Question about Acer Aspire One PC Notebook
I have a laptop, when I turn on, the screen remains off
I tried installing a monitor on a laptop, but its doesn't work,
help me please
  • 108 Answers
Install a Proper Graphics Driver to your Laptop. Before that you have to Install Chipset Information Driver of you driver.. Visit this site to get all those drivers..
http://www.acer.co.in/acer/service.do?LanguageISOCtxParam=hi&miu10einu24.current.attN2B2F2EEF=3350&sp=page15e&ctx2.c2att1=158&miu10ekcond13.attN2B2F2EEF=3350&CountryISOCtxParam=IN&ctx1g.c2att92=856&ctx1.att21k=1&CRC=670790123
Posted on May 28, 2010
I turned on my labtop after repalcing the power inverter and the screen is still dark
Hi brylindo.
Try hooking your laptop to an external monitor...if the picture comes on then it is an lcd screen problem...if it doesn't come on then re-down load your drivers and see if that solves the problem...if it still doesn't work then you may have a problem with the laptop electronics.
Please take time to rate me
Sep 13, 2011 | Toshiba Satellite P105-S6197 Laptop
I have a Dell inspiron 5100. When I try to turn it on, it just stays blank. It shows the Dell and Windows logos, but the screen where I'm supposed to choose my user account doesn't appear.
Are there any error messages displayed? Does the laptop switch off, or does it still remain on? (are lights etc. on?). Also, have you connected to an external monitor recently? I suggest attempting to connect to a monitor or TV using the S-Video or VGA connectors on your laptop, this should get the login screen to show up.
Jul 05, 2011 | Dell Computers & Internet
Please help, My laptop Toshiba Satellite L645 blank screen when turned on, there is absolutely no view. please help me ..................
Can you tell if the laptop itself is turning on?
If not then there is an issue with the laptop.
If the laptop is turning on then try plugging in the laptop to an external monitor and see if you get anything on the screen. If the laptop works normally with the external monitor then you will need the screen replaced . If the laptop still shows nothing on the external monitor then you will need to repair your laptop.
Please rate if this helps
Mar 14, 2011 | Computers & Internet
All the lights turn on on the hp pavilion dv1000, but the screen remains black. Almost as if there was no power going to the screen. I have tried reseating the RAM and the HD. Problem still remains. ...
Hook a external monitor to the video output on the back of the laptop, if okay! there is a LCD problem with the laptop screen, causes! bad inverter board, or back light. If both show black! causes are Video Graphics Card that is part of the motherboard.
Jan 10, 2011 | HP Pavilion dv1000 Notebook
The screen remains black when i turn it on. The power button turns green and blinking but the screen remains black.
try using the Fn + F?key (has a graphic of a monitor)F5 or F7 to switch the system from external monitor to the laptop ... you probably have it in presentation mode for external monitor.
Oct 14, 2009 | Acer Computers & Internet
HP Pavillion 9925nr LCP monitor turns black
Check screen brightness.
On keyboard is normally activated by combined FN + Fx keys (F9 or F10).
Check your keytops and/or your user manual.
Using this feature you should be able to restore a standard contrast on your screen.
If it isn't working the only alternative is external monitor.
Feb 16, 2009 | HP Pavilion dv9000z Notebook
Motherboard issues
If you have an external monitor available, connect your laptop to it and start the machine. It would not start and shutoff if the motherboard was failing. It would not power at all or would turn on a display an error, with some beeps. By plugging into the ext monitor, you can amke sure this is not a video problem and watch it boot, until it gets to the error, which is probably a Windows Blue Screen.
Sep 26, 2008 | Computers & Internet
Screen won't come on
Please try to remove the battery and power laptop on ac. If it still happens, please try to use an external monitor like a PC monitor. If it is okay with the external display, please press on Fn+F5. If it still does not work, it's a hardware problem. Hope this works. Thank you.
Sep 25, 2008 | Toshiba Satellite A205-S4777 Notebook
Hp laptop wont restart
please connect your laptop to external monitor.
if it works with external monitor, then the problem is with your laptop monitor driver.if that is the case, then re-install laptop monitor drivers.
if it doesn't work even with the external monitor, then re-install graphic card drivers.
Apr 05, 2008 | Computers & Internet
Check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Feb 05, 2007 | IBM E74 17" CRT Monitor
Acer Aspire One  PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
