Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Rug Beater isn't rotating during use
I just bought this vacuum and the third time I used it, the rug beater stopped rotating. I have tried cleaning out all the filters and have checked that the hose attachment is hooked up properly on both ends.
  • 438 Answers
This defintiely sounds like your belt has broken or slipped off the motor pulley. The brushes on your vacuum are driven by a belt that attaches to the motor shaft on one end, and the roller brush on the other end.
If you really do have the Bissell 6594 model that you posted this repair under, then to check your belt, simply turn the vacuum upside down, and remove the four screws from the plate that covers the brushes. The bottom plate will then lift off, and you will have access to the brush and belt area of your machine.
You'll probably notice that the belt is either split completely, or is stretched out, and fallen off the motor shaft. Even if the belt is still completely circular, it may be a good idea to go ahead and replace the belt anyway. We recommend replacing the belt on your vacuum every 6 months even if they don't break, as they don't perform nearly as well when the machine has a fresh, tight belt on it.
The model 6594 uses the Bissell Style 7,9,10, etc. belt. It's the most popular Bissell belt on the market. If you don't already have a new belt handy, here's a link to your belt on our website if you need to purchase one:
Bissell Style 7/9/10/12/14/16 Upright Vacuum Cleaner Belts (2 Pack), Part Number 32074
Here's link to the Bissell Owners Manual for your model that will walk you through step by step how to replace the belt on your machine:
http://www.bissell.com/searchresults.aspx?searchtext=6594 &mode=userguides
I hope that this was helpful. If you have any further questions or concerns, please feel free to use the clarification request form here on Fixya, and I'll be happy to answer any of your follow up questions.
If this was helpful, please be so kind and rate the repair, or leave feedback, this is greatly appreciated by the Fixya community when a helpful answer is written.
Chris Jones
GoVacuum.com
Posted on May 28, 2010
How do I find the belt on the electrolux epic 6500. My husband picked up a scarf end, and now the brush won't turn to clean the rug. A rectangular light came on, I do not know what that means.
Turn off power. Remove the screws in the bottom plate of the vacuum head. The belt is around the beater bar inside the power head. Pull the beater bar out of its bracket to access the belt.
Jun 22, 2015 | Vacuums
The "rug mode" (when you
pull out contents - gently off beater bar. Push reset button.
Sep 03, 2011 | Kenmore 25512/ 25513 Progressive Canister...
BEATER BAR WILL NOT WORK. I ACCIDENTLY RAN VACUM OVER SMALL THROW RUG WHICH GOT CAUGHT IN BEATER BAR AND IT STOPPED AND I COULD SMELL BURNING. I SHUT IT OFF RIGHT AWAY. WHAT DO I DO?
remove the bottom of the machine, and if your lucky re attach the belt, if not replace it , you need to remove the beater bar to do this, so prior to taking it out, look at the ends so you know where they are and the positioning before you remove it for easy reattachment
Jul 03, 2011 | Miele Vacuums
The brushes stop rotating on rugs after a few seconds then button has to be pressed to start rotating again but keeps cutting out
Not sure this is your foolproof solution to the problem, but you might give it a try to see if it solves your problem.
When the beater brush starts to bind up due to debris it retards the action of the cleaner, sometimes to the point of the belt breaking.
Remove the beater brush as if you were going to change the belt. Remove all debris and clean as best you can. Pay attention to the end pieces on each end of the beater brush. They will can clogged to the point to stopping the brush from rotating. Add some WD40 to the clips at the end of the beater brush and work in by twisting the clips while holding the beater brush. Once it seems to be free, reassemble and be sure the belt is on properly, you might want to consider replacing the belt.
If you find this solution to be of help I would appreciate a Thumbs Up. Good luck and be well. Paul
Oct 06, 2010 | Dyson Vacuums
Rug beater does not work, vacuum does I just was vacuuming the rug and it suddenly stopped, beater will not turn on.
The beater bar will turn itself off if something became lodged in the brushbar area - it turns itself off so that it doesn't cause any further damage. If this is the case, recline the machine, turn it on and press the gray button next to the red power button. This is the brushbar's ON/OFF switch. If that doesn't solve the problem, call the Dyson helpline for further assistance.
Jul 11, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater bar has stopped turning
All beater and rotating brush bars are fairly easy to get to with a couple of screw on the bottom of your wan. They are driven by a belt and these belts come off, break, or the bar itself is stuck with rug material. Unplug your vacumn and get our screwdriver. It;s easy to figure out once inside the wan.
Mar 02, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Beater bar stopped working
hi welcome to fixya you need to replace belt if belt is ok than you burnt out the motor please check belt first as it is cheaper thank you for useing fixya please rate
Noisy on rugs!
Are the rugs long haired or short haired? Most likely the suction is just causing the noise when it picks up the rug and the buzz saw could be the beater bar hitting the rug then. I actually own a DC14 and it does the same thing and the rugs like to be dragged along. Nothing really to fix this, just the way it is. You could try it with the beater bar raised and see how well it works then but this sounds normal.
Have a good day
bestdarngood
Feb 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater bruch doesn't seem to be working as well as it used to
HI
Sounds like the belt has either broken or stretched. You need to replace it as per the instructuion book
Rob
Feb 09, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush roll slows/stops turning
when you removed the beater brush did you clean all the lint and threads off the ends of the brush? you can unscrew one end of the beater brush plate to clean the crap off it. Inside the beater brush are two ball bearings. Use a light machine oil to lube these two bearings. re-assemble the rod and end nut. then put your brush back in the machine and note which direction the belt needs to be installed. there'll be an arrow on the motor housing.
Sep 05, 2007 | Kirby G4 Bagged Upright Vacuum
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
359 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
