Question about SansuiM1315 TV
Cable tv on a 1315
My cable tv only works to channel 19 also how can i program channels have a universal remote and no manual thank you
  • lou_lou009 Mar 03, 2009
    I have a universal remote for my TV and I need to program my tv to cable but there is no menu button on the tv and the menu will not appear with the universal remote I own. I was told to hold both the channel buttons down and the menu should appear but no menu showed up???????
  • 4,234 Answers
You have the set in standard air mode rather than cable mode. I am not familiar with your particular model, but you should be able to switch it to cable (assuming that it is cable ready). Check for a switch on the back or front. If there is no switch, there should be a menu option for changing the set to receive either over-air or cable. Check under the setup menus.
Dan
Posted on Apr 08, 2008
I can't get the TV to input to watch my cable. I no longer have the remote and have gone through and saved every channel but still cannot locate the input channel.
Most tvs won't let you switch to imput without the remote, you could try looking under the menu on the tv but if it not there then I would suggest you buy a universal remote. Or a lot of cable remotes allow you to program them to the tv.
Jun 17, 2011 | Philips 19PR19 19" TV
I tried to program my Toshiba TV Model 27A43 to a new Universal Remote, because the original Toshiba remote was functioning more+more slowly ( I changed batteries on the original Toshiba remote first)...
Yes do a complete new channel scan. Play this like you just got the TV. If you want to buy the OEM factory remote you can most likely get it at the link and avoid all this hassle. Follow the link below. 1 800 Remotes
Mar 28, 2017 | Vacuums
I have a mitsubishi tv model cs27200 and I dont have a remote. I got a universal remote but it wont bring up the menu. I need to program the channels for cable. I only get local channels without bringing...
You would need to look up how to program that remote to your specific tv. I would look up the owners manual if you dont have it for the remote...and follow the instructions for it. However, you will have to directly use the tv to program it to the cable. The universal remote will only change the channels and volume for you. Use your menu button to bring it up, make sure its set to cable and not antenna, and use your channel + and - to navigate through the menu and vol + to select your option
Nov 20, 2010 | Televison & Video
I cant to program my cable channels with my univ remot sony tv
do it manually, front panel controls, or buy sony brand universal at wallymart
Jan 01, 2010 | RCA Universal Remote Control
I have a 19'' older (approx 1999) Sharp tube TV that won't show the cable channels even though the cable is hooked up to the tv (the cable has been tested with another TV and works perfectly). There is no...
Even with the TV in the wrong mode, you should be able to see some channels lower than 12. Try that first and report here what you see. If you can get a few in that range (2-12) but nothing else, then the TV is in broadcast mode not cable. You will need to change it to cable mode to get the remaining channels. You should be able to locate a universal remote for $5 or so that will allow you to get into the menus.
Dan
Jun 18, 2009 | Sharp Televison & Video
Lost remote programing directions
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Dynex 19" tv
Go into the setup screen on the TV and set the channel option to CABLE (it is probably set to AIR right now or something).
The website should also have a manual for how to program the remote.
Sep 08, 2008 | Dynex 19 in. LCD Flat-Panel HDTV
Programming my rca universal remote for basic cable the stations wont turn
I can only suggest that you Double check you have the connections correctly set ie. coax ariel to ,(dvd /digi box reciever ect...)
Also check again (& i know this is state the obvious)
your tv manual. IF you havent a manual do a google search for your tv (make & model) & search for a manual.
Ive have had a simmular experience when programming channels to a Vid-Recorder & when i finished the channels dissapeared.
I realised I didnt have the video set to the correct channel with the tv usually channel 9 or the highest channel on the tv.
So i waisted a good half hour for nothing.
Dec 09, 2007 | RCA Universal Remote Control
Program universal remote
check remote first, and replace ir ditector in the tv...
Sep 28, 2007 | Orion1934 19" TV
Problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
Sep 11, 2007 | Sharp 27K-S100 TV
SansuiM1315 TV Logo
197 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
