Question about Danby DDW496W Free-Standing Dishwasher
Danby ddw496w I got my danby ddw496w in the mail today and got all put together except for the drain hose connection. It wont attach or screw on to the area it is supposed to. help please.
  • Anonymous Apr 08, 2008
    do you know which hose is the drain hose connection? they arent labeled.
    One is a thin hose and the other has a big plastic turning knob. one is the water inlet connection and one is the drain hose connection. there are no pictures of which is which.
    Genius:
  • 3,422 Answers
HI,
You can email the company and ask for a service manual this will fix your problem.
Goodluck,
Please don't forget to rate the solution as fixya.
Posted on Apr 08, 2008
  • Danby Master
  • 19,396 Answers
Maybe you have the wrong part , contact danby and ask a replacement
Posted on Apr 07, 2008
  • 1 more comment
  • Ginko
    Ginko Apr 08, 2008
    I tried to find service manual but there is none. you need the part number, so that you can ask the replacement. If I find any schematics or manual I will post it here.
  • Ginko
    Ginko Apr 08, 2008
    Put your model number here and check if they have the parts in stock
  • Ginko
    Ginko Apr 08, 2008
    I also found a manual for the 396 , which is similar, showing pictures of the connection.
SOURCE:
I have a danby ddw496w that leaks water from the bottom of the machine when it goes into the drain cycle.it will start coming out the bottom as well as the drain outlet .Could it be a simple hose...
Ditto- same issue, hoses are tight, just leaks through the bottom while draining. Anyone with advice? I just bought mine used, and the previous owner is willing to buy a replacement part, we just have to figure out what we need...
Sep 25, 2011 | Danby DDW496W Free-Standing Dishwasher
How do I switch from continuous drain to draining into the bucket? I have a Danby Pro dehumidifier. Thanks Tyler
Disconnect the hose and reattach the hose connection drain cap, that was removed when the hose was attached. The water will then be diverted into the water collection bucket
Hope this helped you, Tyler and thanks for choosing FixYa.
Aug 01, 2011 | Danby DDR5009EE Dehumidifier
My air conditioners is a everstar model mpa-08cr, and i need to instal the water hose on the side of unit.
Hey there, just follow these simple steps then you'll be on your way
To connect the continuous drain option. Remove
the water tank from the cabinet. Inside the
cabinet (water tank area) you will find a section of
hose hanging beside the water tank, which is plugged
at the end. Remove the plug
from the end of the hose and install the drain hose connector
(included with this unit) into the
end of this hose section. Route the end of the
hose (with drain connection) into the water tank,
then through the hole provided in the face of the
water tank. Attach a section of garden hose (to
suit your continuous drain option requirements)
to the drain hose connector. Place the open end
of the hose directly over the drain area in your
basement floor.
Please make sure the drain hose
section routed through water tank does not interfere
with the correct positioning of the water tank inside
the cabinet, or the will fail-safe switch mechanism will
be activated, not allowing the unit to operate.
Jun 19, 2009 | Danby DPAC8020 Air Conditioner
Soap suds and some water not draining out of washer after cycle is complete
if you read the manual, it states that this is normal. so dont let this bother you
May 05, 2009 | Danby DDW496W Free-Standing Dishwasher
Danby continuous water flow will not work on a dehumidifier it still fills the bucket
Please try the following:
1) Remove the bucket.
2) You will notice a round outlet/spout where the water drips from into the bucket.
3) Remove the plug from the backside of the unit (you will now see a hole to the bucket area).
4) Feed a hose through the hole from the back and attach the end of the hose to the round outlet/spout.
5) Place the other end of the hose on a floor drain outlet.
6) Put the bucket back into the unit.
When the unit is turned on, the water will now flow through the hose instead (into the floor drain). When you want to use the bucket again to capture the water, you will need to remove the hose.
I hope that helps.
Apr 25, 2009 | Danby DDR601 Dehumidifier
E3 code
Received from Danby customer support:
"The error code of E3 tells us that the unit is not getting the proper water temperature to continue thru the entire cycle. Before starting the dishwasher and attaching the quick connect assembly to the faucet, please make sure that the water from the faucet is warm to the touch; you can then attach the quick connect assembly with hose to the faucet and start the unit. If the water temperature does not reach 120 degrees F the dishwasher will not be able to run thru the entire cycle properly. If this is being done and the same code comes up, we will need a service tech in you area to diagnose the problem for us. For a warranty servicer in your area you can reach us at 800-263-2629 Mon-Thu 8:30-5 or Fri 8:30-4 EST."
Jun 11, 2008 | Danby DDW496W Free-Standing Dishwasher
Danby ddw496w
Havent solved it yet. Have to call the Danby 1800 number to see what I need to do.
Apr 07, 2008 | Danby DDW496W Free-Standing Dishwasher
Danby DDW496W Leaking Brand new
Check your hose connections in the back for tightness and sealing (there should be some rubber seals inside the screw-in connections) and if tight and not leaking, you might have a loose clamp inside the unit, or a leaking/damaged hose, or even a defective/leaking pump. If it is brand new and returnable I'd return it for a new one rather than try to fix it...
Apr 05, 2008 | Danby DDW496W Free-Standing Dishwasher
Danby DDW496W Free-Standing Dishwasher Logo
201 people viewed this question
Top Danby Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Brian Acker
Level 1 Expert
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
