Question about Kenmore 64002 Microwave Oven
I have a Galaxy over the range microwave,mod# 721.80002401. The problem is that the vent fan doesn't work. The unit will heat food, the turntable works the under unit lights work, the display is all normal, etc. When we took the unit down we found an obstruction in the fan blades and cleared it. Still no fan. How do I find out whether it's the fan motor, or a circuit board problem? Thanks for any help.
  • Kenmore Master
  • 9,098 Answers
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, & testing.
To access & test the hood vent exhaust fan, you'll have to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you've misplaced yours, y
ou can just enter your full model number (721.80002401) at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they may ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
You can remove the oven from the wall, take off the outer cover, plug the oven in, and run it.
Then you can see if the motor leads are getting the voltage they need to run when turned on.
If your cooktop lights recently blew, the resulting surge can damage the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 30, 2010
Testimonial: "I did not find a mini-manual,but with your advice I don't get AC voltage at the motor. When I removed the pc board I see a burnt spot on the lower right center inside the area marked "LIVE PART". I think it's toast. I'll see if I can access a new one locally first, but thank you very much."
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
Glass tray turntable makes noises when heating food
Hi, the rollers on the support mechanism has residue, try cleaning the rollers and the track it follows, should resolve the sound problem
Jan 05, 2015 | LG LMH2016ST 2.0 cu. ft. Over-the-Range...
Mmv5165bas vent fan will not stop running
Check to see if there's a relay providing power to the fan. If there is, the contacts might be sticking in the closed position. Assuming that this is an over-the-range unit, disconnecting the vent fan completely might not be a good idea as heat/steam from foods cooking on the range would more likely damage the microwave.
Apr 29, 2014 | Microwave Ovens
GE JVM 1653WH01 over range microwavw: Hetas food but light, internal fan and turntable only work intermittently.
A relay sometimes gets bad connections inside and needs replacing. The door switches turn everything on and off, likeely one of the switches is bad
Nov 24, 2013 | GE JVM1542 Microwave Oven
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Microwave not heating items, also range vent not operating
the unit inside the microwave that heats called the "magnetron" has gone bad or the circuits that power the magnetron and other parts of the unit have failed. if its under warranty still, send it back to the manufacturer. if not you can call some repair shops and see how much it would be to service it, but its most likely going to be cheaper to purchace a new microwave since they are relatively cheap these days, they dont make them long lasting anymore, they are a "disposable" product these days
Jan 14, 2010 | Whirlpool MH3184XP Microwave Oven
Over the range Frigidaire Microwave not heating. Model FMT148
This is a sure sign that the MAGNATRON needs replaced (this is what heats up the food) if every thing else works but food not cooking! 99% of time it is the magnatron!
Please rate answer!
THANK YOU!
Jan 12, 2009 | Microwave Ovens
Maytag Over the oven microwave
is the turntable working
Dec 29, 2007 | Microwave Ovens
Kenmore 64002 Microwave Oven Logo
562 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
