Question about Dometic Rooftop RV Air Conditioner
Replacing AC blower motor
I am trying to replace the AC blower motor on my trailer. I can not determine how to get the old blower out. Can someone help me?
  • 1,343 Answers
ITS CALLED SURGERY take picture as ya go and have a big bucket for screws. make sure you have your motor and capacitor tested first before you replace it unless you know its bad (hp,sf &rpm must match !!!! on new motor ) little guys are real expensive and are a three speed motor and must be hooked up right or you will burn it UP ! do this in the shade cuz it aint no fun in the hot sun(me Florida) the first thing i would do is oil the motor then have the capacitor checked , the motor may not need to be replaced just serviced ?.. hay now if'n i was any help write a review of thanks or just VOTE,, MOTORWIZJ ..FL
Posted on May 28, 2010
    Problem Solver:
I recently replaced the blower motor, blade fan, and blower wheel on my Dometic 57915 rooftop AC. Not a hard job if you are moderately mechanical. Look up the schematic diagram to see how everything goes together and know what part is what. First remove the shroud, condenser cover, and evaporator cover. This will provide access to the motor, blade fan, and blower wheel. Spray some PB Blaster on the motor shaft where the blade fan and blower wheel attach to make later removal easier. Loosen the screws which tighten the metal retainer rings which keep the fans mounted on the motor shaft. Remove the three nuts which mount the motor to the metal housing. Remove the 'foot' which support the bottom of the motor to the floor. The motor can now be pulled away from the metal housing which is around the blower wheel. The blower wheel will prevent you from completely removing the motor. With a small pry bar, using the metal of the motor as the fulcrum point, pry the motor away from the blower wheel/metal blower housing. The blower wheel will pop off and stay inside the housing. The motor is now free to remove except for the external wires. If you need to replace the blower wheel, loosen the 3 screws which hold the evaporator coil to the housing. The coil can now be moved slightly forward which will allow the old blower wheel to be removed and the new one inserted. Remove the blade fan by holding the blade fan next to the motor shaft, allow the motor shaft to hang vertical, tap the motor shaft on top allowing the weight of the motor to pull the shaft out. If you are replacing the motor and it came with a new capacitor, the instructions are wrong. Run the white jumper wire from the common terminal of the old capacitor, connect the other end of the white jumper to one (doesn't matter which one) of the terminals of the new capacitor, connect the white wire from the motor to this same terminal of the NEW capacitor (there will now be two white wires), connect the brown motor wire to the other terminal of the NEW capacitor. The run blower motor side of the OLD capacitor will not have any wires to it.
Posted on May 21, 2013
2004 crown vic. only 63K miles on her. AC/heat fan was sporadically working, now its done. AC was nice and cold, working fine. Is the fan a hard replacement if I were to find one at a parts yard?
Try to check the power and ground on the blower fan. If you missing the ground on the blower fan connector than most likely it is the blower fan resistor (controller), it is located under the hood close to back firewall behind left cylinder head.
Aug 17, 2015 | 2004 Ford Crown Victoria
2003 Toyota Corolla AC Blower/Fan will not turn on, I replaced the Blower/Fan a few weeks ago,
A/c compressor works fine and the blower motor works and shutdown right? it is the problem with the blower resistor or with blower motor relay. try to direct the resistor irrespective of the speed. hope the problem may be solved.
Jun 05, 2014 | 2003 Toyota Corolla
I have a 1995 jeep cherokee sport 4wd 4.0L with air ps/pb/cc/abs. I recently (2 weeks ago) lost all ac/heater blower speeds except high and now 2 of the wires to the ignition switch get so hot with the...
Never just replace any item because someone suggested it may have failed. Before replacing anything, you need to check each item for any signs it's bad. In addition to what I mentioned, the blower motor itself can also cause a problem if it is worn out and is drawing too much amperage to operate. If the blower makes any noise or the wiring becomes warmer than it should be after replacing any damaged parts, look at the motor. Bad motor ground can cause problems as well so check that too.
May 18, 2010 | 1995 Jeep Cherokee
Blower motor on 95 olds 88 stays on
Look for the blower motor relay in the relay box,it most likely is stuck in closed position,replace it with a new one.
Aug 28, 2009 | 1994 Oldsmobile 88
No A/C.
It maybe the blower motor. Determine if the blower motor is getting ac, if not getting ac to the blower motor then there might be a breaker, which would probably be located somewere near the motor, or the motor has an internal breaker or fuse.
Aug 13, 2009 | Heating & Cooling
Noisy Blower Motor
could be trash leaves acorns ect in housing that the blower is picking up then dropping when the unit is off. try cleaning the housing the motor fits into
Aug 04, 2009 | Buick LeSabre Cars & Trucks
AC unit wong start unless I spin the blower
you have 2 windings that are in you motor,One winding is the start winding It give the motor its initial boost that gets the fan spinning.The other winding is the run winding and it takes over and keeps the fan running.So it sounds like the motor is bad because the start winding is not giving the boost it needs to start. good luck--Nate
Jul 15, 2009 | Coleman Mach III Air Conditioner
No power to heat control or blower motor
R u sure u tested it correctly? There will be a 30 amp fuse usually associated with the blower motor however u need to look at the motor connections with a meter set to ac. These newer cars use a pwm type drive which is a pulsating dc voltage similiar to ac and should vary in amplitude as u turn ur control for speed. If u have that then ur motor is bad and has to be replaced.
Mar 02, 2009 | 2000 Oldsmobile Intrigue
Dometic Rooftop RV Air Conditioner Logo
859 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
