Question about Toshiba Satellite A45-S121 Notebook
Will not boot-up, then used safe mode, I got a "stop code"
The stop code is, STOP:0X000000ED(0X81A8FE30,0XC0000006,0X00000000,0X00000000)
  • 428 Answers
STOP error 0xED means that the I/O subsystem attempted to mount the boot volume and it failed. STOP code 0x000000ED may also display "UNMOUNTABLE_BOOT_VOLUME" on the same STOP message. Problem is with the hard drive
Check this: What MS has to say http://support.microsoft.com/kb/297185
Most probably a damaged directory structure. Firs make sure that the hard drive is connected properly. Use your windows cd and boot from it. Go to Repair mode. Type Dir and if it says there is an error accessing the disk. (Directory Enumeration). Type D: (If u have a separate volume er I mean a partition) Type Dir and enter. If it shows the directory list thats fine. Type C: and go their again. (You have to hit enter after typing for every command) Type chkdsk C: or chkdsk /r C: (recommended)
Then it will scan the disk and do the repair. (There is a minimal loss of data if its damaged pretty too much). If you see that it repairs after the process type Dir and hit enter. If you see the directory list then its the time to boot the machine and its all done! If still error is shown type fixboot instead chkdsk Note: If chkdsk command is unavailable type help and hit enter to get a list of commands. Check for scandisk and use it (scandisk c:). Thats for older versions of windows.
Thanks for contacting Fixya.
Posted on May 28, 2010
Unmountable boot
Hi
You will need to get the original windows disk you was sent.
Put it in the laptop and run the 'RECOVERY CONSOLE'
this should bring up a command line, (command prompt)
Type :
1. fixboot
2. chkdsk /r /f
If they both fail you will either have to put your hard drive on a cradle and write another boot directory to it, or you will have to reformat it.
Mar 30, 2013 | Dell LATITUDE Computers & Internet
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
Stop error code 0x000000ED, dell inspiron mini 10 no disk drive. No recovery or repair disk.
http://www.wiki-errors.com/download.php try safe mode first turn off then turn on press f8 when u turn thhis will take you to safe mode screen try the LAST GOOD CONFIGERATION hopefully this will fix you problem other that click the link
Jul 28, 2011 | Computers & Internet
My netbook (Acer Aspire One Netbook ao531h) goes to blue screen on start-up it has an unmountable boot volume error, codes shown below: STOP 0x000000ED (0x86B5C470, 0xc0000006, 0x00000000, ...
Its the problem with hardware driver software. Please remove last installed software/hardware in your system. To remove software run system in safe mode by pressing F8 on system starting and select safe mode then remove last installed hardware by opening device manager or remove software by opening add remove program from the control panel.Then restart system.
Any problem came ask again new question
************************Please RATE it *******************
Apr 25, 2011 | Acer Aspire One Netbook AO531h-1729 10.1...
Hi, Everytime I turn on my DELL Dimension 5150 I am faced with the following message: A problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE...
This sounds like it can not mount your boot file from hard drive which needs to load windows. Sometimes this will happen if you leave a floppy, cd or some kinda usb flash drive in computer when rebooting and it does not happen always. I would try to boot in to safe mode as message is saying. To boot in to safe mode modet computers use F8 key. Turn off your pc and then as soon as you push power button start tapping key F8 located on top of keyboard. You can stop once you get screen that says Advanced startup menu. Choose option Safe mode and press enter. You will need to use arrows to make selection. Once you choose safe mode wait for the loading to be done and then choose ether your windows name or Administrator. Once in safe mode you will get error message just ignore it and press yes. When windwos comes up try to do a restore to previous date. Go to start-programs-accessories-system tools-system restore.in system restore choose restore to earlier time and on the calendar choose date that your computer was working fine. I usually go even week prior to when computer stopped working. Your data will be saved but if you have installed some programs you might have to reinstall them. Hope this helps.
Nov 06, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Windows Vista Start up problem, reboots automatically.
Boot to recovery console using XP CD, run CHKDSK /R and see if that resolves.
If no go, try a reinstall of windows, if still no go, then replace HDD
Sep 28, 2009 | Dell Inspiron 1525 Notebook
Unmountable boot volume
Hi
It looks you have a bad hard drive. Have you tried changing it? If not, try it. Regards.
Nov 28, 2008 | Sony VAIO VGN-FJ270/B Notebook
Since yesterday, cannot boot up my PB IMEDIA 1529 in XP. I get a screen message to say that Windows has been shut down to prevent damage to my computer. Trying to boot up using Safe Mode ends up with the...
Boot your system in safe mode then check, its booting or not, if boots restore it to some previous date, or change the RAM then check
please rate this solution i appreciate it
Nov 01, 2008 | Packard Bell Computers & Internet
Windows XP won't boot and safe mode doesn't work
Well hate to give you the bad news but it sounds like your hard drive as died. The error code you mentioned (0X000000ED) designates file system damage. (Referenced here http://support.microsoft.com/kb/297185). Your best solution would be to replace the hard drive in a repair shop.
Sep 07, 2008 | Microsoft Windows XP Professional With...
Toshiba Satellite A45-S121 Notebook Logo
705 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
