temp that you say 36 to 38 degrees is normal operating temp thanks the appliance doc
Sep 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Tv shutting off on its own.
Was talking to one of the experts on the "chat live now" tab and he suspects a power supply problem. Who knows??
May 02, 2008 | Panasonic PT-60DL54 60" Rear Projection...
Whirlpool GU2200XTSS Built-in Dishwasher Logo
24 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
