Question about Bissell LiftOff Revolution Pet Vac 37602 Vacuum
Just quit running while in use - Bissell LiftOff Revolution Pet Vac 37602 Vacuum
My bissell just quit. No smell. Don''t understand. Had a new bag.
Posted on Jun 27, 2011
No power - vaccumn quit running
The motor is burned out or the brushes in the motor coil need to be replaced.
Sep 09, 2014 | Dyson DC28 Animal Upright Vacuum New DC 28...
My Hoover UH70604 vacuum just quit running.
have u check the cord for frays specially if this is a older unit or the switch for false contacts...hope this help u.thanks
Nov 12, 2013 | Hoover Remedy Multi-Cyclonic Upright...
Motor quits
Does it come back on right away or do you have to wait a while. It could be faulty thermal sensor because it should not overheat in 30 seconds. Probably will need to replace motor if so.
Nov 03, 2013 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Have a rainbow e-2 that was running and quit.
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Apr 25, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I have to reset my Beam Central vac quite often!!!
Check to see if there is a clog in the system. Something is causing stress on your motor causing it to switch off. Or it could be the motor itself failing.
First check for a clog, if you can't find anything wrong, call Beam for assistance
Aug 21, 2009 | Vacuums
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Rainbow d4c
If it just quit running, it could be the cord. If you have a meter, you can check it to make sure it isn't broke. Take out the 4 I think, screw from the bottom, the top half should come off, then you get to the switch and the end of the cord. Check the motor brushes also, if they are worn down, they may not be conducting and the motor won't run. It gets involved, so don't know if you want to do this at home.
Feb 24, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Bissell LiftOff Revolution Pet Vac 37602 Vacuum Logo
149 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
