Question about HP LaserJet 4600dn Color Printer
I am trying to print a note card measuring 8 5/8 x 6, with a half fold on the long side. What document size do I choose so it prints when it goes through?
  • 241 Answers
You can adjust the page size in the software application you are creating your document with. By doing this the printer should enable you to print your document. You can also choose to input a customized size. Make sure you choose the cardstock setting so the printer will not cause a paper jam, and it will be able to heat the fuser up enough so the toner will stick to the card stock.
Posted on May 28, 2010
Printmaster half-fold printing on epson printer
Before printing you need to select the size and orientation and it's a good idea to look at the preview before printing. That saves a lot of paper.
Nov 19, 2017 | Epson Office Equipment & Supplies
Paper fold and printing problem
Did U try to change drum unit,or maybe transfer roller
Oct 16, 2014 | Canon IR 3300 Digital Copier
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Printer not printing margins correctly
Set the margin unit of measurement to whatever you find most useful: inches, centimeters, millimeters, points, or picas.
  1. Choose File > Options > Advanced.
  2. Under Display, in the Show measurements in units of box, select the unit you want.
Mar 24, 2017 | HP Office Equipment & Supplies
Need to print a half-fold card envelope with HP Photosmart C4480
I also contacted HP and they directed me to a workaround which I have not implemented yet!
Mar 07, 2009 | HP Photosmart C5280 InkJet Printer
I'm printing wedding invitation envelopes (or A6) and had to set both my C4480 and psc1315 to a regular size 8.5x11 letter size but changed my margins to reflect the smaller size for my envelope with the left side of the screen being the more narrow margin. After adjusting the top margin accordingly, I fed the envelopes, flap side down and straight into the printer and voila...envelope addresses are printed. Good luck. Blu
Feb 15, 2009 | HP Photosmart C4480 All-In-One InkJet...
I AM PRINTING A DOCUMENT 2 SIDED AND I NEED IT TO FOLD IN HALF??
you could only do it if you have a saddle stich finisher..and if you do.. on the screen tap on finishing and follow step by step you will find saddle stich tap on it .. remember you could only do it with 8 1/2 X 14 (legal) and 11 X 17 (ledger)
Jan 07, 2009 | Toshiba COPIERS E-STUDIO 520 Copier
INSIDE MESSAGE ON GREETING CARD
Your card will fold to make an inside and outside once folded, but is seen in a page layout app differently.
Take a sheet of paper and fold it in half to represent the card you will be making.
Now open it up and lay it down on a table, with the inside of the card face down.
The outside back of the card should now be on your left, and the front of the card is on the right. Use a pencil or pen to mark it as such, if you need to.
Now when you do your card layout, the cover art and text should be on the right side of the page you create in the application.
If you flip the card over, so that the inside is now facing you, you are looking at the inside of the card.
Usually, the text and signature areas would be on the right side of this page, as well.
Now, use that same guidance when you work on 'page 2' of your document. Add the text to the right side of your page, so it will be on the right inside panel after you print and fold the card.
The final step is to print it out so that the inside and outside are in the correct orientation to each other.
Be sure to feed the paper such that the top of the card is facing the same side of the paper tray when you prnt both sides. (I sometimes make a light mark in pencil which can be erasd, to be sure it goes in the right direction, since this step is easily messed up.)
Good luck.
DigiChick
Jun 09, 2008 | Cosmi Print Perfect Platinum
HP LaserJet 4600dn Color Printer Logo
78 people viewed this question
Ben Johnson
