Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Had a power surge and now the lamp notification is on steadily
Had a power surge and now the lamp notification is blinking steadily. The TV will not turn on. Have a surge protector. Have unplugged TV for several days, and reinstalled the lamp. Model WD 52725
Looking for a reset switch?
  • 116 Answers
This is a common problem and usually shows up when power is interrupted. The capacitors in the micro, digital, and power supply have to be replaced. In my shop, we prefer to send the chassis to Mitsubishi and they repair it. Do you have a local authorized Mitsubishi service center near you?
Posted on May 28, 2010
Blinking red light in front of tv (lamp) and noise coming from tv as well.
The Lamp light of the TV blinks when the Lamp of the TV requires replacement. The model # of the user replaceable lamp block is XL-2200. You can download the manual of the TV by clicking here. Refer to page # 76 of the manual for further information. Follow the steps below to perform a power reset first:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 17, 2011 | Sony KDF-E55A20 55 in. LCD Television
Red standby light is blinking 8 times on my sony bravia tv
I simply followed these steps with a surge protector
press the power button and hold up
Then hold up with the power button
then let go of up
and let go of power
worked with my kdl-55ex720
Jul 16, 2011 | Sony 55 KDL55EX720 3D LCD TV
I have a sony 65 in. sxrd projection tv that has the red power light blinking and the tv won't come on?
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Jul 16, 2011 | Sony Televison & Video
Flashing red lamp light on front of my sony tv model # kdsr60bxr1/ no picture , no sound
Jul 14, 2011 | Sony KDSR50XBR1 50" Projection HDTV
Tv shuts off,standby light blinks 5 times repeatedly until tv comes backon
Mar 14, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony 3 lcd rear projection tv hd w/ wega gate. kdf-e42a10. tv will atempt to turn, shuts down, greem power light blinks 12 times on average. red standby light blinks 4 times. i replaced lamp [ xl 2400...
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
My standby light blinks 7 times ?
Feb 25, 2011 | Sony KV-40XBR700 40" TV
I have five (5) blinking lights from the standby lamp, what does it indicate?
Jan 28, 2011 | Sony KDS-R50XBR1 50" HDTV
Green power light blinks for 1 minute then the lamp light blinks
When Lamp of the TV has been blown out, the LAMP light blinks in red.
When there is an internal malfunction in the TV, the Power led blinks and there will not be any picture on the screen.
Since, both are happening with your TV, it seems that there is an internal malfunction. Hence, your TV requires service.
You may try the following troubleshooting steps before getting the TV serviced.
Disconnect the Power cord from the Wall outlet and connect it to a different working wall outlet.
Disconnect surge protectors if you are using.
Then try resetting the TV to the Factory default settings to check whether the issue is resolved.
Jul 14, 2010 | Sony KDF-E42A10 42 in. LCD Television
My mitsubishi wd-62525 turns itself off and the status light steadily blinks red. Tried unplugging and using the system reset, however it does the same thing after having it on again for about a minute. I...
Check to see if the Lamp is shattered. If so replace it and it will probably work. If not, you
will need to get a Professional out to determine if it is a Optical Block issue or a bad Main Board.
Aug 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
237 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
