Question about SanDisk 4GB microSDHC Memory Card
How to remove write protection from a sandisk hc memory card
    President:
  • 1,070 Answers
Hello Friend,
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus.
  • Change the Usb Port(Recommend you to Use Backside Port)
  • Change the Cable
  • Restart PC
  • Still have Problem Change Card Reader..
Hope this Helped you..Thanks for Contacting FixYa...........
Posted on May 28, 2010
  • 503 Answers
The SD Cards' "Write Protection" issue is not a software issue or any computer related problem. It is not the problem with your SD card either. The real problem lies in the Card Reader itself, a stuck WRITE PROTECTION SWITCH in the card slot. Peer inside the slot and you can see on the left a copper lever switch. This is the WRITE PROTECT SWITCH.
If your card reader is out of warranty, you might want to do this simple repair yourself to save bucks:
Loosen the screws and open up your card reader. If you can have access to the card slot metal cover, you can see that there is a certain hole on the left just outside the copper switch we mentioned awhile ago. Confirm the location of the switch and if it is in line with this hole by peering once more inside the card slot.
Now insert a needle or a pin inside the hole and push slightly the lever away from the card slot wall, being careful not to breack the switch. This will cause the copper lever to bend slightly inwards from the card slot.
Test if you're successful with this repair. Without the cover on, connect the card reader to the computer and insert the SD card. If you can now manage to manipulate your files by erasing them, or formating your card, then you're done. Replace everything back inside the cover, and your done!
Please post your feedback and Vote if the problem resovled as per your satisfaction
Remove write protection on 8gb sdhc card
SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 23, 2014 | Electronics - Others
How can i remove write protection from a SD card that I just purchased?
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 06, 2012 | SanDisk 16gb Sdhc Sd HC Flash Memory Card...
When I try to synk music it tells me I cant because is write protected. How do I cleared it?
1. Be sure that the device you are using the 4GB micro SDHC card for,
is able to use this type (HC=High Capacity) of memory.
2. Check the memory card is working well on a notebook / pc with an adaptor
and/or a SD-cardreader.
3. Format the memory card and re-check.
Nov 13, 2011 | SanDisk 4GB microSD High Capacity Memory...
Plz help me to remove write protection from my micro sd card.
Hi, slide up the Write protection switch which is white in color for the Memory Card Adapter to remove Write protection and Slide down to enable write protection of the Memory Card.
Please click on the link below to view the Write protection switch:
http://kb.sandisk.com/euf/assets/images/faqs/id1102_e3sdhc.gif
If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Apr 16, 2011 | SanDisk 2GB microSD Memory Card
Somehow we locked our Sandisk Extreme SD HC 4gb card. And now when we put it in the camera, it says card locked. Can anybody help how to unlock it?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 03, 2010 | SanDisk Extreme III 4GB Secure Digital...
When i open my digital camera with the card inserted (4GB micro sd HC) then, it is displayed as WRITE PROTECT and cannot proceed further. Please provide solutions.pleaseee
If that doesn't work, try another card.
Oct 24, 2010 | SanDisk 2GB microSD Memory Card
Sandisk 8gb micro sc hc card when i go to my files on my phone its saying memory card needs formatted all data will be erased....how do i fix it... my computer wont recognise it anymore either
try to remove your card safely from ur phone it occurs when u remove ur card without switching off or safely remove card, ur mem card is corrupted so reformat it, if there is any imp files then use a recovery software.
Nov 28, 2009 | SanDisk 2GB microSD Memory Card
SanDisk 4GB MicroSD HC Memory Card is not recognized by my Sansa
sd utility.exe u download from google it wil dolve u r problem.......
Sep 29, 2009 | SanDisk 4GB microSD High Capacity Memory...
Write protection won't allow me to download music
On the left side of your SD card you have a micro switch on it and must be on the upper position. On the down position your SD card is write protected !
Dec 16, 2008 | SanDisk 4GB microSDHC Memory Card
SanDisk 4GB microSDHC Memory Card Logo
917 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
