Question about TVonics STB100 Freeview DTV Receiver
I have lost the pin for my tvonics digital recorder and need to re tune
Bought a tvonics freeview dtr-hv250 digital tv recorder, keeps coming up but it wont allow me to record. keeps saying the hard drive is unformatted. done what it says on the on screen instructions but
Go to your on screen menu under dtr settings and format the hard drive. If you have been recording the hard drive may be full and some programs need to be deleted to allow more recording space. You may also unplug the unit for several minutes and use the reset box option.
Jul 28, 2016 | TVonics Televison & Video
My mother has a Panasonic DMR-ES20D DVD recorder it plays back DVD's ok but has lost all tuned channels. When performing a auto tune it gets to ch 53 and appears to hang with error code U80 in the dis
could be its not digital, so it will not pick up any channels as they are now all digital not terestrial through the aerial like the y used to be. you need a digi box now to plug the recorder into
Dec 11, 2011 | Panasonic DMRES20D DVD Recorder
Unable to record any BBC channels on tvonics dvr
I had this problem and did 'Menu' then 'Settings' and 'Reset set top box'. This will lose your channels and timers, but the recorded programs will still be there. After I did this I could record again on BBC!
Jan 07, 2010 | Televison & Video
No user manual for CE28DN9-B. Bought TVonics
HELLO
Follow these instructions:
Select a spare channel on your TV say 6 on your remote.
Press MENU.
Scroll down and select PRESET.
Using RIGHT button of F/OK/ENTER press it and this will go to TUNING.
Press RIGHT button again which will let you go to SEMI or AUTO tuning (for your purpose select "SEMI").
Scroll DOWN to highlight the actual UHF channel number or CH:C21 as it may appear on the screen.
Press the RIGHT button again yourself manually and you will see the channel number change anywhere from 21 to 69 until you come to your freeview box's RF channel output.
When you have done that scroll down to Memory and you'll see a box beside it. Press the RIGHT button and a tick will appear in the box.
You have stored your Freeview box RF channel on your TV.
Press MENU button THREE time to come out of the MENU setting.
Use this procedure again if you wish to change the RF channel on your TVONICS box.
GOOD LUCK (:-)
Oct 03, 2009 | Televison & Video
Thomson DTH 7000 DVD hard disc recorder
there is no digital tuner built into this unit as I own one
Jun 06, 2009 | Televison & Video
Just installed new tvonics250 freeview + box
I have one of these boxes and one of the things which has caught me out a couple of times is that the remote can control three devices. To turn the Z250 on and off you may need to press the DTR button at the top of the remote first. When you press the on/off button on the remote the DTR button should light up red to let you know the signal is being sent to the Z250.
You are probably aware of this but just in case you weren't
Mar 02, 2009 | TVonics Televison & Video
Lost cable
USB Cable (KP-10) is the model number of the cable you need for this recorder.
Dec 18, 2008 | Olympus VN-480 PC Digital Voice Recorder
TVonics STB100 Freeview DTV Receiver Logo
94 people viewed this question
Top TVonics Televison & Video Experts
 Mikey
Mikey
Are you a TVonics Televison and Video Expert? Answer questions, earn points and help others
