Question about Garden
My cub cadet 682 with a 17 hp kohler was running like **** i changed the points and condensor and it will run fine at high rpm but now will not idle whats the problem?
  • 66 Answers
Are the points set correctly? Check the gap....you said it was running like **** to start with...it maybe a carburetor issue.
Posted on May 30, 2010
Cub cadet 27 ton log splitter 6 hp runs high rpm all the time moving throttle doesn't help adj. governor no help.help
There's a very good chance the governor broke inside the crank case... outside adjustments won't help at this point... remove the motor and remove bottom portion of housing and you will find the problem.
Jul 02, 2017 | Cub Cadet Garden
Cub cadet gtx 1054 cutting grass and the tractor stop running. Will not start
check wires and connectors--check the inline fuse --seat switch -battery look over the wiring possible wire damaged or disconnected
Aug 14, 2016 | Cub Cadet GTX1054 54 in. 27 HP Kohler...
Why does my Vintage Cub Cadet 125, Kohler 12HP engine pop/backfire and die when given any throttle?
Carburetor needs adjusted. May need rebuilt or just cleaned. Could be one of the jets is plugged.
Jul 19, 2014 | Cub Cadet Garden
Cub cadet runs fine until I start the PTO, then it stutters and dies. If I shut off the PTO blade, it will pick back up and run again
I had a similar problem with my cub Cadet. It turned out that the Ignition Module on the engine was cracked. Motor started OK - but died as soon as a load (such as engaging the mower) was put on it.
These are not terribly hard to check, and/or change, yourself. Easy to get to once the motor shroud is removed.
My 25 HP Kohler engine has 2 modules. EXPENSIVE from the dealer - found MUCH better prices online.
Aug 30, 2013 | Cub Cadet Garden
I have a new Cub Cadet RZT-S - 23 HP Kohler. I was
check the drive belt on hydraulic pump under you seat
Aug 09, 2013 | Cub Cadet Garden
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
I have cub cadet 129 with 12 hp kohler cast iron engine when it runs for about 5 minuts the muffler gets cherry red does any one know why?
This would most likely indicate an air leak in the intake tract. Another possibility would be a partially clogged main jet in the carb. Either problem results in a lean running engine with VERY high exhaust temps. Bad news if not corrected.
Hope this helps,
Dolf_
Nov 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cadet does not fire
is it the 12 hp kohler? if so it is electronic type no points.
have you tried cleaning the flywheel magnet and coil?
use very fine sandpaper and clean them. if still no go gheck kill switch and nothing there is is probally a bad coil.
Jul 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
DGS 6500 w/26hp Kohler Courage surging
i HAD SIMILAR ISSUES WITH MY 2500 SERIES CUB CADET....IT WAS THE CARB.....REPLACED, AND ALL HAS BEEN WELL...THINK IT WAS APROX 200.00
Jul 03, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Garden Logo
139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
